Отчет жесткого диска 320 ГБ SAMSUNG [ПОМОГИ]
0: Device State: Online 0: Device number: 0 0: Model: ST320LM000 HM321HI ST320LM000 HM321HI: DeviceInterfacePath: \\?\ide#diskst320lm000_hm321hi______________________2aj10002#4&2e140e6a&0&0.0.0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b} ST320LM000 HM321HI: Serial: S26VJ9AC415712 ST320LM000 HM321HI: Firmware: 2AJ10002 ST320LM000 HM321HI: Manufacturer: SEAGATE ST320LM000 HM321HI: Disk size: 320072933376 bytes ST320LM000 HM321HI: Power status: Unknown ST320LM000 HM321HI: Health status: Prefail ST320LM000 HM321HI: Temperature: 39 ST320LM000 HM321HI: Max. Temperature: 46 ST320LM000 HM321HI: Bus type: SATA ST320LM000 HM321HI:>ATA specific parameters: ST320LM000 HM321HI: Performance status: Prefail ST320LM000 HM321HI: AAM Supported ST320LM000 HM321HI: AAM Enabled ST320LM000 HM321HI: Current AAM: 128 ST320LM000 HM321HI: Recomended AAM: 254 ST320LM000 HM321HI: APM Supported ST320LM000 HM321HI: Current APM: 128 ST320LM000 HM321HI: Power On Hours: 6843 ST320LM000 HM321HI: Health: 0 ST320LM000 HM321HI: Performance: 99 ST320LM000 HM321HI: Attributes count: 22 ST320LM000 HM321HI: Attributes: ST320LM000 HM321HI: ------------------------------------------------- ST320LM000 HM321HI: ID Flags Thresh Value Worst Raw ST320LM000 HM321HI: ------------------------------------------------- ST320LM000 HM321HI: 01 002f 33 01 01 000000000003d1f2 ST320LM000 HM321HI: 02 0026 00 fc fc 0000000000000000 ST320LM000 HM321HI: 03 0023 19 59 58 0000000000000d4a ST320LM000 HM321HI: 04 0032 00 63 63 00000000000006c7 ST320LM000 HM321HI: 05 0033 0a 04 04 0000000000000f82 ST320LM000 HM321HI: 07 002e 33 fc fc 0000000000000000 ST320LM000 HM321HI: 08 0024 0f fc fc 0000000000000000 ST320LM000 HM321HI: 09 0032 00 64 64 0000000000001abb ST320LM000 HM321HI: 0a 0032 33 fc fc 0000000000000000 ST320LM000 HM321HI: 0b 0032 00 64 64 0000000000000175 ST320LM000 HM321HI: 0c 0032 00 63 63 000000000000052d ST320LM000 HM321HI: bf 0022 00 01 01 000000000020b982 ST320LM000 HM321HI: c0 0022 00 fc fc 0000000000000000 ST320LM000 HM321HI: c2 0002 00 3d 37 0000002e00100027 ST320LM000 HM321HI: c3 003a 00 64 64 0000000000000000 ST320LM000 HM321HI: c4 0032 00 04 04 0000000000000f82 ST320LM000 HM321HI: c5 0032 00 64 60 000000000000001c ST320LM000 HM321HI: c6 0030 00 fc fc 0000000000000000 ST320LM000 HM321HI: c7 0036 00 64 64 0000000000000003 ST320LM000 HM321HI: c8 002a 00 01 01 0000000000015c15 ST320LM000 HM321HI: df 0032 00 64 64 0000000000000175 ST320LM000 HM321HI: e1 0032 00 58 58 000000000001f87b ST320LM000 HM321HI: ------------------------------------------------- ... |
| 23.05.2014, 15:20 |
И ? ... |
| 23.05.2014, 15:56 |
Leonid KudryavtsevИ ? МайданST320LM000 HM321HI: Performance status: Prefail ... |
| 23.05.2014, 16:04 |
Видел... и что? ...пожертвовать автору 1 150 руб на новый диск желанием не горю ... |
| 23.05.2014, 16:25 |
Leonid KudryavtsevВидел... и что? ...пожертвовать автору 1 150 руб на новый диск желанием не горю Дак вроде счет не указан... Может сочувствия ищет? ... |
| 23.05.2014, 16:30 |
wadmanДак вроде счет не указан... Может сочувствия ищет? а лог от SMART'а зачем? Одного ника, что бы вызвать сочувствия достаточно ))) ... |
| 23.05.2014, 16:56 |
Leonid Kudryavtsev и Другие , Дорогие друзья ,я конешно все понимаю ,но HDD Regenerator поможет ? ... |
| 23.05.2014, 20:13 |
Поможет чем и в чем? Хочется на умирающем диске поиграться - играйся на здоровье. Кто может запретить? У меня тоже ЖД 40 Mb в первом компьютер работал с охлаждением в виде чугунной подставки из под утюга. Отдали на работе бесплатно, т.к. там такой был не нужен ))) ... |
| 23.05.2014, 20:18 |
Запустите для начала chkdsk /f /r и потом отпишите что получилось ... |
| 23.05.2014, 20:26 |
weber, тролля содой напоить зачем chkdsk /f /r 0 заблокировать диск ? ... |
| 23.05.2014, 21:02 |
МайданLeonid Kudryavtsev и Другие , Дорогие друзья ,я конешно все понимаю ,но HDD Regenerator поможет ?Если ты его купил, зачем спрашиваешь? Или ты продолжаешь свою же тему http://www.sql.ru/forum/1095105/primary-master-st320lm000-hm321hi-press-f1-to-resume-pri-starte-komputera?hl= ? Так там уже всё сказали ... |
| 23.05.2014, 21:04 |
Майданweber, тролля содой напоить зачем chkdsk /f /r 0 заблокировать диск ? Шо значит заблокировать. Он блокируется на время необходимое для проведения операции по исправлению ошибок. Я блин свой сервак так лечил ночью когда один из раид дисков начал давать сбои. Ночью вылечил а диск потом бежал как надо. Потом его заменил для уверенности но сейчас пашет в домашнем компе уже 6 месяц и нифига без проблем. ... |
| 23.05.2014, 21:44 |
А притом забыл добавить што лечил через Remote Desctop ну и после рестарта сервака всё набежало как надо а то не набегал вообще зависал мёртво. ... |
| 23.05.2014, 21:54 |
weberМайданweber, тролля содой напоить зачем chkdsk /f /r 0 заблокировать диск ? Шо значит заблокировать. Он блокируется на время необходимое для проведения операции по исправлению ошибок. Я блин свой сервак так лечил ночью когда один из раид дисков начал давать сбои. Ночью вылечил а диск потом бежал как надо. Потом его заменил для уверенности но сейчас пашет в домашнем компе уже 6 месяц и нифига без проблем. В раиде диске часто не выходят из строя а деградируют, а это дело поправимое ... |
| 23.05.2014, 22:12 |
Анатолий - во первых привет, давно я сюды не заходил. Во вторых мне абсолютно было по-боку деградирует или выходит но 17 секторов ушло в туман но данные остались . 6 Часов длилась операция , я уж думал что утром меня клиенты загребут , но как раз всё прошло на ура а то был готов уже лететь 150 км менять диск . ... |
| 23.05.2014, 22:24 |
start [/forum/topic.php?fid=26&gotonew=1&tid=1494695]: |
73ms |
69ms |
| others: | 244ms |
| total: | 448ms |
