Ой что это ?
Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. кто знает что до меня хочет донести система ? ... |
| 21.09.2004, 09:40:45 |
Ой что это ?
13.5. What is this UID 0 toor account? Have I been compromised? Do not worry. toor is an ``alternative'' superuser account (toor is root spelt backwards). Previously it was created when the bash(1) shell (не твой случай?) was installed but now it is created by default. It is intended to be used with a non-standard shell so you do not have to change root's default shell. This is important as shells which are not part of the base distribution (for example a shell installed from ports or packages) are likely to be installed in /usr/local/bin which, by default, resides on a different filesystem. If root's shell is located in /usr/local/bin and /usr (or whatever filesystem contains /usr/local/bin) is not mounted for some reason, root will not be able to log in to fix a problem (although if you reboot into single user mode you will be prompted for the path to a shell). Some people use toor for day-to-day root tasks with a non-standard shell, leaving root, with a standard shell, for single user mode or emergencies. By default you cannot log in using toor as it does not have a password, so log in as root and set a password for toor if you want to use it. ===== Cat и его покойный друг Chicago ... |
| 21.09.2004, 10:08:55 |
Ой что это ?
я вот про это Код: plaintext 1. 2. ... |
| 21.09.2004, 10:37:48 |
start [/forum/topic.php?fid=25&gotonew=1&tid=1491315]: |
186ms |
57ms |
| others: | 222ms |
| total: | 528ms |
