POP3
Помогите. Не могу понять. Настроил qpopper на RetHat4EL (2.6.9) Проблема получить почту telnet 192.168.1.1 110 - на самом линухе работает, а удаленно нет причем telnet 192.168.1.1 25 - порт работает и локально и удаленно. hosts.allow и hosts.deny - пустые ... |
| 15.06.2005, 13:30:32 |
POP3
Chain INPUT (policy ACCEPT) target prot opt source destination RH-Firewall-1-INPUT all -- anywhere anywhere Chain FORWARD (policy ACCEPT) target prot opt source destination RH-Firewall-1-INPUT all -- anywhere anywhere Chain OUTPUT (policy ACCEPT) target prot opt source destination Chain RH-Firewall-1-INPUT (2 references) target prot opt source destination ACCEPT all -- anywhere anywhere ACCEPT icmp -- anywhere anywhere icmp any ACCEPT ipv6-crypt-- anywhere anywhere ACCEPT ipv6-auth-- anywhere anywhere ACCEPT udp -- anywhere 224.0.0.251 udp dpt:5353 ACCEPT udp -- anywhere anywhere udp dpt:ipp ACCEPT all -- anywhere anywhere state RELATED,ESTABLISHED ACCEPT tcp -- anywhere anywhere state NEW tcp dpt:ssh ACCEPT tcp -- anywhere anywhere state NEW tcp dpt:http ACCEPT tcp -- anywhere anywhere state NEW tcp dpt:smtp REJECT all -- anywhere anywhere reject-with icmp-host-prohibited ... |
| 15.06.2005, 14:25:23 |
start [/forum/topic.php?fid=25&gotonew=1&tid=1490543]: |
29ms |
39ms |
| others: | 239ms |
| total: | 348ms |
