Кто использовал шасси "ViDock" для внешних видеокарт для ноутбуков?
http://www.villageinstruments.com/tiki-index.php?page=ViDock Introducing ViDock 3, ViDock 4, and ViDock 4 Plus ViDock 3, ViDock 4, and ViDock 4 Plus are expansion chassis tailored specifically for adapting PCI Express graphics cards for use with ExpressCard equipped laptop PCs. Simply select the PCI Express graphics card the best fits your needs and install it in the box. It’s that simple. Imagine using your thin and light laptop PC during the day on the job, at school, or at the local café then arriving home, or dorm room, plugging it into your ViDock and firing up your latest PC game on a large format monitor. Just plug in one cable into your laptop PC and you instantly have a powerful 3D workstation with a big display, a big keyboard and your pointing device of choice. You are ready for gaming, video transcoding, photoshop, 3D design, watching full 1080p HD movies, and more! When you need mobility and performance for gaming PC gamers that need the mobility of a laptop are faced with purchasing a separate gaming desktop for graphics performance and a laptop for small size, light weight, cool temperature, and long battery life. This solution is expensive and keeping the two machines in sync is not always easy. One alternative is to purchase an expensive gaming laptop and deal with lugging around a large and heavy machine, getting burned by the heat, and little battery life. And, when it comes time to upgrade, the only option is to replace the entire laptop. With a ViDock expansion chassis, you can simply unplug and go to take full advantage of your laptop’s mobile features - light weight, cool, small laptop with great battery life. When you get home, just plug in one cable and your are ready! No sync, no firing up a separate machine, no aches and pains of lugging a heavy computer around all day. And, when it’s time to upgrade, just replace the graphics card with the latest one available - in a few minutes! Docking for Gamers With just one cable, your laptop can connect to a large format display (or two), keyboard, and mouse. A USB hub will allow you to add more devices to the one-step plug-in such as a printer, external hard drive, USB headset, and more. Intelligent Power Management ViDock 3 manages its own power, so there is no need to fiddle with an on/off button. The embedded microcontroller in ViDock 3 senses the laptop’s power state and keeps the graphics card in sync even while cycling through suspend or sleep modes. Works best with Windows 7 ViDock is not only compatible with Windows 7 but takes full advantage of its latest features. Windows 7 instantly remembers and restores your display configurations when you hot plug your ViDock then again when you gracefully remove ViDock. No need to go into the display set-up dialog box to configure your displays. Also, with Windows 7, the graphics card in ViDock will show up in the eject tray as a removable device. ViDock also works with Vista, Windows XP, and Mac OS X. Very easy card installation With the removal of four thumbscrews, ViDock’s PCI Express card slot is exposed for easy card installation. Once the card is installed in the slot, just slide the assembly back in and install the thumbscrews. ViDock 3, ViDock 4, and ViDock 4 Plus - Choose the one that fits your needs ViDock 3 is designed for graphics cards that consume up to 75W of power and get all of their power needs from the PCI Express connector. It can accommodate cards up to 240mm long, which is a bit longer than the PCI Express Standard “half length” cards. ViDock 4 is designed for those higher performance graphics cards that require up to 150W of power and use a 6 pin power connector to supplement the power supplied by the PCI Express connector. It will accommodate cards that are up to 316mm long, which is the PCI Express “full length” specification. ViDock 4 Plus adds a second 2 x 3 pin power connector to accommodate graphics cards that require up to 225W. These ViDock products are offered without a graphics card installed so that the user can choose the card that best fits his/her laptop model and desired performance level. All three ViDock models support double wide PCIe cards. Кто-то уже узал такое шасси? А что, видяху поменял и немного проапгрейдил ноут! இڿڰۣڿڰஇڿڰۣڿڰஇڿڰۣڿڰஇڿڰۣڿڰஇڿڰۣڿڰஇڿڰۣڿڰஇڿڰۣڿڰஇڿڰۣڿڰஇڿڰۣڿڰஇڿڰۣڿڰஇ Спасибо всем, кто меня ненавидит - вы делаете меня еще сильнее!!! ... |
| 31.12.2011, 02:52:59 |
И похоже не позволяет использовать монитор самого ноута http://www.youtube.com/v/oXiQ6-6rcY0 ... |
| 31.12.2011, 03:12:59 |
С0ВЕСТЬИ похоже не позволяет использовать монитор самого ноута Это ж, вроде как, очевидно. Каким боком видеокарта может использовать монитор, который к ней не подключен? ... |
| 31.12.2011, 05:17:45 |
ДжекНепотрошительС0ВЕСТЬ Это ж, вроде как, очевидно. Каким боком видеокарта может использовать монитор, который к ней не подключен? особых проблем нет, бэк и фронт буферы могут быть на разных картах ... |
| 01.01.2012, 03:57:14 |
start [/forum/topic.php?fid=30&gotonew=1&tid=1530391]: |
69ms |
56ms |
| others: | 224ms |
| total: | 411ms |
