Password for IE
Как можно удалить если забыл? ... |
| 11.11.2006, 21:29 |
Password for IE
Нашел. Гугл подсказал :) ... |
| 11.11.2006, 22:29 |
Password for IE
Может с нами поделитесь? ... |
| 11.11.2006, 22:35 |
Password for IE
How to Remove Content Advisor Password in Internet Explorer The following steps will remove any password set in the Internet Explorer Content Advisor and allow you to reset the program to its original state. 1) Click on Start and choose Run. 2) Type in RegEdit and select OK. 3) Now click on the little plus sign to the left of H_KEY_LOCAL_MACHINE. 4) Continue to drill down, always clicking on the plus sign at the left of the named key, through Software, Microsoft, Windows, Current Version and Policies. 5) Now click on the Ratings folder. 6) In the right pane of the RegEdit window, you'll see an icon called Key. Click on it and press Delete. 7) Next, choose Registry and then Exit to exit RegEdit. You've just deleted your original Content Advisor password. 8) Restart the computer and run Internet Explorer again. 9) Choose View and then Internet Options (or Options for version 3.x). For IE 5 or greater, Click on Tools, Internet Options. 10) Click on the Content tab and click on Disable. When asked for a password, don't enter anything; just click on OK. This will disable Content Advisor because there's no longer a password. Как то так наверное ... |
| 11.11.2006, 23:09 |
start [/forum/topic.php?fid=26&gotonew=1&tid=1508909]: |
190ms |
35ms |
| others: | 289ms |
| total: | 563ms |
