rpm. удаление пакетов.
так получилось, что в базе rpm следующее: rpm -qa | grep openoffice openoffice.org-core07-2.0.0-3 openoffice.org-graphicfilter-2.0.0-3 openoffice.org-core06-2.0.1-1 openoffice.org-gnome-integration-2.0.1-1 openoffice.org-core04-2.0.0-3 openoffice.org-math-2.0.0-3 openoffice.org-core03-2.0.1-1 openoffice.org-javafilter-2.0.1-1 openoffice.org-core04u-2.0.0-3 openoffice.org-core04u-2.0.1-1 openoffice.org-core10-2.0.0-3 openoffice.org-core10-2.0.1-1 openoffice.org-core03-2.0.0-3 openoffice.org-core09-2.0.0-3 openoffice.org-pyuno-2.0.0-3 openoffice.org-core01-2.0.1-1 openoffice.org-core09-2.0.1-1 openoffice.org-math-2.0.1-1 openoffice.org-libs-1.1.1-4 openoffice.org-core08-2.0.0-3 openoffice.org-calc-2.0.0-3 openoffice.org-gnome-integration-2.0.0-3 openoffice.org-writer-2.0.0-3 openoffice.org-core07-2.0.1-1 openoffice.org-calc-2.0.1-1 openoffice.org-emailmerge-2.0.1-1 openoffice.org-writer-2.0.1-1 openoffice.org-1.1.1-4 openoffice.org-base-2.0.0-3 openoffice.org-draw-2.0.0-3 openoffice.org-testtool-2.0.0-3 openoffice.org-core08-2.0.1-1 openoffice.org-base-2.0.1-1 openoffice.org-draw-2.0.1-1 openoffice.org-testtool-2.0.1-1 openoffice.org-i18n-1.1.1-4 openoffice.org-core06-2.0.0-3 openoffice.org-core03u-2.0.0-3 openoffice.org-impress-2.0.0-3 openoffice.org-core03u-2.0.1-1 openoffice.org-graphicfilter-2.0.1-1 openoffice.org-core02-2.0.0-3 openoffice.org-xsltfilter-2.0.0-3 openoffice.org-core05u-2.0.0-3 openoffice.org-core05-2.0.0-3 openoffice.org-javafilter-2.0.0-3 openoffice.org-core01-2.0.0-3 openoffice.org-spellcheck-2.0.0-3 можно это все удалить одной командой как-нибудь? а то по одному пакету удалять устану. ... |
| 13.02.2006, 10:50:34 |
rpm -e `rpm -qa | grep openoffice` ? ... |
| 13.02.2006, 10:56:05 |
start [/forum/topic.php?fid=25&gotonew=1&tid=1489787]: |
72ms |
33ms |
| others: | 233ms |
| total: | 385ms |
