tecdoc pictures
Hallo, I have a big problem. I try to transfer the Tecdoc database to mysql. The problem occurs when i try transfer the images table "tof_gra_data_1, tof_gra_data_2 etc". This is the problem: "You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'ÎÔ¦Ãa¹[q™Q[nEû²¤°$E‰4bì»”g²wår݉¿¦s»¯µL' at line 1" Please help me! Thank you. ... |
| 02.03.2011, 00:25 |
tecdoc pictures
Dumitru, 1. The rules of this forum require using the russian language only. 2. We can't read the text You wrote "...to use near '*************' at line 1". On the place of the picks we see unrecognizeble characters. Just this piece of your post contains the key of solution. 3. Your question may be discussed in other subjects of this forum. Can you read in russian? ... |
| 02.03.2011, 09:22 |
start [/forum/topic.php?fid=29&gotonew=1&tid=1526299]: |
97ms |
35ms |
| others: | 235ms |
| total: | 422ms |
