Попытка подбора пароля или?
Заглянул в почту root и вижу такую фишку. Чтобы это могло быть? Список довольно большой, поэтому привожу только начало. --------------------- SSHD Begin ------------------------ Failed logins from these: 1/password from ::ffff:66.221.168.72: 1 Time(s) a/password from ::ffff:66.221.168.72: 2 Time(s) a1/password from ::ffff:63.210.138.7: 1 Time(s) a2/password from ::ffff:63.210.138.7: 1 Time(s) a3/password from ::ffff:63.210.138.7: 1 Time(s) aa/password from ::ffff:63.210.138.7: 2 Time(s) aaa/password from ::ffff:63.210.138.7: 2 Time(s) aaron/password from ::ffff:161.53.50.60: 1 Time(s) aaron/password from ::ffff:66.221.168.72: 1 Time(s) abbey/password from ::ffff:161.53.50.60: 1 Time(s) abc/password from ::ffff:63.210.138.7: 2 Time(s) abcd/password from ::ffff:63.210.138.7: 1 Time(s) abdul/password from ::ffff:66.221.168.72: 1 Time(s) abigale/password from ::ffff:66.221.168.72: 1 Time(s) и т.д. ... |
| 28.02.2006, 22:37:08 |
Робот по подбору. Говорили детям - дети, ВСЕГДА меняйте порт 22 на что нибудь еще, если ваш сервер виден из интернета. А то его роботы замучают. orawebЗаглянул в почту root и вижу такую фишку. Чтобы это могло быть? Список довольно большой, поэтому привожу только начало. --------------------- SSHD Begin ------------------------ Failed logins from these: 1/password from ::ffff:66.221.168.72: 1 Time(s) a/password from ::ffff:66.221.168.72: 2 Time(s) a1/password from ::ffff:63.210.138.7: 1 Time(s) a2/password from ::ffff:63.210.138.7: 1 Time(s) a3/password from ::ffff:63.210.138.7: 1 Time(s) aa/password from ::ffff:63.210.138.7: 2 Time(s) aaa/password from ::ffff:63.210.138.7: 2 Time(s) aaron/password from ::ffff:161.53.50.60: 1 Time(s) aaron/password from ::ffff:66.221.168.72: 1 Time(s) abbey/password from ::ffff:161.53.50.60: 1 Time(s) abc/password from ::ffff:63.210.138.7: 2 Time(s) abcd/password from ::ffff:63.210.138.7: 1 Time(s) abdul/password from ::ffff:66.221.168.72: 1 Time(s) abigale/password from ::ffff:66.221.168.72: 1 Time(s) и т.д. ... |
| 28.02.2006, 22:44:50 |
Мне такую сказку в детстве не рассказывали. :) Да, роботы пострашнее волка будут. Благодарствую. ... |
| 28.02.2006, 23:05:00 |
проще скрипт в 10 строк - скокато неверных попыток - правило в фаер для хоста. Posted via ActualForum NNTP Server 1.3 ... |
| 01.03.2006, 09:08:25 |
авторГоворили детям - дети, ВСЕГДА меняйте порт 22 на что нибудь еще, если ваш сервер виден из интернета. А то его роботы замучают. и что это изменит? Если хакер не лох, то для начала он тебя просканирует nmap, например, и толку от того, что ты поменяешь порт? ... |
| 01.03.2006, 10:02:26 |
ALex_hha авторГоворили детям - дети, ВСЕГДА меняйте порт 22 на что нибудь еще, если ваш сервер виден из интернета. А то его роботы замучают. и что это изменит? Если хакер не лох, то для начала он тебя просканирует nmap, например, и толку от того, что ты поменяешь порт? ...НЕ ЛОХИ брут фост пользуют в крайнем случае... ... |
| 01.03.2006, 10:10:50 |
Короче, настроил прослушку SSH на eth1 (внутренняя сеть) и "наша граница на замке". Писать правила в фаер к сожалению пока не созрел. ... |
| 01.03.2006, 12:30:39 |
ну если он снаружи и не нужен, то всегда надо убирать. И не только ssh, а любые сервисы. ... |
| 01.03.2006, 13:34:03 |
ALex_hhaну если он снаружи и не нужен, то всегда надо убирать. И не только ssh, а любые сервисы. Кстати, можно настроить FTP сервер (в частности vsftpd), так чтобы он прослушивал только внутреннюю сеть. Т.е. на серваке две сетевухи, одна смотрит в инет, другая на вн. сеть, соответственно, конект разрешен только к внутр. ... |
| 02.03.2006, 02:51:27 |
Если это вопрос, то да, должно быть можно (я использую pure-ftpd, потому не гарантирую, но это самая базовая функциональность, она должна быть). Если это информация, то тут все в курсе, скорей всего.) ... |
| 02.03.2006, 03:08:02 |
ALex_hha авторГоворили детям - дети, ВСЕГДА меняйте порт 22 на что нибудь еще, если ваш сервер виден из интернета. А то его роботы замучают. и что это изменит? Если хакер не лох, то для начала он тебя просканирует nmap, например, и толку от того, что ты поменяешь порт? А толку то, что сканирование всех 65 тыс портов занимает ОЧЕНЬ приличное время и может использоваться ТОЛЬКО если ваш хост ломают СПЕЦИАЛЬНО. 99.999% же этих атак ведется автоматами, которые просто шарят по всей мировой сети, пробуют простые тесты (порт есть? есть. Прогнать по нему 10 тысяч логинов и паролей плюс пару эксплойтов) и не заморачиваются вариантами нестандартных портов. Прогоните по 2 мегабитному линку nmap на полный диапазон портов (и добавьте программу которая будет еще распознавать ssh) и доложите сюда о результате. А потом прикиньте время, потребное для такого скана хотя бы сотни сетей класса C. И сравните с тупым роботом сканящим порт 22. В реальности перенос порта уменьшает шансы на взлом (особенно на быстрый взлом роботом после публикации слабости протокола) в десятки тысяч раз. Если не в миллионы. Естественно, если вы банк и у вас там миллиарды - это не может быть единственной защитой. ... |
| 02.03.2006, 22:37:31 |
oraweb ALex_hhaну если он снаружи и не нужен, то всегда надо убирать. И не только ssh, а любые сервисы. Кстати, можно настроить FTP сервер (в частности vsftpd), так чтобы он прослушивал только внутреннюю сеть. Т.е. на серваке две сетевухи, одна смотрит в инет, другая на вн. сеть, соответственно, конект разрешен только к внутр. Тогда безопаснее запустить фареволл на внешний интерфейс (тот же ipchain или что там у вас имеется в системе). ... |
| 02.03.2006, 22:38:33 |
Кстати, Alex Roudnev прав почти абсолютно - поставил у себя PortSentry - ничё не изменилось. не сканят меня. Сканят отдельные порты - причём у меня несколько компов в пределах одной подсери - пройдутся веером по 1080, через несколько часов другой по 8080... А больша ничего не сканят... на 22 сразу ломятся, не сканя... 23 - вообще никто не ткнулся ни разу, ... Posted via ActualForum NNTP Server 1.3 ... |
| 03.03.2006, 09:07:59 |
Стыдно признаваться, но меня взломали. А с другой стороны, админом заделался пару месяцев назад, так что нас reboot, а мы крепчаем. Понаделали, сволочи, кучу пользователей с крутыми правами, типа: "лох - не заметит". Я, конечно, лох, но не до такой степени. Короче, чтобы не заморачиваться, грохнул все по старой, виндовой привычке и поставил все по новой. Теперь на все порты смотрю не добрым глазом. Например, Xspider тут пишет - "Сервер DNS поддерживает рекурсию запросов" и, поди, разбери, каким боком это отзовется. ... |
| 03.03.2006, 13:10:53 |
авторКороче, чтобы не заморачиваться, грохнул все по старой, виндовой привычке и поставил все по новой это конечно не обязательно было делать. Но если есть возможност ту да, лучше все переустановить. А что за ОС? ... |
| 03.03.2006, 14:03:13 |
авторэто конечно не обязательно было делать. с другой стороны- профилактика rootkit-ов :-) ... |
| 03.03.2006, 14:24:19 |
ALex_hha А что за ОС? ASPLinux v10 ... |
| 03.03.2006, 14:33:59 |
--null--с другой стороны- профилактика rootkit-ов :-) Ага, паришься, взламываешь, следы заметаешь... А лох взял и переустановил все. И кто на кого в обиде - не понять. :) И охота с такими лохами дела иметь? ... |
| 03.03.2006, 15:22:59 |
самое главное - как взломали-то? Posted via ActualForum NNTP Server 1.3 ... |
| 03.03.2006, 15:36:35 |
авторс другой стороны- профилактика rootkit-ов :-) вот про это я и говорил. Хотя можно воспользоваться - Chrootkit (Saint Jude, kScan, Carbonite, Kstat, Rootkithunter, Tripware, Samhain или подобным ПО. Т.е. впервую очередь отключаешь сервер от сети, а затем начинаешь поиск. Просто полная переустановка не всегда приемлима. авторсамое главное - как взломали-то? полностью согласен, надо было хоть логи было посмотреть через что взломали (apache, ssh, ftp etc). А иначе переустановка системы может ничего не дать и через некоторое время тебя опять взломают. ... |
| 03.03.2006, 17:24:32 |
Вот лог выполнения chkrootkit Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. 53. 54. 55. 56. 57. 58. 59. 60. 61. 62. 63. 64. 65. 66. 67. 68. 69. 70. 71. 72. 73. 74. 75. 76. 77. 78. 79. 80. 81. 82. 83. 84. 85. 86. 87. 88. 89. 90. 91. 92. 93. 94. 95. 96. 97. 98. 99. 100. 101. 102. 103. 104. 105. 106. 107. 108. 109. 110. 111. 112. 113. 114. 115. 116. 117. 118. 119. 120. 121. ... |
| 03.03.2006, 17:56:08 |
Несомненно, надо установить причину взлома и после устранения все-таки переустановка + закрытие дыры наиболее надежна, ибо 100%-й детектилки руткитов в природе скорее всго нету. Хотя все зависит от ситуации, конечно - если жучка нашли, то вероятнее всего, он единственный. Что тоже не факт. ... |
| 03.03.2006, 18:07:44 |
start [/forum/topic.php?fid=25&gotonew=1&tid=1489721]: |
40ms |
51ms |
| others: | 234ms |
| total: | 371ms |
