Подсчет строк по условию
Необходимо подсчитать количество строк в базе удовлетворяющему определенное значение Код: plaintext Данная формула должна быть в "textbox" ... |
| 09.10.2008, 19:02:15 |
что-то типа =sum((Fields!Коэф.Value > 1.1 ,1,0)) --- This posting is provided "AS IS" with no warranties, and confers no rights. ... |
| 09.10.2008, 23:42:55 |
LevSчто-то типа =sum((Fields!Коэф.Value > 1.1 ,1,0)) --- This posting is provided "AS IS" with no warranties, and confers no rights. спасибо, не работает, и выдало 4 ошибки [rsAggregateofAggregate] The Value expression for the textbox 'textbox13' contains an aggregate function (or RunningValue or RowNumber functions) in the argument to another aggregate function (or RunningValue). Aggregate functions cannot be nested inside other aggregate functions. [rsNonAggregateInMatrixCell] The BackgroundColor expression for the chart ‘chart2’ references a field outside an aggregate function. Value expressions in matrix cells should be aggregates, to allow for subtotaling. [rsReportItemReference] The Value expression for the textbox ‘textbox13’ refers to the report item ‘textbox22’. Report item expressions can only refer to other report items within the same grouping scope or a containing grouping scope. [rsMissingAggregateScope] The Value expression for the textbox ‘textbox13’ uses an aggregate expression without a scope. A scope is required for all aggregates used outside of a data region unless the report contains exactly one data set. [rsMissingAggregateScope] The Value expression for the textbox ‘textbox13’ uses an aggregate expression without a scope. A scope is required for all aggregates used outside of a data region unless the report contains exactly one data set. Build complete -- 4 errors, 1 warnings ... |
| 10.10.2008, 11:29:43 |
наверно имелось ввиду =sum(IIF(Fields!Коэф.Value > 1.1 ,1,0)) ... |
| 10.10.2008, 17:59:41 |
start [/forum/topic.php?fid=31&gotonew=1&tid=1536635]: |
27ms |
59ms |
80ms |
| others: | 353ms |
| total: | 593ms |
