SUS - замучался ужо ...
Поставил SUS синхронизировался, тапереча не могу прливать обновления на клиентских машинах ... Може кто проходил по таким же граблям ... ?? поможите плз ! Под W2000Pro(SP4) пишет - 2005-02-15 12:44:32 06:44:32 Success IUCTL Starting 2005-02-15 12:44:43 06:44:43 Success IUCTL Downloaded iuident.cab from http://susserver.aaaaa.ru to C:\Program Files\WindowsUpdate\V4 2005-02-15 12:44:44 06:44:44 Success IUENGINE Starting 2005-02-15 12:44:44 06:44:44 Success IUENGINE Determining machine configuration 2005-02-15 12:44:44 06:44:44 Error IUENGINE Querying software update catalog from http://susserver.aaaaa.ru/autoupdate/getmanifest.asp (Error 0x80190193) 2005-02-15 12:44:44 06:44:44 Success IUENGINE Shutting down 2005-02-15 12:44:44 06:44:44 Success IUCTL Shutting down Под WXP(SP1) пишет - 2005-02-15 14:30:37+0600 1476 240 Successfully opened event cache file at C:\WINDOWS\SoftwareDistribution\EventCache\{B8436424-CEF4-4ACA-8AAD-CDA9047DF784}.bin for reading. 2005-02-15 14:30:37+0600 3972 d00 Trying to make out of proc datastore active 2005-02-15 14:30:38+0600 3972 d00 Out of proc datastore is now active 2005-02-15 14:30:38+0600 1476 240 PT: Using serverID {3DA21691-E39D-4DA6-8A4B-B43877BCB1B7} 2005-02-15 14:30:38+0600 1476 240 PT: Using server URL http://susserver.aaaaa.ru /ClientWebService/client.asmx 2005-02-15 14:30:38+0600 1476 240 PT: Calling GetConfig on server 2005-02-15 14:30:38+0600 1476 240 Add header for accept-encoding: xpress succeeded 2005-02-15 14:30:38+0600 1476 240 DetectCompressionType returning type 0, hr=0x1 2005-02-15 14:30:38+0600 1476 240 GetConfig: 0x8024401a 2005-02-15 14:30:38+0600 1476 240 PT: Cannot recover from fault, origin=GetConfig, hr=0x8024401a 2005-02-15 14:30:38+0600 1476 240 Failed to obtain cached cookie with hr = 8024401a. 2005-02-15 14:30:38+0600 1476 240 Failed to upload events with hr = 8024401a. 2005-02-15 14:35:38+0600 3972 d00 Out of proc datastore is shutting down 2005-02-15 14:35:39+0600 3972 d00 Out of proc datastore is now inactive ... |
| 15.02.2005, 11:44:36 |
Перегрузи и саевак и машины, дождись нового обновленя от мелкомягких. У меня так вылечилось :) Posted via ActualForum NNTP Server 1.1 ... |
| 15.02.2005, 11:47:28 |
start [/forum/topic.php?fid=26&gotonew=1&tid=1513841]: |
46ms |
28ms |
| others: | 219ms |
| total: | 335ms |
