Ошибка при запуске отчета на JasperServer
Отчет прекрасно работает как в Toad так и iReport. Одноко в JasperServer отваливается сразу же. Даже до показа окна с параметрами. Выдает вот такую портянку: com.jaspersoft.jasperserver.api.JSExceptionWrapper: Errors were encountered when compiling report expressions class file: org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed, calculator_over_bez_zach_1257260794088_509645: 44: unexpected token: field_ @ line 44, column 25. 1 error com.jaspersoft.jasperserver.api.JSExceptionWrapper: net.sf.jasperreports.engine.JRException: Errors were encountered when compiling report expressions class file: org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed, calculator_over_bez_zach_1257260794088_509645: 44: unexpected token: field_ @ line 44, column 25. 1 error at net.sf.jasperreports.compilers.JRGroovyCompiler.compileUnits(JRGroovyCompiler.java:92) at net.sf.jasperreports.engine.design.JRAbstractCompiler.compileReport(JRAbstractCompiler.java:192) at net.sf.jasperreports.engine.JasperCompileManager.compileReport(JasperCompileManager.java:219) at com.jaspersoft.jasperserver.api.engine.jasperreports.service.impl.EngineServiceImpl.compileReport(EngineServiceImpl.java:804) at com.jaspersoft.jasperserver.api.engine.jasperreports.service.impl.EngineServiceImpl$CacheableCompiledReports.getData(EngineServiceImpl.java:187) at com.jaspersoft.jasperserver.api.metadata.common.service.impl.hibernate.HibernateRepositoryCache.saveData(HibernateRepositoryCache.java:171) at com.jaspersoft.jasperserver.api.metadata.common.service.impl.hibernate.HibernateRepositoryCache.getCachedItem(HibernateRepositoryCache.java:110) at com.jaspersoft.jasperserver.api.metadata.common.service.impl.hibernate.HibernateRepositoryCache.cache(HibernateRepositoryCache.java:70) at sun.reflect.GeneratedMethodAccessor300.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:585) at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:281) at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:187) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:154) at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:107) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:176) at com.jaspersoft.jasperserver.api.common.util.spring.ReattemptMethodInterceptor.invoke(ReattemptMethodInterceptor.java:51) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:176) at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:210) at $Proxy6.cache(Unknown Source) at com.jaspersoft.jasperserver.api.engine.jasperreports.service.impl.EngineServiceImpl.getCompiledReport(EngineServiceImpl.java:813) at com.jaspersoft.jasperserver.api.engine.jasperreports.service.impl.EngineServiceImpl.getJasperReport(EngineServiceImpl.java:620) at com.jaspersoft.jasperserver.api.engine.jasperreports.service.impl.EngineServiceImpl.getReportInputControlsInformation(EngineServiceImpl.java:1052) at com.jaspersoft.jasperserver.war.action.ReportParametersAction.loadInputControlsInformation(ReportParametersAction.java:409) at com.jaspersoft.jasperserver.war.action.ReportParametersAction.createWrappers(ReportParametersAction.java:487) at com.jaspersoft.jasperserver.war.action.ReportParametersAction.createWrappers(ReportParametersAction.java:414) at com.jaspersoft.jasperserver.war.action.ReportParametersAction.createWrappers(ReportParametersAction.java:123) at com.jaspersoft.jasperserver.war.action.ViewReportAction.checkForParams(ViewReportAction.java:148) at sun.reflect.GeneratedMethodAccessor327.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:585) at org.springframework.webflow.util.DispatchMethodInvoker.invoke(DispatchMethodInvoker.java:103) at org.springframework.webflow.action.MultiAction.doExecute(MultiAction.java:136) at org.springframework.webflow.action.AbstractAction.execute(AbstractAction.java:203) at org.springframework.webflow.engine.AnnotatedAction.execute(AnnotatedAction.java:142) at org.springframework.webflow.engine.ActionExecutor.execute(ActionExecutor.java:61) at org.springframework.webflow.engine.ActionState.doEnter(ActionState.java:180) at org.springframework.webflow.engine.State.enter(State.java:200) at org.springframework.webflow.engine.Flow.start(Flow.java:557) at org.springframework.webflow.engine.impl.RequestControlContextImpl.start(RequestControlContextImpl.java:195) at org.springframework.webflow.engine.impl.FlowExecutionImpl.start(FlowExecutionImpl.java:189) at org.springframework.webflow.executor.FlowExecutorImpl.launch(FlowExecutorImpl.java:206) at sun.reflect.GeneratedMethodAccessor249.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:585) at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:281) at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:187) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:154) at org.acegisecurity.intercept.method.aopalliance.MethodSecurityInterceptor.invoke(MethodSecurityInterceptor.java:66) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:176) at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:210) at $Proxy13.launch(Unknown Source) at org.springframework.webflow.executor.support.FlowRequestHandler.handleFlowRequest(FlowRequestHandler.java:131) at org.springframework.webflow.executor.mvc.FlowController.handleRequestInternal(FlowController.java:170) at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153) at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:45) at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:820) at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:755) at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:396) at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:350) at javax.servlet.http.HttpServlet.service(HttpServlet.java:617) at javax.servlet.http.HttpServlet.service(HttpServlet.java:717) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.jaspersoft.jasperserver.war.common.UploadMultipartFilter.doFilter(UploadMultipartFilter.java:86) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264) at org.acegisecurity.ui.switchuser.SwitchUserProcessingFilter.doFilter(SwitchUserProcessingFilter.java:335) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107) at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at com.jaspersoft.jasperserver.api.metadata.user.service.impl.MetadataAuthenticationProcessingFilter.doFilter(MetadataAuthenticationProcessingFilter.java:141) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at com.jaspersoft.jasperserver.war.util.RequestParameterAuthenticationFilter.doFilter(RequestParameterAuthenticationFilter.java:97) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:181) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at com.jaspersoft.jasperserver.war.UserPreferencesFilter.doFilter(UserPreferencesFilter.java:165) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:217) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at com.jaspersoft.jasperserver.war.UserPreferencesFilter.doFilter(UserPreferencesFilter.java:165) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:191) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148) at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:90) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.jaspersoft.jasperserver.war.util.CharacterEncodingFilter.doFilter(CharacterEncodingFilter.java:70) at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:138) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286) at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:845) at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583) at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447) at java.lang.Thread.run(Thread.java:595) net.sf.jasperreports.engine.JRException: Errors were encountered when compiling report expressions class file: org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed, calculator_over_bez_zach_1257260794088_509645: 44: unexpected token: field_ @ line 44, column 25. 1 error net.sf.jasperreports.engine.JRException: Errors were encountered when compiling report expressions class file: org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed, calculator_over_bez_zach_1257260794088_509645: 44: unexpected token: field_ @ line 44, column 25. 1 error at net.sf.jasperreports.compilers.JRGroovyCompiler.compileUnits(JRGroovyCompiler.java:92) at net.sf.jasperreports.engine.design.JRAbstractCompiler.compileReport(JRAbstractCompiler.java:192) at net.sf.jasperreports.engine.JasperCompileManager.compileReport(JasperCompileManager.java:219) at com.jaspersoft.jasperserver.api.engine.jasperreports.service.impl.EngineServiceImpl.compileReport(EngineServiceImpl.java:804) at com.jaspersoft.jasperserver.api.engine.jasperreports.service.impl.EngineServiceImpl$CacheableCompiledReports.getData(EngineServiceImpl.java:187) at com.jaspersoft.jasperserver.api.metadata.common.service.impl.hibernate.HibernateRepositoryCache.saveData(HibernateRepositoryCache.java:171) at com.jaspersoft.jasperserver.api.metadata.common.service.impl.hibernate.HibernateRepositoryCache.getCachedItem(HibernateRepositoryCache.java:110) at com.jaspersoft.jasperserver.api.metadata.common.service.impl.hibernate.HibernateRepositoryCache.cache(HibernateRepositoryCache.java:70) at sun.reflect.GeneratedMethodAccessor300.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:585) at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:281) at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:187) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:154) at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:107) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:176) at com.jaspersoft.jasperserver.api.common.util.spring.ReattemptMethodInterceptor.invoke(ReattemptMethodInterceptor.java:51) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:176) at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:210) at $Proxy6.cache(Unknown Source) at com.jaspersoft.jasperserver.api.engine.jasperreports.service.impl.EngineServiceImpl.getCompiledReport(EngineServiceImpl.java:813) at com.jaspersoft.jasperserver.api.engine.jasperreports.service.impl.EngineServiceImpl.getJasperReport(EngineServiceImpl.java:620) at com.jaspersoft.jasperserver.api.engine.jasperreports.service.impl.EngineServiceImpl.getReportInputControlsInformation(EngineServiceImpl.java:1052) at com.jaspersoft.jasperserver.war.action.ReportParametersAction.loadInputControlsInformation(ReportParametersAction.java:409) at com.jaspersoft.jasperserver.war.action.ReportParametersAction.createWrappers(ReportParametersAction.java:487) at com.jaspersoft.jasperserver.war.action.ReportParametersAction.createWrappers(ReportParametersAction.java:414) at com.jaspersoft.jasperserver.war.action.ReportParametersAction.createWrappers(ReportParametersAction.java:123) at com.jaspersoft.jasperserver.war.action.ViewReportAction.checkForParams(ViewReportAction.java:148) at sun.reflect.GeneratedMethodAccessor327.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:585) at org.springframework.webflow.util.DispatchMethodInvoker.invoke(DispatchMethodInvoker.java:103) at org.springframework.webflow.action.MultiAction.doExecute(MultiAction.java:136) at org.springframework.webflow.action.AbstractAction.execute(AbstractAction.java:203) at org.springframework.webflow.engine.AnnotatedAction.execute(AnnotatedAction.java:142) at org.springframework.webflow.engine.ActionExecutor.execute(ActionExecutor.java:61) at org.springframework.webflow.engine.ActionState.doEnter(ActionState.java:180) at org.springframework.webflow.engine.State.enter(State.java:200) at org.springframework.webflow.engine.Flow.start(Flow.java:557) at org.springframework.webflow.engine.impl.RequestControlContextImpl.start(RequestControlContextImpl.java:195) at org.springframework.webflow.engine.impl.FlowExecutionImpl.start(FlowExecutionImpl.java:189) at org.springframework.webflow.executor.FlowExecutorImpl.launch(FlowExecutorImpl.java:206) at sun.reflect.GeneratedMethodAccessor249.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:585) at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:281) at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:187) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:154) at org.acegisecurity.intercept.method.aopalliance.MethodSecurityInterceptor.invoke(MethodSecurityInterceptor.java:66) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:176) at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:210) at $Proxy13.launch(Unknown Source) at org.springframework.webflow.executor.support.FlowRequestHandler.handleFlowRequest(FlowRequestHandler.java:131) at org.springframework.webflow.executor.mvc.FlowController.handleRequestInternal(FlowController.java:170) at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153) at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:45) at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:820) at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:755) at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:396) at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:350) at javax.servlet.http.HttpServlet.service(HttpServlet.java:617) at javax.servlet.http.HttpServlet.service(HttpServlet.java:717) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.jaspersoft.jasperserver.war.common.UploadMultipartFilter.doFilter(UploadMultipartFilter.java:86) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264) at org.acegisecurity.ui.switchuser.SwitchUserProcessingFilter.doFilter(SwitchUserProcessingFilter.java:335) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107) at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at com.jaspersoft.jasperserver.api.metadata.user.service.impl.MetadataAuthenticationProcessingFilter.doFilter(MetadataAuthenticationProcessingFilter.java:141) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at com.jaspersoft.jasperserver.war.util.RequestParameterAuthenticationFilter.doFilter(RequestParameterAuthenticationFilter.java:97) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:181) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at com.jaspersoft.jasperserver.war.UserPreferencesFilter.doFilter(UserPreferencesFilter.java:165) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:217) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at com.jaspersoft.jasperserver.war.UserPreferencesFilter.doFilter(UserPreferencesFilter.java:165) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:191) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274) at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148) at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:90) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.jaspersoft.jasperserver.war.util.CharacterEncodingFilter.doFilter(CharacterEncodingFilter.java:70) at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:138) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286) at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:845) at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583) at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447) at java.lang.Thread.run(Thread.java:595) ... |
| 03.11.2009, 18:18:37 |
Сменид Groovy на Java и все заработало. ... |
| 05.11.2009, 10:31:54 |
Всегда говорил: чем дольше путь команды к процессору, тем больще шансов на ошибку. а тут такая "борода" О_о вкусите множество сексуальных наслаждений с нашей новой платформой... (с) 1С. Ну вы поняли... ... |
| 05.11.2009, 23:29:15 |
ДА уж.. сообщения об ошибках в JasperServer иногда пугают... :) Но не все так страшно обычно оказывается.... К сожалению, на этом форуме нет людей работающих с этим софтом (или они просто не хотят общаться).... Потому писать сюда смысла нет... :( Где вы, люди? :) ... |
| 07.11.2009, 19:15:56 |
start [/forum/topic.php?fid=31&gotonew=1&tid=1535825]: |
44ms |
64ms |
| others: | 294ms |
| total: | 471ms |
