VFP 8 SP1 + Windows Me
Начало вот тут http://]www.sql.ru/forum/actualthread.aspx?tid=136382 Есть программа на фоксе 8ке, при работе на Windows Me через раз валит систему в синий экран с ошибкой. Ошибка 0Е адрес 0025:0000459А VxD VREDIR (01) + 0000459A Вызов (адрес 0028:C0033FT8) произведен из драйвера IFSMGR (01) + 00001098 Кто-нибудь сталкивался, подскажите чего крутить ? ... |
| 08.11.2004, 13:53:13 |
Решения найдено - помог фикс к ОСи с гордым названием 293793CHTM.EXE. В описании вот чего: Hot Fix for Microsoft Knowledge Base article number Q293793 Knowledge Base Article ====================== To view the contents of the knowledge base article for this update, visit http://support.microsoft.com/support/misc/kblookup.asp?id=293793 directly, or visit http://support.microsoft.com and query the Knowledge base for the product and the Q number of this update. Installation Instructions ========================= 1. If this hotfix was delivered with hfx.exe then it can be installed by running hfx.exe from the appropriate platform directory. Disclaimer of Liability ====================== The software which may include "online" or electronic documentation (together the "Software"), are provided to you at no additional charge. The Software is protected by United States copyright laws and international copyright treaties, as well as other intellectual property laws and treaties. Microsoft Corporation owns all right, title and interest to the Software. The Software is licensed, not sold. DISCLAIMER OF WARRANTIES. TO THE MAXIMUM EXTENT PERMITTED BY APPLICABLE LAW, MICROSOFT AND ITS SUPPLIERS EXPRESSLY DISCLAIM ALL WARRANTIES FOR THE SOFTWARE. THE SOFTWARE IS PROVIDED "AS IS" WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, AND NON-INFRINGEMENT. THE ENTIRE RISK ARISING OUT OF USE OR PERFORMANCE OF THE SOFTWARE REMAINS WITH YOU. The Software is provided with RESTRICTED RIGHTS. Use, duplication, or disclosure by the Government is subject to restrictions set forth in subparagraph (c)(1)(ii) of the Rights in Technical Data and Computer Software clause at DFARS 252.227-7013 or subparagraphs (c)(1) and (2) of the Commercial Computer Software--Restricted Rights at 48 CFR 52.227-19, as applicable. Manufacturer is Microsoft Corporation, One Microsoft Way, Redmond, WA 98052-6399. Any transfer of this Software must be accompanied by this statement and may only be transferred if first approved by Microsoft. (c) 2001 Microsoft Corporation, All Rights Reserved. Posted via ActualForum NNTP Server 1.1 ... |
| 09.11.2004, 09:30:09 |
start [/forum/topic.php?fid=26&gotonew=1&tid=1514608]: |
186ms |
43ms |
| others: | 228ms |
| total: | 494ms |
