Siebel 8.2.2 Конфигурирование Gateway Name Server
Добрый день! При конфигурировании Gateway Name Server мастер конфигурации вылетает с ошибкой. В лог пишет следующее: ------------ Шаг PrimaryLanguage 16.08.2012 10:45:50 oracle.siebel.configurator.utility.DefaultExceptionHandler uncaughtException SEVERE: java.lang.StringIndexOutOfBoundsException: String index out of range: -1 java.lang.StringIndexOutOfBoundsException: String index out of range: -1 at java.lang.String.substring(String.java:1937) at oracle.siebel.configurator.utility.ConfigUtility.DLOVInstalledLanguage(ConfigUtility.java:592) at oracle.siebel.configurator.engine.AccessSCM.executeDLOVAttrib(AccessSCM.java:4806) at oracle.siebel.configurator.engine.AccessSCM.getNextStep(AccessSCM.java:1175) at oracle.siebel.configurator.screen.ConfiguratorFrame$nextActionListener.actionPerformed(ConfiguratorFrame.java:1735) at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1995) at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2318) at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:387) at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:242) at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:236) at java.awt.Component.processMouseEvent(Component.java:6267) at javax.swing.JComponent.processMouseEvent(JComponent.java:3267) at java.awt.Component.processEvent(Component.java:6032) at java.awt.Container.processEvent(Container.java:2041) at java.awt.Component.dispatchEventImpl(Component.java:4630) at java.awt.Container.dispatchEventImpl(Container.java:2099) at java.awt.Component.dispatchEvent(Component.java:4460) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4577) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4238) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4168) at java.awt.Container.dispatchEventImpl(Container.java:2085) at java.awt.Window.dispatchEventImpl(Window.java:2478) at java.awt.Component.dispatchEvent(Component.java:4460) at java.awt.EventQueue.dispatchEvent(EventQueue.java:599) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161) at java.awt.EventDispatchThread.run(EventDispatchThread.java:122) ------------------- Сервер:Windows Server 2003 SP2 64 bit ENG Siebel ставил, только английский язык. Настораживает, что инсталятор Siebel был на английском, а мастер конфигурации почему-то на русском языке. И еще, при инсталяции Siebel, в конце была ошибка:OUI-10133: Invalid staging area. There are no top level components for Windows NT, Windows 2000 available for installation in this staging area. Но я думаю, что она на это не влияет. Если кто встречался с таким, подскажите пожалуйста в какую сторону смотреть. ... |
| 16.08.2012, 12:02 |
Топик можно закрыть. Проблема решилась следующим образом, похоже, что предыдущие ошибки при инсталляции Siebel имели влияние. Итак: 1. Снести установленный сибель и почистить реестр. 2. Проинсталировать его снова. Но запускать инсталятор не через module.exe а через setup.bat. Установка пройдет без ошибок. 3. Смотрим Event Viewer винды, в разделе Application видим предупреждение, что у нас не зарегистрировалась ssceolpr.dll Ее нужно зарегистрировать в ручную. После этого, мастер конфигурации Gateway Name Server отработал без ошибок. ... |
| 16.08.2012, 18:45 |
start [/forum/topic.php?fid=29&gotonew=1&tid=1526107]: |
161ms |
41ms |
| others: | 219ms |
| total: | 469ms |
