Помогите, ошибка v Surface Area Configuration
Помогите пожайлуста,сегодня вышла такая ошибка, report server был настроен и работал, никто не менял ничего. Често в шоке, опыта работы с нет. TITLE: Surface Area Configuration ------------------------------ Client found response content type of 'text/html; charset=utf-8', but expected 'text/xml'. The request failed with the error message: -- <html> <head> <title>Configuration Error</title> <style> body {font-family:"Verdana";font-weight:normal;font-size: .7em;color:black;} p {font-family:"Verdana";font-weight:normal;color:black;margin-top: -5px} b {font-family:"Verdana";font-weight:bold;color:black;margin-top: -5px} H1 { font-family:"Verdana";font-weight:normal;font-size:18pt;color:red } H2 { font-family:"Verdana";font-weight:normal;font-size:14pt;color:maroon } pre {font-family:"Lucida Console";font-size: .9em} .marker {font-weight: bold; color: black;text-decoration: none;} .version {color: gray;} .error {margin-bottom: 10px;} .expandable { text-decoration:underline; font-weight:bold; color:navy; cursor:hand; } </style> </head> <body bgcolor="white"> <span><H1>Server Error in '/ReportServer' Application.<hr width=100% size=1 color=silver></H1> <h2> <i>Configuration Error</i> </h2></span> <font face="Arial, Helvetica, Geneva, SunSans-Regular, sans-serif "> <b> Description: </b>An error occurred during the processing of a configuration file required to service this request. Please review the specific error details below and modify your configuration file appropriately. <br><br> <b> Parser Error Message: </b>An error occurred loading a configuration file: Failed to start monitoring changes to 'C:\Program Files\Microsoft SQL Server\MSSQL.3\Reporting Services\web.config' because access is denied.<br><br> <b>Source Error:</b> <br><br> <table width=100% bgcolor="#ffffcc"> <tr> <td> <code><pre> [No relevant source lines]</pre></code> </td> </tr> </table> <br> <b> Source File: </b> C:\Program Files\Microsoft SQL Server\MSSQL.3\Reporting Services\web.config<b> Line: </b> 0 <br><br> <hr width=100% size=1 color=silver> <b>Version Information:</b> Microsoft .NET Framework Version:2.0.50727.1433; ASP.NET Version:2.0.50727.1433 </font> </body> </html> <!-- [HttpException]: Failed to start monitoring changes to 'C:\Program Files\Microsoft SQL Server\MSSQL.3\Reporting Services\web.config' because access is denied. at System.Web.DirectoryMonitor.AddFileMonitor(String file) at System.Web.DirectoryMonitor.StartMonitoringFile(String file, FileChangeEventHandler callback, String alias) at System.Web.FileChangesMonitor.StartMonitoringFile(String alias, FileChangeEventHandler callback) at System.Web.Configuration.WebConfigurationHost.StartMonitoringStreamForChanges(String streamName, StreamChangeCallback callback) at System.Configuration.BaseConfigurationRecord.MonitorStream(String configKey, String configSource, String streamname) at System.Configuration.BaseConfigurationRecord.InitConfigFromFile() [ConfigurationErrorsException]: An error occurred loading a configuration file: Failed to start monitoring changes to 'C:\Program Files\Microsoft SQL Server\MSSQL.3\Reporting Services\web.config' because access is denied. (C:\Program Files\Microsoft SQL Server\MSSQL.3\Reporting Services\web.config) at System.Configuration.ConfigurationSchemaErrors.ThrowIfErrors(Boolean ignoreLocal) at System.Configuration.BaseConfigurationRecord.ThrowIfParseErrors(ConfigurationSchemaErrors schemaErrors) at System.Configuration.BaseConfigurationRecord.GetSectionRecursive(String configKey, Boolean getLkg, Boolean checkPermission, Boolean getRuntimeObject, Boolean requestIsHere, Object& result, Object& resultRuntimeObject) at System.Configuration.BaseConfigurationRecord.GetSection(String configKey, Boolean getLkg, Boolean checkPermission) at System.Configuration.BaseConfigurationRecord.GetSection(String configKey) at System.Web.Configuration.RuntimeConfig.GetSectionObject(String sectionName) at System.Web.Configuration.RuntimeConfig.GetSection(String sectionName, Type type, ResultsIndex index) at System.Web.Configuration.RuntimeConfig.get_CustomErrors() at System.Web.Configuration.CustomErrorsSection.GetSettings(HttpContext context, Boolean canThrow) at System.Web.HttpResponse.ReportRuntimeError(Exception e, Boolean canThrow, Boolean localExecute) at System.Web.HttpRuntime.FinishRequest(HttpWorkerRequest wr, HttpContext context, Exception e) --> --. (SQLSAC) ... |
| 16.09.2008, 11:07:33 |
qwerty2000An error occurred loading a configuration file: Failed to start monitoring changes to 'C:\Program Files\Microsoft SQL Server\MSSQL.3\Reporting Services\web.config' because access is denied попробуйте посмотреть все ли в порядке с правам на папку ... |
| 16.09.2008, 11:23:10 |
start [/forum/topic.php?fid=31&fpage=100&tid=1536713]: |
23ms |
49ms |
57ms |
| others: | 304ms |
| total: | 484ms |
