Астрософт +RS
Доброго времени суток, форумчане! Вообщем столкнулся с проблемой при настройке отчетов для Астрософт Хелпдеск, страница со ссылками на отчеты формируется но при кликании на ссылку говорит вот такю ошибку: Server Error in '/HelpDesk' Application. -------------------------------------------------------------------------------- Runtime Error Description: An application error occurred on the server. The current custom error settings for this application prevent the details of the application error from being viewed remotely (for security reasons). It could, however, be viewed by browsers running on the local server machine. Details: To enable the details of this specific error message to be viewable on remote machines, please create a <customErrors> tag within a "web.config" configuration file located in the root directory of the current web application. This <customErrors> tag should then have its "mode" attribute set to "Off". <!-- Web.Config Configuration File --> <configuration> <system.web> <customErrors mode="Off"/> </system.web> </configuration> Notes: The current error page you are seeing can be replaced by a custom error page by modifying the "defaultRedirect" attribute of the application's <customErrors> configuration tag to point to a custom error page URL. <!-- Web.Config Configuration File --> <configuration> <system.web> <customErrors mode="RemoteOnly" defaultRedirect="mycustompage.htm"/> </system.web> </configuration> Так же при попытке просмотреть отчеты в самом RS через http://localhost/reportmanager тоже выдает вот такую ошибку: Logon failed. (rsLogonFailed) For more information about this error navigate to the report server on the local server machine, or enable remote errors Помогите настроить пожалуйста. За ранее благодарен всем. ... |
| 22.09.2006, 10:07:12 |
start [/forum/topic.php?fid=31&fpage=149&tid=1538690]: |
23ms |
59ms |
80ms |
| others: | 349ms |
| total: | 567ms |
