откуда берутся SDK
[This is preliminary documentation and subject to change] Development Environment All the transaction interfaces are COM (Component Object Model) interfaces and, therefore, the natural language of choice is C++. The interfaces are available in the following header files: Comsvcs.H Transact.H Txdtc.H XoleHlp.H The header file “Transact.h” contains interfaces that an application will use to interact with the transaction coordinator (such as DTC); interfaces such as ITransactionDispenser Interface, ITransaction Interface, and so forth. The header file “Txdtc.h” contains interfaces which deal with the interaction between the resource manager and the transaction coordinator. The header file “XoleHlp.H” contains API definitions used to connect to DTC. All of these header files are available with the DTC Software Development Kit (SDK). я поискал на диске headers spoken above и ничего не нашел. тогда поискал DTC Software Development Kit и тоже ничего не нашел. как быть? ... |
| 13.07.2005, 16:58:56 |
start [/forum/topic.php?fid=26&gotonew=1&tid=1512790]: |
46ms |
23ms |
| others: | 221ms |
| total: | 320ms |
