При удалении SQL Express на WinXP sp3 выдало синий экран stop:c000021A
Собственно сабж, попытался удалить sql, и выдало экран. ... |
| 17.05.2011, 14:27 |
domovoiСобственно сабж, попытался удалить sql, и выдало экран. когда уже люди научатся пользоваться гуглом? 0xC000021A: STATUS_SYSTEM_PROCESS_TERMINATED This occurs when Windows switches into kernel mode and a user-mode subsystem, such as Winlogon or the Client Server Runtime Subsystem (CSRSS), is compromised. Security can no longer be guaranteed. Because Win XP can’t run without Winlogon or CSRSS, this is one of the few situations where the failure of a user-mode service can cause the system to stop responding. This Stop message also can occur as a result of malware infestation or when the computer is restarted after a system administrator has modified permissions so that the SYSTEM account no longer has adequate permissions to access system files and folders. ... |
| 17.05.2011, 15:06 |
start [/forum/topic.php?fid=26&gotonew=1&tid=1498225]: |
173ms |
27ms |
| others: | 224ms |
| total: | 466ms |
