Не работает политика
Biz©dcdiag netdiag лечитесь, одним словом ... КАК??? dcdiagDomain Controller Diagnosis Performing initial setup: Done gathering initial info. Doing initial required tests Testing server: Default-First-Site-Name\[DC2] Starting test: Connectivity ......................... [DC2] passed test Connectivity Doing primary tests Testing server: Default-First-Site-Name\[DC2] Starting test: Replications ......................... [DC2] passed test Replications Starting test: NCSecDesc ......................... [DC2] passed test NCSecDesc Starting test: NetLogons ......................... [DC2] passed test NetLogons Starting test: Advertising ......................... [DC2] passed test Advertising Starting test: KnowsOfRoleHolders ......................... [DC2] passed test KnowsOfRoleHolders Starting test: RidManager ......................... [DC2] passed test RidManager Starting test: MachineAccount ......................... [DC2] passed test MachineAccount Starting test: Services ......................... [DC2] passed test Services Starting test: ObjectsReplicated ......................... [DC2] passed test ObjectsReplicated Starting test: frssysvol ......................... [DC2] passed test frssysvol Starting test: frsevent ......................... [DC2] passed test frsevent Starting test: kccevent ......................... [DC2] passed test kccevent Starting test: systemlog ......................... [DC2] passed test systemlog Starting test: VerifyReferences ......................... [DC2] passed test VerifyReferences Running partition tests on : Schema Starting test: CrossRefValidation ......................... Schema passed test CrossRefValidation Starting test: CheckSDRefDom ......................... Schema passed test CheckSDRefDom Running partition tests on : Configuration Starting test: CrossRefValidation ......................... Configuration passed test CrossRefValidation Starting test: CheckSDRefDom ......................... Configuration passed test CheckSDRefDom Running partition tests on : [DCNAME] Starting test: CrossRefValidation ......................... [DCNAME] passed test CrossRefValidation Starting test: CheckSDRefDom ......................... [DCNAME] passed test CheckSDRefDom Running enterprise tests on : [DCNAME].[bla-bla].ru Starting test: Intersite ......................... [DCNAME].[bla-bla].ru passed test Intersite Starting test: FsmoCheck ......................... [DCNAME].[bla-bla].ru passed test FsmoCheck ... |
| 27.10.2006, 09:30 |
netdiag Computer Name: [DCNAME] DNS Host Name: [DCNAME].[bla-bla].ru System info : Microsoft Windows Server 2003 (Build 3790) Processor : x86 Family 6 Model 1 Stepping 9, GenuineIntel List of installed hotfixes : Q147222 Netcard queries test . . . . . . . : Passed GetStats failed for '¦Ё ьющ ярЁрыыхы№эvщ яюЁЄ'. [ERROR_NOT_SUPPORTED] [WARNING] The net card '¦шэшяюЁЄ WAN (PPTP)' may not be working because it h as not received any packets. [WARNING] The net card '¦шэшяюЁЄ WAN (PPPoE)' may not be working because it has not received any packets. [WARNING] The net card '¦шэшяюЁЄ WAN (IP)' may not be working because it has not received any packets. GetStats failed for '¦шэшяюЁЄ WAN (L2TP)'. [ERROR_NOT_SUPPORTED] Per interface results: Adapter : ¦юфъы¦ўхэшх яю ыюъры№эющ ёхЄш Netcard queries test . . . : Passed Host Name. . . . . . . . . : [DCNAME] IP Address . . . . . . . . : ------------- Subnet Mask. . . . . . . . : 255.255.255.0 Default Gateway. . . . . . : ------------- Primary WINS Server. . . . : ------------- Dns Servers. . . . . . . . : ------------- AutoConfiguration results. . . . . . : Passed Default gateway test . . . : Passed NetBT name test. . . . . . : Passed [WARNING] At least one of the <00> 'WorkStation Service', <03> 'Messenge r Service', <20> 'WINS' names is missing. WINS service test. . . . . : Passed Global results: Domain membership test . . . . . . : Passed NetBT transports test. . . . . . . : Passed List of NetBt transports currently configured: NetBT_Tcpip_{4C98553F-46B6-4488-8600-82AE1695EDBB} 1 NetBt transport currently configured. Autonet address test . . . . . . . : Passed IP loopback ping test. . . . . . . : Passed Default gateway test . . . . . . . : Passed NetBT name test. . . . . . . . . . : Passed [WARNING] You don't have a single interface with the <00> 'WorkStation Servi ce', <03> 'Messenger Service', <20> 'WINS' names defined. Winsock test . . . . . . . . . . . : Passed DNS test . . . . . . . . . . . . . : Passed PASS - All the DNS entries for DC are registered on DNS server '192.168.130. 9' and other DCs also have some of the names registered. Redir and Browser test . . . . . . : Passed List of NetBt transports currently bound to the Redir NetBT_Tcpip_{4C98553F-46B6-4488-8600-82AE1695EDBB} The redir is bound to 1 NetBt transport. List of NetBt transports currently bound to the browser NetBT_Tcpip_{4C98553F-46B6-4488-8600-82AE1695EDBB} The browser is bound to 1 NetBt transport. DC discovery test. . . . . . . . . : Passed DC list test . . . . . . . . . . . : Passed Trust relationship test. . . . . . : Passed Secure channel for domain '[bla]' is to '\\[bla].[bla-bla].ru'. Kerberos test. . . . . . . . . . . : Passed LDAP test. . . . . . . . . . . . . : Passed Bindings test. . . . . . . . . . . : Passed WAN configuration test . . . . . . : Skipped No active remote access connections. Modem diagnostics test . . . . . . : Passed IP Security test . . . . . . . . . : Skipped Note: run "netsh ipsec dynamic show /?" for more detailed information The command completed successfully -------------------------------------------------------------- [подпись с другого сайта] ... |
| 27.10.2006, 09:40 |
В общем, выявил такую закономерность: если комп готовит сетевые подключения до момента логона, то политика отрабатывает, если нет, то и политика не работает, а в лог пошит ошибку Userenv. Мне удалось добиться каким-то образом такого эффекта на своем компе, когда система готовит эти подключения, но на "свежей" машине никак не получается добиться того, чтобы комп заранее готовил эти подключения, может кто-нибудь знает где это включать? Признателен за участие! -------------------------------------------------------------- [подпись с другого сайта] ... |
| 02.11.2006, 18:01 |
CerebrumМне удалось добиться каким-то образом такого эффекта на своем компе, когда система готовит эти подключения, но на "свежей" машине никак не получается добиться того, чтобы комп заранее готовил эти подключения вот ваше "каким-то образом" ... |
| 02.11.2006, 21:34 |
не помогло, gpupdate выполнял -------------------------------------------------------------- [подпись с другого сайта] ... |
| 03.11.2006, 08:20 |
Cerebrumне помогло, gpupdate выполнял имхо это ошибки разного характера ... гляньте на КД есть ли ошибки в то же время, относящиеся к данному клиенту ... |
| 03.11.2006, 09:08 |
на кд вообще нет записей с ошибками. редко предупреждения и информационные сообщения -------------------------------------------------------------- [подпись с другого сайта] ... |
| 03.11.2006, 09:17 |
Cerebrumна кд вообще нет записей с ошибками. редко предупреждения и информационные сообщения проблемы с сетевой картой исключаете ? ... |
| 03.11.2006, 09:29 |
start [/forum/topic.php?fid=26&gotonew=1&tid=1509079]: |
48ms |
40ms |
| others: | 263ms |
| total: | 396ms |
