CACLS делает не все
Возникла потребность пакетником регулировать права на папку. С помощью CACLS нормально устанавливается N,R,W,F полномочия . Но если посмотреть в permissions вкладки security на папке, там ведь есть List Folders и другие , как можно их отрегулировать? Может еще есть какая команда? ... |
| 29.12.2005, 10:10:54 |
CACLS делает не все
Resource Kit 2000C:\WINDOWS\system32>xcacls /? Displays or modifies access control lists (ACLs) of files XCACLS filename [/T] [/E|/X] [/C] [/G user:perm;spec] [/R user [...]] [/P user:perm;spec [...]] [/D user [...]] [/Y] filename Displays ACLs. /T Changes ACLs of specified files in the current directory and all subdirectories. /E Edit ACL instead of replacing it. /X Same as /E except it only affects the ACEs that the specified users already own. /C Continue on access denied errors. /G user:perm;spec Grant specified user access rights. Perm can be: R Read C Change (write) F Full control P Change Permissions (Special access) O Take Ownership (Special access) X EXecute (Special access) E REad (Special access) W Write (Special access) D Delete (Special access) Spec can be the same as perm and will only be Press ENTER to continue... applied to a directory. In this case, Perm will be used for file inheritence in this directory. If not omitted: Spec=Perm. Special values for Spec only: T Not Specified (for file inherit, only for dirs valid) At least one access right has to follow! Entries between ';' and T will be ignored! /R user Revoke specified user's access rights. /P user:perm;spec Replace specified user's access rights. for access right specification see /G option /D user Deny specified user access. /Y Replace user's rights without verify Wildcards can be used to specify more that one file in a command. You can specify more than one user in a command. You can combine access rights. ... |
| 29.12.2005, 10:21:19 |
start [/forum/topic.php?fid=26&gotonew=1&tid=1511443]: |
31ms |
35ms |
| others: | 192ms |
| total: | 301ms |
