The device is not ready.
Такая фигня происходит.... Может кто сталкивался... я что то в непонятках. На домашней машине работает, на рабочей вот такое... Что делать никто не знает?(Кристал 10й) Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. Exception Details: System.Runtime.InteropServices.COMException: The device is not ready. Source Error: An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below. Stack Trace: [COMException (0x80004005): The device is not ready. ] CrystalDecisions.ReportAppServer.ClientDoc.ReportClientDocumentClass.Open(Object& DocumentPath, Int32 Options) +0 CrystalDecisions.ReportAppServer.ReportClientDocumentWrapper.Open(Object& DocumentPath, Int32 Options) +72 CrystalDecisions.ReportAppServer.ReportClientDocumentWrapper.EnsureDocumentIsOpened() +218 [Exception: Load report failed.] CrystalDecisions.Web.ReportAgentBase.() +537 CrystalDecisions.Web.ReportAgent.get_RequestContext() +10 CrystalDecisions.Web.ReportAgent.get_{() +7 CrystalDecisions.Web.ReportAgent.LoadViewState(Object viewState, Boolean bRptSourceChangedByNavigation) +1107 CrystalDecisions.Web.CrystalReportViewerBase.LoadViewState(Object viewState) +230 CrystalDecisions.Web.CrystalReportViewer.LoadViewState(Object viewState) +681 System.Web.UI.Control.LoadViewStateRecursive(Object savedState) +136 System.Web.UI.Control.LoadViewStateRecursive(Object savedState) +414 System.Web.UI.Control.LoadViewStateRecursive(Object savedState) +414 System.Web.UI.Page.LoadPageViewState() +306 System.Web.UI.Page.ProcessRequestMain() +447 ... |
| 18.11.2005, 20:21:02 |
start [/forum/topic.php?fid=31&fpage=167&tid=1539386]: |
41ms |
53ms |
| others: | 375ms |
| total: | 539ms |
