Форумы / Unix-системы [игнор отключен] [закрыт для гостей] / FreeBSD 6.2: Как настроить PPPoE через mpd?
    #34675156
mallory
Не могу выйти в инет через PPPoE используя mpd-3.18_4.tbz.
/var/log/ppp.log :
Код: plaintext
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
49.
50.
51.
52.
53.
54.
55.
56.
57.
58.
59.
60.
61.
62.
63.
64.
65.
66.
67.
68.
69.
70.
71.
72.
73.
74.
75.
76.
77.
78.
79.
80.
81.
82.
83.
84.
85.
86.
87.
88.
89.
90.
91.
92.
93.
94.
95.
96.
97.
98.
99.
Jul  21   18 : 00 : 00  gangster newsyslog[ 1331 ]: logfile turned over due to size>100K
Jul  21   18 : 00 : 50  gangster ppp: mpd: pid  1351 , version  3 . 18  (root@freebsd.org  06 : 18   15 -Oct- 2006 )
Jul  21   18 : 00 : 50  gangster ppp: [PPPoE] ppp node is "mpd1351-PPPoE"
Jul  21   18 : 00 : 50  gangster ppp: [PPPoE] exec: /sbin/ifconfig rl0 up
Jul  21   18 : 00 : 50  gangster ppp: [PPPoE] Cannot send a netgraph message: rl0::No such file or directory
Jul  21   18 : 00 : 50  gangster ppp: [PPPoE] Error in creation ng_pppoe node on rl0:
Jul  21   18 : 00 : 50  gangster ppp: [PPPoE] using interface ng0
Jul  21   18 : 00 : 50  gangster ppp: [PPPoE] IPCP: peer address cannot be zero
Jul  21   18 : 00 : 50  gangster ppp: [PPPoE] IFACE: Open event
Jul  21   18 : 00 : 50  gangster ppp: [PPPoE] IPCP: Open event
Jul  21   18 : 00 : 50  gangster ppp: [PPPoE] IPCP: state change Initial --> Starting
Jul  21   18 : 00 : 50  gangster ppp: [PPPoE] IPCP: LayerStart
Jul  21   18 : 00 : 50  gangster ppp: [PPPoE] bundle: OPEN event in state CLOSED
Jul  21   18 : 00 : 50  gangster ppp: [PPPoE] opening link "PPPoE"...
Jul  21   18 : 00 : 50  gangster ppp: [PPPoE] link: OPEN event
Jul  21   18 : 00 : 50  gangster ppp: [PPPoE] LCP: Open event
Jul  21   18 : 00 : 50  gangster ppp: [PPPoE] LCP: state change Initial --> Starting
Jul  21   18 : 00 : 50  gangster ppp: [PPPoE] LCP: LayerStart
Jul  21   18 : 00 : 50  gangster ppp: [PPPoE] device: OPEN event in state DOWN
Jul  21   18 : 00 : 50  gangster ppp: [PPPoE] can't connect bypass,link0 and
rl0:orphans,mpd1351-PPPoE: No such file or directory
Jul 21 18:00:50 gangster ppp: [PPPoE] can't remove hook mpd1351-PPPoE from node "rl0:orphans": No such file or directory
Jul  21   18 : 00 : 50  gangster ppp: [PPPoE] device is now in state OPENING
Jul  21   18 : 00 : 50  gangster ppp: [PPPoE] device: DOWN event in state OPENING
Jul  21   18 : 00 : 50  gangster ppp: [PPPoE] device is now in state DOWN
Jul  21   18 : 00 : 50  gangster ppp: [PPPoE] link: DOWN event
Jul  21   18 : 00 : 50  gangster ppp: [PPPoE] LCP: Down event
Jul  21   18 : 00 : 50  gangster ppp: [PPPoE] pausing  4  seconds before open
Jul  21   18 : 00 : 54  gangster ppp: [PPPoE] device: OPEN event in state DOWN
Jul  21   18 : 00 : 54  gangster ppp: [PPPoE] pausing  2  seconds before open
Jul  21   18 : 00 : 54  gangster ppp: [PPPoE] device is now in state DOWN
Jul  21   18 : 00 : 56  gangster ppp: [PPPoE] device: OPEN event in state DOWN
Jul  21   18 : 00 : 56  gangster ppp: [PPPoE] exec: /sbin/ifconfig rl0 up
Jul  21   18 : 00 : 56  gangster ppp: [PPPoE] Cannot send a netgraph message: rl0::No such file or directory
Jul  21   18 : 00 : 56  gangster ppp: [PPPoE] Error in creation ng_pppoe node on rl0:
Jul  21   18 : 00 : 56  gangster ppp: [PPPoE] can't connect bypass,link0 and rl0:orphans,mpd1351-PPPoE: No such file or directory
Jul 21 18:00:56 gangster ppp: [PPPoE] can't remove hook mpd1351-PPPoE from node "rl0:orphans": No such file or directory
Jul  21   18 : 00 : 56  gangster ppp: [PPPoE] device is now in state OPENING
Jul  21   18 : 00 : 56  gangster ppp: [PPPoE] device: DOWN event in state OPENING
Jul  21   18 : 00 : 56  gangster ppp: [PPPoE] device is now in state DOWN
Jul  21   18 : 00 : 56  gangster ppp: [PPPoE] link: DOWN event
Jul  21   18 : 00 : 56  gangster ppp: [PPPoE] LCP: Down event
Jul  21   18 : 00 : 56  gangster ppp: [PPPoE] pausing  4  seconds before open
Jul  21   18 : 01 : 00  gangster ppp: [PPPoE] device: OPEN event in state DOWN
Jul  21   18 : 01 : 00  gangster ppp: [PPPoE] pausing  2  seconds before open
Jul  21   18 : 01 : 00  gangster ppp: [PPPoE] device is now in state DOWN
Jul  21   18 : 01 : 02  gangster ppp: [PPPoE] device: OPEN event in state DOWN
Jul  21   18 : 01 : 02  gangster ppp: [PPPoE] exec: /sbin/ifconfig rl0 up
Jul  21   18 : 01 : 02  gangster ppp: [PPPoE] Cannot send a netgraph message: rl0::No such file or directory
Jul  21   18 : 01 : 02  gangster ppp: [PPPoE] Error in creation ng_pppoe node on rl0:
Jul  21   18 : 01 : 02  gangster ppp: [PPPoE] can't connect bypass,link0 and
Jul 21 18:01:02 gangster ppp: [PPPoE] can't remove hook mpd1351-PPPoE from node "rl0:orphans": No such file or directory
Jul  21   18 : 01 : 02  gangster ppp: [PPPoE] device is now in state OPENING
Jul  21   18 : 01 : 02  gangster ppp: [PPPoE] device: DOWN event in state OPENING
Jul  21   18 : 01 : 02  gangster ppp: [PPPoE] device is now in state DOWN
Jul  21   18 : 01 : 02  gangster ppp: [PPPoE] link: DOWN event
Jul  21   18 : 01 : 02  gangster ppp: [PPPoE] LCP: Down event
Jul  21   18 : 01 : 02  gangster ppp: [PPPoE] pausing  6  seconds before open
Jul  21   18 : 01 : 08  gangster ppp: [PPPoE] device: OPEN event in state DOWN
Jul  21   18 : 01 : 08  gangster ppp: [PPPoE] exec: /sbin/ifconfig rl0 up
Jul  21   18 : 01 : 08  gangster ppp: [PPPoE] Cannot send a netgraph message: rl0::No such file or directory
Jul  21   18 : 01 : 08  gangster ppp: [PPPoE] Error in creation ng_pppoe node on rl0:
Jul  21   18 : 01 : 08  gangster ppp: [PPPoE] can't connect bypass,link0 and
Jul 21 18:01:08 gangster ppp: [PPPoE] can't remove hook mpd1351-PPPoE from node "rl0:orphans": No such file or directory
Jul  21   18 : 01 : 08  gangster ppp: [PPPoE] device is now in state OPENING
Jul  21   18 : 01 : 08  gangster ppp: [PPPoE] device: DOWN event in state OPENING
Jul  21   18 : 01 : 08  gangster ppp: [PPPoE] device is now in state DOWN
Jul  21   18 : 01 : 08  gangster ppp: [PPPoE] link: DOWN event
Jul  21   18 : 01 : 08  gangster ppp: [PPPoE] LCP: Down event
Jul  21   18 : 01 : 08  gangster ppp: [PPPoE] pausing  6  seconds before open
Jul  21   18 : 01 : 13  gangster ppp: mpd: caught fatal signal term
Jul  21   18 : 01 : 13  gangster ppp: [PPPoE] IPCP: Down event
Jul  21   18 : 01 : 13  gangster ppp: [PPPoE] IFACE: Close event
Jul  21   18 : 01 : 13  gangster ppp: [PPPoE] IPCP: Close event
Jul  21   18 : 01 : 13  gangster ppp: [PPPoE] IPCP: state change Starting --> Initial
Jul  21   18 : 01 : 13  gangster ppp: [PPPoE] IPCP: LayerFinish
Jul  21   18 : 01 : 13  gangster ppp: [PPPoE] bundle: CLOSE event in state OPENED
Jul  21   18 : 01 : 13  gangster ppp: [PPPoE] closing link "PPPoE"...
Jul  21   18 : 01 : 13  gangster ppp: [PPPoE] link: CLOSE event
Jul  21   18 : 01 : 13  gangster ppp: [PPPoE] LCP: Close event
Jul  21   18 : 01 : 13  gangster ppp: [PPPoE] LCP: state change Starting --> Initial
Jul  21   18 : 01 : 13  gangster ppp: [PPPoE] LCP: LayerFinish
Jul  21   18 : 01 : 13  gangster ppp: [PPPoE] device: CLOSE event in state DOWN
Jul  21   18 : 01 : 13  gangster ppp: [PPPoE] device is now in state DOWN
Содержимое конфигов - /usr/local/etc/mpd.conf :
Код: plaintext
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
default:
	load PPPoE
... другие разделы...
PPPoE:
	new -i ng0 PPPoE PPPoE
	set iface addrs  1 . 1 . 1 . 1   2 . 2 . 2 . 2
	set iface route default
	set iface disable on-demand
	set iface idle  0
	set bundle disable multilink
	set bundle authname malor
	set bundle password moi_parol
	set link no acfcomp protocomp
	set link disable pap chap
	set link accept chap
	set link mtu  1492
	set link keep-alive  10   60
	set ipcp yes vjcomp
	set ipcp ranges  0 . 0 . 0 . 0 / 0   0 . 0 . 0 . 0 / 0
	open iface
... другие разделы ...
/usr/local/etc/mpd.links :
Код: plaintext
1.
2.
3.
4.
5.
6.
7.
PPPoE:
        set link type pppoe
        set pppoe iface rl0
        set pppoe service "*"
	set pppoe disable incoming
	set pppoe enable originate
В /usr/local/etc/mpd.secret прописана строка с именем и паролем.
Что делать?
P.S. Где в ин е те инструкции по настройке PPPoE через mpd?
FreeBSD 6.2
