Форумы / Unix-системы [игнор отключен] [закрыт для гостей] / Трабл со сборкой ПХП 5.0.5
    #33458276
Sarin
make ругается на ошибки.
Их там дофига. Вот кусочек:
Код: plaintext
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
49.
50.
51.
/usr/include/libxml2/libxml/relaxng.h: 140 : error: syntax error before "ctxt"
/usr/include/libxml2/libxml/relaxng.h: 145 : error: syntax error before "ctxt"
/usr/include/libxml2/libxml/relaxng.h: 152 : error: syntax error before "ctxt"
/usr/include/libxml2/libxml/relaxng.h: 154 : error: syntax error before "ctxt"
/usr/include/libxml2/libxml/relaxng.h: 162 : error: syntax error before "ctxt"
/usr/include/libxml2/libxml/relaxng.h: 166 : error: syntax error before "ctxt"
/usr/include/libxml2/libxml/relaxng.h: 170 : error: syntax error before "ctxt"
/usr/include/libxml2/libxml/relaxng.h: 174 : error: syntax error before "ctxt"
In file included from /home/php5/php- 5 . 0 . 5 /ext/libxml/libxml.c: 47 :
/home/php5/php- 5 . 0 . 5 /ext/libxml/php_libxml.h: 26 : error: storage class specified for parameter `zend_module_entry'
/home/php5/php-5.0.5/ext/libxml/php_libxml.h:26: error: syntax error before "libxml_module_entry"
In file included from /home/php5/php-5.0.5/ext/libxml/libxml.c:47:
/home/php5/php-5.0.5/ext/libxml/php_libxml.h:35:40: ext/standard/php_smart_str.h: No such file or directory
/home/php5/php-5.0.5/ext/libxml/php_libxml.h:39: error: syntax error before "zval"
/home/php5/php-5.0.5/ext/libxml/php_libxml.h:39: warning: no semicolon at end of struct or union
/home/php5/php-5.0.5/ext/libxml/php_libxml.h:47: warning: structure defined inside parms
/home/php5/php-5.0.5/ext/libxml/php_libxml.h:47: error: storage class specified for parameter `php_libxml_ref_obj'
/home/php5/php- 5 . 0 . 5 /ext/libxml/php_libxml.h: 50 : error: syntax error before "xmlNodePtr"
/home/php5/php- 5 . 0 . 5 /ext/libxml/php_libxml.h: 50 : warning: no semicolon at end of struct or union
/home/php5/php- 5 . 0 . 5 /ext/libxml/php_libxml.h: 51 : error: redeclaration of `refcount'
/home/php5/php-5.0.5/main/streams/php_stream_filter_api.h:55: error: `refcount' previously declared here
/home/php5/php- 5 . 0 . 5 /ext/libxml/php_libxml.h: 52 : error: redeclaration of `_private'
/usr/include/libxml2/libxml/parser.h:735: error: `_private' previously declared here
/home/php5/php- 5 . 0 . 5 /ext/libxml/php_libxml.h: 53 : error: syntax error before '}' token
/home/php5/php- 5 . 0 . 5 /ext/libxml/php_libxml.h: 56 : error: syntax error before "zend_object"
/home/php5/php- 5 . 0 . 5 /ext/libxml/php_libxml.h: 56 : warning: no semicolon at end of struct or union
/home/php5/php- 5 . 0 . 5 /ext/libxml/php_libxml.h: 62 : error: syntax error before '*' token
/home/php5/php- 5 . 0 . 5 /ext/libxml/php_libxml.h: 62 : error: storage class specified for parameter `php_libxml_export_node'
/home/php5/php-5.0.5/ext/libxml/php_libxml.h:66: error: syntax error before '*' token
/home/php5/php-5.0.5/ext/libxml/php_libxml.h:67: error: syntax error before '*' token
/home/php5/php-5.0.5/ext/libxml/php_libxml.h:68: error: syntax error before '*' token
/home/php5/php-5.0.5/ext/libxml/php_libxml.h:69: error: syntax error before '*' token
/home/php5/php-5.0.5/ext/libxml/php_libxml.h:71: error: syntax error before '*' token
/home/php5/php-5.0.5/ext/libxml/php_libxml.h:73: error: syntax error before "node"
/home/php5/php-5.0.5/ext/libxml/php_libxml.h:75: error: syntax error before '*' token
/home/php5/php-5.0.5/ext/libxml/php_libxml.h:80: error: syntax error before "zval"
/home/php5/php-5.0.5/ext/libxml/libxml.c:54: error: parameter `_php_libxml_initialized' is initialized
/home/php5/php- 5 . 0 . 5 /ext/libxml/libxml.c: 57 : error: syntax error before "php_libxml_export_node"
/home/php5/php- 5 . 0 . 5 /ext/libxml/libxml.c: 57 : warning: no semicolon at end of struct or union
/home/php5/php- 5 . 0 . 5 /ext/libxml/libxml.c: 60 : error: storage class specified for parameter `HashTable'
/home/php5/php-5.0.5/ext/libxml/libxml.c:60: error: syntax error before "php_libxml_exports"
/home/php5/php-5.0.5/ext/libxml/libxml.c:108: error: syntax error before '*' token
/home/php5/php-5.0.5/ext/libxml/libxml.c:109: error: storage class specified for parameter `php_libxml_dec_node'
/home/php5/php- 5 . 0 . 5 /ext/libxml/libxml.c: 249 : error: syntax error before ';' token
/home/php5/php- 5 . 0 . 5 /ext/libxml/libxml.c: 267 : error: parameter `path_to_open' is initialized
/home/php5/php-5.0.5/ext/libxml/libxml.c:268: error: parameter `ret_val' is initialized
/home/php5/php- 5 . 0 . 5 /ext/libxml/libxml.c: 270 : error: syntax error before ';' token
/home/php5/php- 5 . 0 . 5 /ext/libxml/libxml.c: 346 : error: parameter `output' is initialized
/home/php5/php-5.0.5/ext/libxml/libxml.c:348: error: syntax error before ';' token
/home/php5/php- 5 . 0 . 5 /ext/libxml/libxml.c: 527 : error: syntax error before "for"
make: *** [ext/libxml/libxml.lo] Error  1
    #33458297
BlackStar
опции configure в студию
There Ain't No Such Thing As A Free Lunch
    #33458301
BlackStar
и почему 5.0.5? вон же 5.1.1 лежит.
    #33458344
Sarin
./ --with-apxs
и всё.
Пойду последнюю качать. Может поможет.
    #33465081
Sarin
Тож ошибка лезет:
Код: plaintext
1.
2.
3.
4.
i586-alt-linux-gcc: Zend/zend_language_parser.c: No such file or directory
i586-alt-linux-gcc: no input files
make: *** [Zend/zend_language_parser.lo] Error  1
[sarin@sarin php5. 1 . 1 ]$
Я понимаю, что он файл не нашёл. Но как это вылечить?
