Procedure Error
Hi everybody If you can Colud you explain to me what does this error mean in SQL*Plus First I created procedure in PL/SQL Developer create or replace procedure change_salary(v_emp_id in number, v_new_salary in number) is begin update s_emp set salary = v_new_salary where id = v_emp_id; commit; end change_salary; It gave the message: Compiled successfully Then in SQL*Plus, I tried the next: SQL> exec change_salary; begin change_salary; end; ORA-06550: line 1, column 7: PLS-00306: wrong number or types of arguments in call to 'CHANGE_SALARY' ORA-06550: line 1, column 7: PL/SQL: Statement ignored SQL> ... |
| 24.05.2005, 15:53:25 |
start [/forum/topic.php?fid=25&gotonew=1&tid=1490609]: |
182ms |
51ms |
| others: | 199ms |
| total: | 484ms |
