добавить сетевой принтер к Vista
Подскажите, как установить сетевой принтер под Vista? Ситуация- сетевой принтер под XP, с машины под Vista нужно печатать. Устанавливаю на машину с Vista клиент принтера с драйвером под Висту, и нифига. Или на машину к которой подключен принтер, т.е. на XP, нужно ставить новый клиент, поддерживающий Висту? ... |
| 07.04.2008, 11:50:55 |
Получилось: http://www.kevinyank.com/blog/archives/connect-to-a-network-printer-on-a-windows-xp-server-in-windows-vista Here are the exact steps that worked for me: Download the Windows Vista printer driver for the SCX-4216F multifunction printer from www.samsung.com. Install the driver on your Windows Vista computer. During installation, you’ll be prompted to connect the printer to your computer. Choose the option to proceed with installation without connecting the printer. After installation completes, open the Printers applet from the Windows Vista Control Panel. Right-click on the new Samsung SCX-4100 Series printer and choose Properties. Go to the Ports tab. Click Add Port…, select Local Port, then click New Port… For the port name, enter exactly the network path and share name of your printer (e.g. \\RECEPTION\Samsung SCX-4×16 Series). Click OK, and double-check that this new port is selected with the checkbox next to it. Click OK to close the printer properties. ... |
| 07.04.2008, 14:20:20 |
start [/forum/topic.php?fid=26&gotonew=1&tid=1504764]: |
52ms |
47ms |
| others: | 234ms |
| total: | 387ms |
