dcdiag показала ошибки. Как исправить?
Добрый день. Есть два DC в разных подсетях: primary PDC (192.168.0.1) и backup BDC (192.168.1.1) . Запустил на BDC dcdiag , тест Advertising не пройден: авторDomain Controller Diagnosis Performing initial setup: Done gathering initial info. Doing initial required tests Testing server: Office\BDC Starting test: Connectivity ......................... BDC passed test Connectivity Doing primary tests Testing server: Office\BDC Starting test: Replications ......................... BDC passed test Replications Starting test: NCSecDesc ......................... BDC passed test NCSecDesc Starting test: NetLogons ......................... BDC passed test NetLogons Starting test: Advertising Warning: DsGetDcName returned information for \\pdc.firm.local, when we were trying to reach BDC. Server is not responding or is not considered suitable. ......................... BDC failed test Advertising Starting test: KnowsOfRoleHolders ......................... BDC passed test KnowsOfRoleHolders Starting test: RidManager ......................... BDC passed test RidManager Starting test: MachineAccount ......................... BDC passed test MachineAccount Starting test: Services ......................... BDC passed test Services Starting test: ObjectsReplicated ......................... BDC passed test ObjectsReplicated Starting test: frssysvol Error: No record of File Replication System, SYSVOL started. The Active Directory may be prevented from starting. ......................... BDC passed test frssysvol Starting test: kccevent ......................... BDC passed test kccevent Starting test: systemlog ......................... BDC passed test systemlog Running enterprise tests on : firm.local Starting test: Intersite ......................... firm.local passed test Intersite Starting test: FsmoCheck ......................... firm.local passed test FsmoCheck Подскажите, как исправить ошибку? Спасибо. ... |
| 18.12.2005, 18:33:48 |
Какой вопрос - такой и тынц. Хотя может совсем не в ту степь... http://support.microsoft.com/kb/296951 Posted via ActualForum NNTP Server 1.3 ... |
| 18.12.2005, 21:16:47 |
Да, вроде симптомы верные. И какой hot-fix ставить, у меня Win2K Server SP4 (rus) ? Если есть, поделитесь пожалуйста. Буду очень благодарен. ... |
| 19.12.2005, 00:27:19 |
Переустанови сп4. Еще в этом году выходил накопительный пакет обновлений для 2000, его тоже поставь Posted via ActualForum NNTP Server 1.3 ... |
| 19.12.2005, 11:24:46 |
SP4 интегрирован... Сносить и ставить по-новой получается. Вопрос: если поставить на bdc win2003, проблема должна решиться? Где-то есть накопительный пакет для rus версии? ... |
| 19.12.2005, 13:07:05 |
Если (судя по артиклю выше) проблема не в сервис-паке, то либо статья не та, либо проблема в локализованной винде Posted via ActualForum NNTP Server 1.3 ... |
| 19.12.2005, 16:12:26 |
netdiag дал такое: авторDomain membership test . . . . . . : Failed [WARNING] Ths system volume has not been completely replicated to the local machine. This machine is not working properly as a DC. Возможно глупый вопрос, но... проблема хоть не в pdc? Тогда может быть win2003 поможет. ... |
| 19.12.2005, 16:28:48 |
Встречный глупый вопрос - а какие ДЦ есть в сети и какие мастера на каком ДЦ установлены? Опиши сеть плз в дополнение к первому вопросу! ЗЫ: осмелюсь напомнить: понятия ПДЦ и БДЦ умерли вместе с НТ4 доменами, в 2000 доменах и старше все ДЦ равноправны. ЗЗЫ: в современных доменах 90% ошибок - это ошибки ДНС и проблемы прохождения пакетов между ДЦ, если с настройками по умолчанию не играть в извращенной форме. Что ни говори про дядю Билли, а что серверы, что клиенты сечас достаточно стабильны, чтобы они нормально работали продолжительное время... ЗЗЫ2: начал писать, потом все стер нафиг Матов там, кстати, не было... Posted via ActualForum NNTP Server 1.3 ... |
| 19.12.2005, 18:46:22 |
авторв 2000 доменах и старше все ДЦ равноправны. Интересно. А M$ пишет, что первый контроллер в домене, по умолчанию, является владельцем операций. И он, условно, все же первичный контроллер, а все остальные дополнительные ... |
| 20.12.2005, 15:51:09 |
Тогда уж условно можно раскидать владельцев операции на 5 машин и все их смело называть ПДЦ :-) Posted via ActualForum NNTP Server 1.3 ... |
| 20.12.2005, 16:31:21 |
YanisТогда уж условно можно раскидать владельцев операции на 5 машин и все их смело называть ПДЦ :-) Posted via ActualForum NNTP Server 1.3 Можно, но не нужно - есть роль Эмулятор PDC. Хоть там и толкуют о пред-Win2000 клиентах, но на самом деле даже в NATIVE режиме домена PDC играет особую роль, например, удаленное подключение по телефону доменной уч. записи не может быть авторизовано, если PDC не доступен. ДАЖЕ ЕСЛИ МОДЕМ стоит на DC (не PDC). Сам нарывался. Теперь по-существу: В данном случае, т.е. когда PDC полностью работоспособен проще всего: 1) Временно отключить BDC от сети и убедиться, что все фунициклирует. 2) Подключить обратно к сети и понизить до сервера. 3) Обратно поднять до DC, подождать 15-45 мин и проверить, что все реплицировалось и работает. ... |
| 21.12.2005, 09:13:05 |
А как вообще правилно делать. Допустим у меня 3 контроллера. Лучше сделать каждый из контроллеров мастером какой либо операции или пусть мастером будет однин контроллер? ... |
| 21.12.2005, 10:33:04 |
ALex_hhaА как вообще правилно делать. Допустим у меня 3 контроллера. Лучше сделать каждый из контроллеров мастером какой либо операции или пусть мастером будет однин контроллер? на MS KB есть на этот щёт статьи и даже на русском вроди тоже ... цитировать нет смысла, смотрите первоисточник ... ... |
| 21.12.2005, 14:10:17 |
А что, то что говорит MS является единственно правильным? ... |
| 21.12.2005, 18:08:51 |
Почти всегда - да. Если нет - то нужно искать другую их же статью, в которой написано опровержение этой. На самом деле единственно правильным является то, что говорит админ отдельно взятой машины. Posted via ActualForum NNTP Server 1.3 ... |
| 21.12.2005, 22:13:33 |
YanisВстречный глупый вопрос - а какие ДЦ есть в сети и какие мастера на каком ДЦ установлены? Опиши сеть плз в дополнение к первому вопросу! Posted via ActualForum NNTP Server 1.3 В сети два ДЦ. Расположены в двух разных точках города, соединены сетки через VPN. Мастера стоят все на PDC (по крайней мере, я никаких действий не предпринимал, чтобы переместить какой-то из пяти мастеров на BDC) (как определить, где какие мастера? как-то на этот вопрос я и внимания не обращал...). Когда VPN падает, во второй подсетке где BDC начинаются проблемы (в сетевом окружении недоступны компьютеры), хотя DNS на нем запущен и работает правильно, nslookup отрабатывает и на клиентских машинах, и на сервере. Еще на PDC стала валиться такая ошибка: http://www.eventid.net/display.asp?eventid=13568&eventno=1743&source=NtFrs&phase=1. ... |
| 23.12.2005, 02:36:33 |
Гость11 YanisВстречный глупый вопрос - а какие ДЦ есть в сети и какие мастера на каком ДЦ установлены? Опиши сеть плз в дополнение к первому вопросу! Posted via ActualForum NNTP Server 1.3 В сети два ДЦ. Расположены в двух разных точках города, соединены сетки через VPN. Мастера стоят все на PDC (по крайней мере, я никаких действий не предпринимал, чтобы переместить какой-то из пяти мастеров на BDC) (как определить, где какие мастера? как-то на этот вопрос я и внимания не обращал...). Когда VPN падает, 1) во второй подсетке где BDC начинаются проблемы (в сетевом окружении недоступны компьютеры) , хотя DNS на нем запущен и работает правильно, nslookup отрабатывает и на клиентских машинах, и на сервере. Еще на PDC стала валиться такая ошибка: http://www.eventid.net/display.asp?eventid=13568&eventno=1743&source=NtFrs&phase=1. Чегож ты, бедняга, хочешь? DC c недореплицированным SYSVOL - не может работать как DC => не может авторизовать клиентов и выдавать билетики. На нем (BDC) есть сообщение в логе "Служба репликации файлов": Код: plaintext 1. 2. 3. В общем повторюсь: В данном случае, т.е. когда PDC НЕ полностью работоспособен, приходится туго, НО проще всего, если есть возможность на время остановить домен : 0) BACKUP SystemState на обеих контроллерах. 1) Понизить BDC до сервера. 2) Обратно поднять до DC, подождать 15-45 мин и проверить, что все реплицировалось и работает. ----------------- иначе накатить BACKUP-ы обратно. И чесать репу дальше... ... |
| 23.12.2005, 07:01:16 |
авторкак определить, где какие мастера? как-то на этот вопрос я и внимания не обращал...). если ничего не трогал, то мастером всех операций является первый контроллер в домене. А посмотреть who is who можно здесь http://support.microsoft.com/kb/q197132/ Как их можно передать здесь http://support.microsoft.com/default.aspx?scid=kb;RU;324801#XSLTH3123121121120121120120 ... |
| 23.12.2005, 10:45:51 |
start [/forum/topic.php?fid=26&gotonew=1&tid=1511488]: |
47ms |
50ms |
| others: | 239ms |
| total: | 378ms |
