WSUS::Server Error in '/WSUSAdmin' Application. - Cannot execute a program
AD2000, DC, has SUS running Installation went without a hitch. Tried this without any success: Cannot access the WSUS console Any feedback is appreciated Thanks http://server:8530/wsusadmin/Server Error in '/WSUSAdmin' Application. -------------------------------------------------------------------------------- Cannot execute a program. The command being executed was "c:\winnt\microsoft.net\framework\v1.1.4322\csc.exe" /noconfig @"C:\WINNT\Microsoft.NET\Framework\v1.1.4322\Temporary ASP.NET Files\wsusadmin\f233198f\f9e45c2\5qyna6rw.cmdline". Description: An unhandled exception occurred during compilation using the CodeDomProvider 'Microsoft.CSharp.CSharpCodeProvider'. Please review the stack trace for more information about the error and where it originated in the code. Exception Details: System.Runtime.InteropServices.ExternalException: Cannot execute a program. The command being executed was "c:\winnt\microsoft.net\framework\v1.1.4322\csc.exe" /noconfig @"C:\WINNT\Microsoft.NET\Framework\v1.1.4322\Temporary ASP.NET Files\wsusadmin\f233198f\f9e45c2\5qyna6rw.cmdline". Source Error: An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below. Stack Trace: [ExternalException (0x5): Cannot execute a program. The command being executed was "c:\winnt\microsoft.net\framework\v1.1.4322\csc.exe" /noconfig @"C:\WINNT\Microsoft.NET\Framework\v1.1.4322\Temporary ASP.NET Files\wsusadmin\f233198f\f9e45c2\5qyna6rw.cmdline".] System.CodeDom.Compiler.Executor.ExecWaitWithCaptureUnimpersonated(IntPtr userToken, String cmd, String currentDir, TempFileCollection tempFiles, String& outputName, String& errorName, String trueCmdLine) +2036 System.CodeDom.Compiler.Executor.ExecWaitWithCapture(IntPtr userToken, String cmd, String currentDir, TempFileCollection tempFiles, String& outputName, String& errorName, String trueCmdLine) +260 System.CodeDom.Compiler.CodeCompiler.Compile(CompilerParameters options, String compilerDirectory, String compilerExe, String arguments, String& outputFile, Int32& nativeReturnValue, String trueArgs) +383 System.CodeDom.Compiler.CodeCompiler.FromFileBatch(CompilerParameters options, String[] fileNames) +548 System.CodeDom.Compiler.CodeCompiler.FromDomBatch(CompilerParameters options, CodeCompileUnit[] ea) +428 System.CodeDom.Compiler.CodeCompiler.FromDom(CompilerParameters options, CodeCompileUnit e) +90 System.CodeDom.Compiler.CodeCompiler.System.CodeDom.Compiler.ICodeCompiler.CompileAssemblyFromDom(CompilerParameters options, CodeCompileUnit e) +37 System.Web.Compilation.BaseCompiler.GetCompiledType() +227 -------------------------------------------------------------------------------- Version Information: Microsoft .NET Framework Version:1.1.4322.2032; ASP.NET Version:1.1.4322.2032 ... |
| 21.06.2005, 20:05:01 |
closed - resolved details here ... |
| 21.06.2005, 22:11:25 |
start [/forum/topic.php?fid=26&gotonew=1&tid=1512951]: |
32ms |
| others: | 217ms |
| total: | 304ms |
