Event Viewer (RS 2005)
Event Type: Error Event Source: Report Server (MSSQLSERVER) Event Category: Management Event ID: 107 Date: 18.10.2006 Time: 15:03:37 User: N/A Computer: PEAK Description: Report Server (MSSQLSERVER) cannot connect to the report server database. Кто-нибудь сталкивался с такой ошибкой?? С чем это вообще связано? ... |
| 18.10.2006, 16:26:51 |
Надо смотреть логи report server'а --- This posting is provided "AS IS" with no warranties, and confers no rights. ... |
| 19.10.2006, 03:17:19 |
в логах самого репортинга ничего такого нет, что указывало бы на ошибку. ... |
| 19.10.2006, 12:03:32 |
все таки нашла в логах репортинга ошибку автор w3wp!library!15!18.10.2006-17:17:30:: e ERROR: Throwing Microsoft.ReportingServices.Diagnostics.Utilities.ReportServerDatabaseUnavailableException: The report server cannot open a connection to the report server database. A connection to the database is required for all requests and processing., ; Info: Microsoft.ReportingServices.Diagnostics.Utilities.ReportServerDatabaseUnavailableException: The report server cannot open a connection to the report server database. A connection to the database is required for all requests and processing. ---> System.Data.SqlClient.SqlException: Violation of PRIMARY KEY constraint 'PK_RunningJobs'. Cannot insert duplicate key in object 'dbo.RunningJobs'. The statement has been terminated. at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection) at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection) at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj) at System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj) at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString) at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async) at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, DbAsyncResult result) at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(DbAsyncResult result, String methodName, Boolean sendToPipe) at System.Data.SqlClient.SqlCommand.ExecuteNonQuery() at Microsoft.ReportingServices.Library.RunningJobsDb.AddRunningJobs(Hashtable runningJobs) --- End of inner exception stack trace --- а вот эта ошибка пишется в ReportServerWebApp логе автор w3wp!ui!50!18.10.2006-16:41:07:: Unhandled exception: Microsoft.Reporting.WebForms.ReportServerException: Execution 'qqw11rra0xjd3wi0omlw0b55' cannot be found (rsExecutionNotFound) at Microsoft.Reporting.WebForms.ServerReport.GetExecutionInfo() at Microsoft.Reporting.WebForms.ServerReport.SetExecutionId(String executionId, Boolean fullReportLoad) at Microsoft.Reporting.WebForms.ServerReport.LoadFromUrlQuery(NameValueCollection requestParameters, Boolean fullReportLoad) at Microsoft.Reporting.WebForms.ReportDataOperation..ctor() at Microsoft.Reporting.WebForms.HttpHandler.GetHandler() at Microsoft.Reporting.WebForms.HttpHandler.ProcessRequest(HttpContext context) at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) и что все это значит? ... |
| 20.10.2006, 11:24:26 |
Это баг, исправлен в Service Pack 2 На функционирование сервера как будто не влияет. --- This posting is provided "AS IS" with no warranties, and confers no rights. ... |
| 26.10.2006, 01:31:57 |
LevSЭто баг, исправлен в Service Pack 2 На функционирование сервера как будто не влияет. --- This posting is provided "AS IS" with no warranties, and confers no rights. А когда его ждать? Подскажите по секрету ... |
| 26.10.2006, 09:39:12 |
Да хотелось бы уже исправить ситуацию=/ отчеты плохо работают из-за этого бага. ... |
| 26.10.2006, 15:05:07 |
Еще вопрос? О чем говорит вот эта ошибка??? вообще последнее время сыпятся одни ошибки For security reasons DTD is prohibited in this XML document. To enable DTD processing set the ProhibitDtd property on XmlReaderSettings to false and pass the settings into XmlReader.Create method. ... |
| 26.10.2006, 15:34:11 |
start [/forum/topic.php?fid=31&fpage=147&tid=1538578]: |
36ms |
52ms |
| others: | 317ms |
| total: | 463ms |
