Не могу прикрутить MySQL к PHP
Solaris 10, MySQL 4.0.27, PHP 4.4.7 Требуется к PHP данной версии прикрутить MySQL данной версии (требования разработчика сайта). Без MySQL все работает. Делаю для PHP ./confgure --with-mysql=/usr/local/mysql все проходит без ошибок. Делаю make и тут выдает: ld: warning: file /usr/local/mysql/lib/libmysqlclient.a(libmysql.o): wrong ELF class: ELFCLASS64 Undefined first referenced symbol in file mysql_list_dbs ext/mysql/php_mysql.lo mysql_fetch_row ext/mysql/php_mysql.lo mysql_fetch_field ext/mysql/php_mysql.lo mysql_data_seek ext/mysql/php_mysql.lo mysql_get_client_info ext/mysql/php_mysql.lo mysql_errno ext/mysql/php_mysql.lo mysql_error ext/mysql/php_mysql.lo mysql_close ext/mysql/php_mysql.lo mysql_thread_id ext/mysql/php_mysql.lo mysql_get_host_info ext/mysql/php_mysql.lo mysql_insert_id ext/mysql/php_mysql.lo mysql_options ext/mysql/php_mysql.lo mysql_list_tables ext/mysql/php_mysql.lo mysql_free_result ext/mysql/php_mysql.lo mysql_character_set_name ext/mysql/php_mysql.lo mysql_list_processes ext/mysql/php_mysql.lo mysql_get_proto_info ext/mysql/php_mysql.lo mysql_store_result ext/mysql/php_mysql.lo mysql_list_fields ext/mysql/php_mysql.lo mysql_ping ext/mysql/php_mysql.lo mysql_stat ext/mysql/php_mysql.lo mysql_info ext/mysql/php_mysql.lo mysql_init ext/mysql/php_mysql.lo mysql_select_db ext/mysql/php_mysql.lo mysql_get_server_info ext/mysql/php_mysql.lo mysql_affected_rows ext/mysql/php_mysql.lo mysql_real_connect ext/mysql/php_mysql.lo mysql_real_query ext/mysql/php_mysql.lo mysql_eof ext/mysql/php_mysql.lo mysql_field_seek ext/mysql/php_mysql.lo mysql_fetch_lengths ext/mysql/php_mysql.lo mysql_real_escape_string ext/mysql/php_mysql.lo mysql_field_count ext/mysql/php_mysql.lo mysql_num_rows ext/mysql/php_mysql.lo mysql_num_fields ext/mysql/php_mysql.lo mysql_use_result ext/mysql/php_mysql.lo mysql_escape_string ext/mysql/php_mysql.lo ld: fatal: Symbol referencing errors. No output written to sapi/cli/php collect2: ld returned 1 exit status *** Error code 1 make: Fatal error: Command failed for target `sapi/cli/php' Похоже, клиент который имеется в PHP ext/mysql не работает с MySQL 4.0.27. Найти нужные файлы ext/mysql в интернете не получается. Подскажите, кто знает? ... |
| 14.09.2007, 13:26:49 |
start [/forum/topic.php?fid=25&gotonew=1&tid=1487735]: |
39ms |
49ms |
| others: | 279ms |
| total: | 453ms |
