проблемы после установки SP2 c последними хотфиксами
Добрый день! После установки SP2 к SQL Server 2005 возникли проблемы с Reporting при попытке изменения подписки пишет ошибку w3wp!library!7!01/08/2008-13:27:44:: e ERROR: Throwing Microsoft.ReportingServices.Diagnostics.Utilities.OperationNotSupportedNativeModeException: The operation is not supported on a report server that runs in native mode., ; Info: Microsoft.ReportingServices.Diagnostics.Utilities.OperationNotSupportedNativeModeException: The operation is not supported on a report server that runs in native mode. w3wp!extensionfactory!7!01/08/2008-13:27:44:: e ERROR: Exception caught instantiating Report Server DocumentLibrary report server extension: System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.TypeInitializationException: The type initializer for 'Microsoft.ReportingServices.SharePoint.SharePointDeliveryExtension.DocumentLibraryProvider' threw an exception. ---> Microsoft.ReportingServices.Diagnostics.Utilities.OperationNotSupportedNativeModeException: The operation is not supported on a report server that runs in native mode. at Microsoft.ReportingServices.SharePoint.SharePointDeliveryExtension.DocumentLibraryProvider..cctor() --- End of inner exception stack trace --- --- End of inner exception stack trace --- at System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandle& ctor, Boolean& bNeedSecurityCheck) at System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean fillCache) at System.RuntimeType.CreateInstanceImpl(Boolean publicOnly, Boolean skipVisibilityChecks, Boolean fillCache) at System.Activator.CreateInstance(Type type, Boolean nonPublic) at System.RuntimeType.CreateInstanceImpl(BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes) at System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes) at Microsoft.ReportingServices.Diagnostics.ExtensionClassFactory.CreateExtensionObject(Extension extConfig). w3wp!library!7!01/08/2008-13:27:44:: Call to GetReportParametersAction(/Reports Repository/ИНТЕГРАЦИЯ. ИНФО-БУХГАЛТЕР/Экспорт прихода готовой продукции). w3wp!library!8!01/08/2008-13:27:44:: Call to ListEventsAction(). w3wp!library!1!01/08/2008-13:27:44:: Call to GetSubscriptionPropertiessAction(d0c528a2-29fe-4af7-9955-82c1fe5cbb91). w3wp!library!1!01/08/2008-13:27:44:: Call to GetReportParametersAction(/Reports Repository/ИНТЕГРАЦИЯ. ИНФО-БУХГАЛТЕР/Экспорт прихода готовой продукции). w3wp!library!8!01/08/2008-13:27:45:: Call to ListSchedulesAction(). w3wp!library!8!01/08/2008-13:27:45:: e ERROR: Throwing Microsoft.ReportingServices.Diagnostics.Utilities.InternalCatalogException: An internal error occurred on the report server. See the error log for more details., ; Info: Microsoft.ReportingServices.Diagnostics.Utilities.InternalCatalogException: An internal error occurred on the report server. See the error log for more details. ---> System.Data.SqlClient.SqlException: The EXECUTE permission was denied on the object 'xp_sqlagent_notify', database 'mssqlsystemresource', schema 'sys'. at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection) at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection) at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj) at System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj) at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString) at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async) at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, DbAsyncResult result) at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(DbAsyncResult result, String methodName, Boolean sendToPipe) at System.Data.SqlClient.SqlCommand.ExecuteNonQuery() at Microsoft.ReportingServices.Library.InstrumentedSqlCommand.ExecuteNonQuery() at Microsoft.ReportingServices.Library.SqlAgentScheduler.get_IsSchedulerRunning() at Microsoft.ReportingServices.Library.SchedulingDBInterface.CheckIfSchedulerIsRunning(Boolean error) at Microsoft.ReportingServices.Library.SchedulingDBInterface.ListTasks(String path) at Microsoft.ReportingServices.Library.ListSchedulesAction.PerformActionNow() at Microsoft.ReportingServices.Library.RSSoapAction`1.Execute() --- End of inner exception stack trace --- как исправить это?? ... |
| 08.01.2008, 13:32:09 |
В похожей ситуации помогло следующее: - on the surface area configuration - еnable the "scheduled events and report delivery" option. --- This posting is provided "AS IS" with no warranties, and confers no rights. ... |
| 10.01.2008, 01:27:03 |
а у меня эта опция включена была. ... |
| 10.01.2008, 11:25:17 |
Посмотрите здесь: http://forums.microsoft.com/msdn/showpost.aspx?postid=17774&siteid=1 --- This posting is provided "AS IS" with no warranties, and confers no rights. ... |
| 10.01.2008, 21:45:44 |
start [/forum/topic.php?fid=31&fpage=116&tid=1537360]: |
26ms |
54ms |
72ms |
| others: | 315ms |
| total: | 519ms |
