windows linux проблемы с сетью
Добрый денек! Вот в чем проблема: 2 машины в сети (win, madnrake): -линукс пингует нормально; -винда не пингует; поставил самбу smb.conf: [global] workgroup = WORKGROUP server string = Samba Server %v load printers = no log file = /var/log/samba/log.%m max log size = 500 log level = 3 encrypt passwords = yes smb passwd file = /etc/samba/smbpasswd username map = /etc/samba/smbusers socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192 local master = yes preferred master = yes wins support = yes dos charset = 866 unix charset = KOI8-R display charset = KOI8-R #============================ Share Definitions ============================== [server] #Uncomment line below to enable Dr.Web protection! # vfs object = smb_spider comment = SERVER path = /home/dmitry/server browseable = yes writable = yes guest ok = yes create mode = 0777 browseable = yes write list = @adm root inherit permissions = yes read only = no public = yes valid users = dmitry bulat printable = no когда запускаю "демонов" - сеть пропадает! Что не так! ... |
| 03.03.2006, 16:21:36 |
start [/forum/topic.php?fid=25&gotonew=1&tid=1489722]: |
56ms |
35ms |
| others: | 220ms |
| total: | 365ms |
