Crystal Report
Crystal Report 8,9 I have problem with Crystal Report. Problem: We have RTF text with embedded images stored in the Access 2000(Memo, Ole Object data types ) , MS SQL Server 2000(text, image data types). 1.CR could not show embedded images from memo/text fields, only text we can see. 2. CR could not show embedded images and text from image/Ole Object fields. From Rich text box(rich text format) we saved images and text to Access 2000(memo and Ole Object data types ) , MS SQL Server 2000( text and image data types) Used VB6. What is that problem? Thanks. ... |
| 23.05.2006, 21:38:12 |
Crystal Report
Version Crystal Report 9.2, no problem. ... |
| 24.05.2006, 10:45:18 |
start [/forum/topic.php?fid=31&fpage=158&tid=1539019]: |
27ms |
55ms |
25ms |
89ms |
| others: | 369ms |
| total: | 611ms |
