нужно помощь!!!!что надо сделать?
Checking file system on C: The type of the file system is NTFS. Volume label is eMachines. One of your disks needs to be checked for consistency. You may cancel the disk check, but it is strongly recommended that you continue. Windows will now check the disk. CHKDSK is verifying files (stage 1 of 3)... 0 percent complete. (0 of 151808 file records processed) ... |
| 02.12.2014, 20:05 |
start [/forum/topic.php?fid=26&gotonew=1&tid=1494337]: |
397ms |
| others: | 248ms |
| total: | 696ms |
