pptp+FreeBSD (autostart)
Привет всем У меня проблема с автозапуском pptp. (FreeBSD 5.2) Когда система запущена то ётот клиент запускаю pptp 192.168.1.1 vpn & и все работает ! (192,168,1,1 - адрес сервера) Но когда я прописываю в rc.local pptp 192.168.1.1 vpn & sleep 15 ------------- то он не поднимается.., и после такого запуска системы сервер 192,168,1,1 с етой машыны даже не пингуется... :-( только после перегрузки сервера... вот фрагмент лог-файла (ppp.log на клиенте) Apr 26 17:52:25 ppp[658]: Phase: Using interface: tun0 Apr 26 17:52:25 ppp[658]: Phase: deflink: Created in closed state Apr 26 17:52:25 ppp[658]: Phase: PPP Started (direct mode). Apr 26 17:52:25 ppp[658]: Phase: bundle: Establish Apr 26 17:52:25 ppp[658]: Phase: deflink: closed -> opening Apr 26 17:52:25 ppp[658]: Phase: deflink: Connected! Apr 26 17:52:25 ppp[658]: Phase: deflink: opening -> carrier Apr 26 17:52:25 ppp[658]: Phase: deflink: carrier -> lcp Apr 26 17:52:31 ppp[658]: Phase: bundle: Authenticate Apr 26 17:52:31 ppp[658]: Phase: deflink: his = none, mine = CHAP 0x81 Apr 26 17:52:31 ppp[658]: Phase: Chap Output: CHALLENGE Apr 26 17:52:31 ppp[658]: Phase: Chap Input: RESPONSE (49 bytes from pidgaytsy) Apr 26 17:52:31 ppp[658]: Phase: Chap Output: SUCCESS Apr 26 17:52:31 ppp[658]: Phase: deflink: lcp -> open Apr 26 17:52:31 ppp[658]: Phase: bundle: Network Apr 26 17:52:42 ppp[658]: Phase: deflink: read (0): Got zero bytes Apr 26 17:52:42 ppp[658]: Phase: deflink: open -> lcp Apr 26 17:52:42 ppp[658]: Phase: bundle: Terminate Apr 26 17:52:42 ppp[658]: Phase: deflink: Disconnected! Apr 26 17:52:42 ppp[658]: Phase: deflink: Connect time: 17 secs: 1191 octets in, 861 octets out Apr 26 17:52:42 ppp[658]: Phase: deflink: 13 packets in, 21 packets out Apr 26 17:52:42 ppp[658]: Phase: total 120 bytes/sec, peak 382 bytes/sec on Mon Apr 26 17:52:32 2004 Apr 26 17:52:42 ppp[658]: Phase: deflink: lcp -> closed Apr 26 17:52:42 ppp[658]: Phase: bundle: Dead Apr 26 17:52:42 ppp[658]: Phase: PPP Terminated (normal). В чем может быть причина ??? :-( Заранее спасибо ! ... |
| 26.04.2004, 20:00 |
start [/forum/topic.php?fid=25&gotonew=1&tid=1491560]: |
37ms |
35ms |
| others: | 195ms |
| total: | 306ms |
