hp-ux vxfs теряет файлы при пропадании диска
Второй раз уже такое вижу. Что за нафиг? # mount /oradata vxfs mount: /dev/dsk/c16t0d0 is corrupted. needs checking # fsck /dev/rdsk/c16t0d0 vxfs fsck: file system had I/O error(s) on meta-data. log replay in progress file system is not clean, full fsck required full file system check required, exiting ... #fsck -y -o full /dev/rdsk/c16t0d0 vxfs fsck: file system had I/O error(s) on meta-data. log replay in progress pass0 - checking structural files pass1 - checking inode sanity and blocks fileset 999 primary-ilist inode 76 marked bad, allocation flags (0x0001) ... fileset 999 primary-ilist inode 207 failed validation clear? (ynq)y pass2 - checking directory linkage fileset 999 directory 4 block 1544 offset 532 references free inode ino 75 remove entry? (ynq)y fileset 999 directory 4 block 1544 incorrect header fix? (ynq)y fileset 999 directory 5 block 1281 offset 540 references free inode ino 65 remove entry? (ynq)y .... fileset 999 directory 5 block 1281 offset 3828 references free inode ino 76 remove entry? (ynq)y fileset 999 directory 5 block 1281 incorrect header fix? (ynq)y fileset 999 directory 110 block 0 offset 4 references free inode ino 6 remove entry? (ynq)y fileset 999 directory 110 block 0 offset 52 references free inode ino 111 remove entry? (ynq)y fileset 999 directory 110 block 0 incorrect header fix? (ynq)y pass3 - checking reference counts fileset 999 primary-ilist inode 4 link count is 5 should be 4 adjust? (ynq)y fileset 999 primary-ilist inode 160 unreferenced file, reconnect? (ynq)y fileset 999 primary-ilist inode 163 unreferenced file, reconnect? (ynq)y rebuild structural files? (ynq)y pass0 - checking structural files pass1 - checking inode sanity and blocks pass2 - checking directory linkage pass3 - checking reference counts pass4 - checking resource maps fileset 999 au 0 imap incorrect - fix (ynq)y fileset 999 au 0 iemap incorrect - fix (ynq)y au 0 emap incorrect - fix? (ynq)y au 0 summary incorrect - fix? (ynq)y au 1 emap incorrect - fix? (ynq)y au 1 summary incorrect - fix? (ynq)y ... au 999 summary incorrect - fix? (ynq)y fileset 999 iau 0 summary incorrect - fix? (ynq)y free block count incorrect 4920602 expected 24294500 fix? (ynq)y free extent vector incorrect fix? (ynq)y OK to clear log? (ynq)y set state to CLEAN? (ynq)y Исчезло больше 60-ти файлов и каталог. В lost+found два файла Смонтировано так: /oradata type vxfs log,nodatainlog,largefiles,mincache=direct,convosync=direct ... |
| 10.09.2007, 15:18:51 |
start [/forum/topic.php?fid=25&gotonew=1&tid=1487767]: |
48ms |
83ms |
| others: | 298ms |
| total: | 522ms |
