настройка squid
Fedora Core 3 Squid Cache (Version 2.5.STABLE6) PIII-933 ОЗУ 128 1. Скорость по сравнению с WinRoute на порядок ниже (стд google грузиться 1-2 сек (WinRoute) и до 20-ти сек (Squid)) Попробовал поиграться с cache_mem (вместо default'овых 8-ми): при увеличении - скорость наоботот падает Ж8-/ или вообще не отдупляется (если уж сильно большое значение выставить). cache.log 2005/03/16 13:44:36| Starting Squid Cache version 2.5.STABLE6 for i386-redhat-linux-gnu... 2005/03/16 13:44:36| Process ID 3581 2005/03/16 13:44:36| With 1024 file descriptors available 2005/03/16 13:44:36| DNS Socket created at 0.0.0.0, port 1102, FD 4 2005/03/16 13:44:36| User-Agent logging is disabled. 2005/03/16 13:44:36| Referer logging is disabled. 2005/03/16 13:44:36| Unlinkd pipe opened on FD 9 2005/03/16 13:44:36| Swap maxSize 2097152 KB, estimated 161319 objects 2005/03/16 13:44:36| Target number of buckets: 8065 2005/03/16 13:44:36| Using 8192 Store buckets 2005/03/16 13:44:36| Max Mem size: 10240 KB 2005/03/16 13:44:36| Max Swap size: 2097152 KB 2005/03/16 13:44:36| Rebuilding storage in /var/spool/squid (CLEAN) 2005/03/16 13:44:36| Using Least Load store dir selection 2005/03/16 13:44:36| Set Current Directory to /var/spool/squid 2005/03/16 13:44:36| Loaded Icons. 2005/03/16 13:45:04| Accepting HTTP connections at 192.168.0.7, port 3128, FD 11. 2005/03/16 13:45:04| Accepting ICP messages at 0.0.0.0, port 3130, FD 12. 2005/03/16 13:45:04| WCCP Disabled. 2005/03/16 13:45:04| Ready to serve requests. 2005/03/16 13:45:04| Done reading /var/spool/squid swaplog (294 entries) 2005/03/16 13:45:04| Finished rebuilding storage from disk. 2005/03/16 13:45:04| 294 Entries scanned 2005/03/16 13:45:04| 0 Invalid entries. 2005/03/16 13:45:04| 0 With invalid flags. 2005/03/16 13:45:04| 294 Objects loaded. 2005/03/16 13:45:04| 0 Objects expired. 2005/03/16 13:45:04| 0 Objects cancelled. 2005/03/16 13:45:04| 0 Duplicate URLs purged. 2005/03/16 13:45:04| 0 Swapfile clashes avoided. 2005/03/16 13:45:04| Took 28.5 seconds ( 10.3 objects/sec). 2005/03/16 13:45:04| Beginning Validation Procedure 2005/03/16 13:45:04| Completed Validation Procedure 2005/03/16 13:45:04| Validated 294 Entries 2005/03/16 13:45:04| store_swap_size = 2468k 2005/03/16 13:45:06| storeLateRelease: released 0 objects 2005/03/16 13:48:20| Preparing for shutdown after 0 requests 2005/03/16 13:48:20| Waiting 30 seconds for active connections to finish 2005/03/16 13:48:20| FD 11 Closing HTTP connection 2005/03/16 13:48:20| Shutting down... 2005/03/16 13:48:20| FD 12 Closing ICP connection 2005/03/16 13:48:20| Closing unlinkd pipe on FD 9 2005/03/16 13:48:20| storeDirWriteCleanLogs: Starting... 2005/03/16 13:48:20| Finished. Wrote 294 entries. 2005/03/16 13:48:20| Took 0.0 seconds (274253.7 entries/sec). CPU Usage: 0.068 seconds = 0.033 user + 0.035 sys Maximum Resident Size: 0 KB Page faults with physical i/o: 0 Memory usage for squid via mallinfo(): total space in arena: 2112 KB Ordinary blocks: 2032 KB 3 blks Small blocks: 0 KB 5 blks Holding blocks: 200 KB 1 blks Free Small blocks: 0 KB Free Ordinary blocks: 79 KB Total in use: 2232 KB 106% Total free: 79 KB 4% 2005/03/16 13:48:20| Squid Cache (Version 2.5.STABLE6): Exiting normally. TOP показывает загрузку CPU до ~3-4% Кроме Squid'а и стд демонов еще поднята Samba. Что можно покрутить-подкрутить, что бы забегало пошустрее? 2. acl BlockSitesByName dstdomain "/etc/squid/sites_by_name" кушает, а, вот, на acl BlockURLByRegEx urlpath_regex "/etc/squid/url_by_regex" squid.out 2005/03/16 13:54:00| aclParseAclLine: IGNORING invalid ACL: acl BlockURLByRegEx urlpath_regex "/etc/squid/url_by_regex" 2005/03/16 13:54:00| squid.conf line 1879: http_access deny all BlockURLByRegEx 2005/03/16 13:54:00| aclParseAccessLine: ACL name 'BlockURLByRegEx' not found. 2005/03/16 13:54:32| aclParseAclLine: IGNORING invalid ACL: acl BlockURLByRegEx urlpath_regex "/etc/squid/url_by_regex" 2005/03/16 13:54:32| squid.conf line 1879: http_access deny all BlockURLByRegEx 2005/03/16 13:54:32| aclParseAccessLine: ACL name 'BlockURLByRegEx' not found. а почему? тем более, что во всех хельпах-букварях в urlpath_regex указываются файлы, 4 example http://www.softportal.com/printarticles/244 Отказ от рекламы Вставьте эти строки в свой /usr/local/etc/squid/squid.conf: acl good_url url_regex "/usr/local/etc/squid/acl/good_url" acl bad_urlpath urlpath_regex "/usr/local/etc/squid/acl/bad_urlpath" acl bad_url url_regex "/usr/local/etc/squid/acl/bad_url" http_access deny bad_urlpath !good_url http_access deny bad_url !good_url P.S. Для общего развития ;) : как подmount'ить vfat, что бы русские буковки в наименованиях файлов показывало? (iocharset=koi8-r,codepage=866 - не помогло). TIA _________________ "Helo, word!" - 17 errors 56 warnings ... |
| 16.03.2005, 19:28:28 |
настройка squid
squid.conf покажи? ... |
| 16.03.2005, 21:35:26 |
настройка squid
У меня на Cel1200 128 ОЗУ скуид начал грузить систему на 2-4% ТОЛЬКО после того как настроил ограничение скорости пользователям. До этого его не было ни видно ни слышно. (Видно правда было, памяти 30 Мег кушал:)) ... |
| 16.03.2005, 21:37:42 |
настройка squid
lissyara squid.conf покажи? Та настройки практически default'овые... Во че менял: squid.conf ... cache_mem 10 MB ... cache_swap_low 93 cache_swap_high 97 ... maximum_object_size 8192 KB ... cache_dir ufs /var/spool/squid 2048 16 256 ... acl Admins src "/etc/squid/users.admin" acl LocalNet src 192.168.0.0/24 acl BlockSitesByName dstdomain "/etc/squid/sites_by_name" #acl BlockSitesByRegEx dstdom_regex "/etc/squid/sites_by_regex" #acl BlockURLByRegEx urlpath_regex "/etc/squid/url_by_regex" ... http_access deny all BlockSitesByName #http_access deny all BlockSitesByRegEx #http_access deny all BlockURLByRegEx http_access allow localhost http_access allow LocalNet ... delay_pools 1 delay_class 1 2 delay_parameters 1 -1/-1 10000/100000 delay_access 1 deny Admins delay_access 1 allow LocalNet delay_access 1 deny all lissyara скуид начал грузить систему на 2-4% ТОЛЬКО после того как настроил ограничение скорости пользователям забалабенил аналогично ;) lissyara До этого его не было ни видно ни слышно. меня загрузка системы - мало волнует. хай хоть по самые помидоры будет загружена - маша специяльно выделена под проксю. Вопрос почему так медленно? А что по поводу п.2. && P.S.? _________________ "Helo, word!" - 17 errors 56 warnings ... |
| 17.03.2005, 12:38:42 |
настройка squid
с п.2. - разобрался ;) Оказывается, squid, не любит когда файл, указанный в urlpath_regex, пустой... Зато поимел ;) другой вопрос: какой сложности регулярные выражения обрабатывает squid? Код: plaintext 1. режет тока /ad. а остальные - пропускает :( на характер проверил perl'ом: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. выкусывает из: aaa/ad.ru aaa/ad1.ru aaa/ad11.ru aaa/dd.ru aaa/dd1.ru aaa/dd11.ru aaa/adc.ru aaa/ad1c.ru aaa/ad11c.ru aaa.ad.ru aaa.ad1.ru aaa.ad11.ru aaa.dd.ru aaa.dd1.ru aaa.dd11.ru aaa.adc.ru aaa.ad1c.ru aaa.ad11c.ru тока aaa/ad.ru aaa/ad1.ru aaa/ad11.ru так, что все, вроде, честно... а где тогда рыть?.. Да... Таки ткните носом, pls, или подскажите: как, все-таки, подmount'ить vfat, что бы русские буковки в наименованиях файлов показывало? (рыл, искал, нашел: iocharset=koi8-r,codepage=866 - не помогло :( ). Бо шо в X-сах, шо в mc одни знаки вопроса Ж8-/... _________________ "Helo, word!" - 17 errors 56 warnings ... |
| 23.03.2005, 00:26:06 |
настройка squid
Ex_Soft/ad\d*\. Поскольку \d == [0-9] заменил /ad\d*\. -> /ad[0-9]*\. и все зафунциклировало Осталось тока P.S. Ex_Softкак, все-таки, подmount'ить vfat, что бы русские буковки в наименованиях файлов показывало?забороть и топик можна считать закрытым _________________ "Helo, word!" - 17 errors 56 warnings ... |
| 17.04.2005, 09:38:55 |
start [/forum/topic.php?fid=25&gotonew=1&tid=1490730]: |
164ms |
39ms |
| others: | 214ms |
| total: | 463ms |
