Apach httpd-error.log
Здраствуйте! привожу лог httpd-error.log [Thu Oct 18 13:33:56 2007] [warn] child process 36911 still did not exit, sending a SIGTERM [Thu Oct 18 13:33:56 2007] [warn] child process 36912 still did not exit, sending a SIGTERM [Thu Oct 18 13:33:56 2007] [warn] child process 36913 still did not exit, sending a SIGTERM [Thu Oct 18 13:33:56 2007] [warn] child process 36949 still did not exit, sending a SIGTERM [Thu Oct 18 13:34:04 2007] [notice] Apache/1.3.37 (Unix) PHP/4.4.4 configured -- resuming normal operations [Thu Oct 18 13:34:04 2007] [notice] Accept mutex: flock (Default: flock) FATAL: erealloc(): Unable to allocate 3298439 bytes FATAL: emalloc(): Unable to allocate 3840 bytes FATAL: erealloc(): Unable to allocate 3298439 bytes FATAL: erealloc(): Unable to allocate 3298439 bytes FATAL: emalloc(): Unable to allocate 3840 bytes [Thu Oct 18 23:49:56 2007] [notice] child pid 53659 exit signal Segmentation fault (11) сервер зависает и всё! пока не перегрузиш апач! почему? в чём может быть проблема? спасибо ... |
| 19.10.2007, 15:13:35 |
а что в системе происходит в этот момент? посмотри кол-во свободной памяти и своп ... |
| 19.10.2007, 16:30:30 |
мне так каэццо у вас в каком-то модуле memory leak ... |
| 20.10.2007, 14:06:52 |
пока вот так CPU states: 0.0% user, 0.0% nice, 100% system, 0.0% interrupt, 0.0% idle Mem: 234M Active, 872M Inact, 202M Wired, 95M Cache, 112M Buf, 1852M Free Swap: 2048M Total, 63M Used, 1985M Free, 3% Inuse ... |
| 21.10.2007, 20:34:38 |
CPU states: 0.0% user, 0.0% nice, 0.2% system, 0.0% interrupt, 99.8% idle Mem: 234M Active, 872M Inact, 203M Wired, 95M Cache, 112M Buf, 1851M Free Swap: 2048M Total, 63M Used, 1985M Free, 3% Inuse ... |
| 21.10.2007, 20:37:32 |
vitalik mensпока вот так CPU states: 0.0% user, 0.0% nice, 100% system, 0.0% interrupt, 0.0% idle Mem: 234M Active, 872M Inact, 202M Wired, 95M Cache, 112M Buf, 1852M Free Swap: 2048M Total, 63M Used, 1985M Free, 3% Inuse это когда ошибки валятся?! ... |
| 21.10.2007, 21:00:42 |
нет, это когда всё гуд, будут ошыбки сразу выложу ... |
| 21.10.2007, 21:20:40 |
vitalik mensнет, это когда всё гуд, будут ошыбки сразу выложу рад, что у вас всё хорошо. ждём ошибок :) ... |
| 21.10.2007, 21:36:54 |
что это за процессы?? 80644 www 1 4 0 507M 504M accept 0 1:23 0.00% httpd 80645 www 1 4 0 29844K 27100K sbwait 0 0:24 0.00% httpd 87228 www 1 4 0 30412K 27676K accept 0 0:22 0.00% httpd 86405 www 1 4 0 30248K 27508K accept 0 0:16 0.00% httpd 14900 www 1 4 0 31768K 28992K accept 1 0:04 0.00% httpd 17016 www 1 4 0 12212K 9392K accept 0 0:02 0.00% httpd 17186 www 1 4 0 12404K 9584K accept 0 0:02 0.00% httpd 17234 www 1 4 0 12224K 9412K accept 1 0:02 0.00% httpd 16717 www 1 4 0 12320K 9516K accept 0 0:01 0.00% httpd 17423 www 1 4 0 12236K 9416K accept 0 0:01 0.00% httpd первый уже 504 метра!! ... |
| 25.10.2007, 12:08:16 |
start [/forum/topic.php?fid=25&gotonew=1&tid=1487572]: |
23ms |
68ms |
60ms |
| others: | 302ms |
| total: | 507ms |
