procmail (sendmail) отлов исходящей почты
Не могу отловить исходящюю почту - помогите sendmail.mc: divert(-1)dnl dnl # dnl # This is the sendmail macro config file for m4. If you make changes to dnl # /etc/mail/sendmail.mc, you will need to regenerate the dnl # /etc/mail/sendmail.cf file by confirming that the sendmail-cf package is dnl # installed and then performing a dnl # dnl # make -C /etc/mail dnl # include(`/usr/share/sendmail-cf/m4/cf.m4')dnl VERSIONID(`setup for Red Hat Linux')dnl OSTYPE(`linux')dnl dnl # dnl # Uncomment and edit the following line if your outgoing mail needs to dnl # be sent out through an external mail server: dnl # dnl define(`SMART_HOST',`smtp.your.provider') dnl # define(`confDEF_USER_ID',``8:12'')dnl define(`confTRUSTED_USER', `smmsp')dnl dnl define(`confAUTO_REBUILD')dnl define(`confTO_CONNECT', `1m')dnl define(`confTRY_NULL_MX_LIST',true)dnl define(`confDONT_PROBE_INTERFACES',true)dnl define(`PROCMAIL_MAILER_PATH',`/usr/bin/procmail')dnl define('PROCMAIL_MAILER_ARGS','procmail -Y -m $h $g $u')dnl define(`ALIAS_FILE', `/etc/aliases')dnl dnl define(`STATUS_FILE', `/etc/mail/statistics')dnl define(`UUCP_MAILER_MAX', `2000000')dnl define(`confUSERDB_SPEC', `/etc/mail/userdb.db')dnl define(`confPRIVACY_FLAGS', `authwarnings,novrfy,noexpn,restrictqrun')dnl define(`confAUTH_OPTIONS', `A')dnl dnl # dnl # The following allows relaying if the user authenticates, and disallows dnl # plaintext authentication (PLAIN/LOGIN) on non-TLS links dnl # dnl define(`confAUTH_OPTIONS', `A p')dnl dnl # dnl # PLAIN is the preferred plaintext authentication method and used by dnl # Mozilla Mail and Evolution, though Outlook Express and other MUAs do dnl # use LOGIN. Other mechanisms should be used if the connection is not dnl # guaranteed secure. dnl # dnl TRUST_AUTH_MECH(`EXTERNAL DIGEST-MD5 CRAM-MD5 LOGIN PLAIN')dnl dnl define(`confAUTH_MECHANISMS', `EXTERNAL GSSAPI DIGEST-MD5 CRAM-MD5 LOGIN PLAIN')dnl dnl # dnl # Rudimentary information on creating certificates for sendmail TLS: dnl # make -C /usr/share/ssl/certs usage dnl # dnl define(`confCACERT_PATH',`/usr/share/ssl/certs') dnl define(`confCACERT',`/usr/share/ssl/certs/ca-bundle.crt') dnl define(`confSERVER_CERT',`/usr/share/ssl/certs/sendmail.pem') dnl define(`confSERVER_KEY',`/usr/share/ssl/certs/sendmail.pem') dnl # dnl # This allows sendmail to use a keyfile that is shared with OpenLDAP's dnl # slapd, which requires the file to be readble by group ldap dnl # dnl define(`confDONT_BLAME_SENDMAIL',`groupreadablekeyfile')dnl dnl # dnl define(`confTO_QUEUEWARN', `4h')dnl dnl define(`confTO_QUEUERETURN', `5d')dnl dnl define(`confQUEUE_LA', `12')dnl dnl define(`confREFUSE_LA', `18')dnl define(`confTO_IDENT', `0')dnl dnl FEATURE(delay_checks)dnl FEATURE(`no_default_msa',`dnl')dnl FEATURE(`smrsh',`/usr/sbin/smrsh')dnl FEATURE(`mailertable',`hash -o /etc/mail/mailertable.db')dnl FEATURE(`virtusertable',`hash -o /etc/mail/virtusertable.db')dnl FEATURE(redirect)dnl FEATURE(always_add_domain)dnl FEATURE(use_cw_file)dnl FEATURE(use_ct_file)dnl dnl # dnl # The -t option will retry delivery if e.g. the user runs over his quota. dnl # FEATURE(local_procmail,`',`procmail -t -Y -a $h -d $u')dnl FEATURE(`access_db',`hash -T<TMPF> -o /etc/mail/access.db')dnl FEATURE(`blacklist_recipients')dnl EXPOSED_USER(`root')dnl dnl # dnl # The following causes sendmail to only listen on the IPv4 loopback address dnl # 127.0.0.1 and not on any other network devices. Remove the loopback dnl # address restriction to accept email from the internet or intranet. dnl # dnl # DAEMON_OPTIONS(`Port=smtp,Addr=127.0.0.1, Name=MTA')dnl dnl # dnl # The following causes sendmail to additionally listen to port 587 for dnl # mail from MUAs that authenticate. Roaming users who can't reach their dnl # preferred sendmail daemon due to port 25 being blocked or redirected find dnl # this useful. dnl # dnl DAEMON_OPTIONS(`Port=submission, Name=MSA, M=Ea')dnl dnl # dnl # The following causes sendmail to additionally listen to port 465, but dnl # starting immediately in TLS mode upon connecting. Port 25 or 587 followed dnl # by STARTTLS is preferred, but roaming clients using Outlook Express can't dnl # do STARTTLS on ports other than 25. Mozilla Mail can ONLY use STARTTLS dnl # and doesn't support the deprecated smtps; Evolution <1.1.1 uses smtps dnl # when SSL is enabled-- STARTTLS support is available in version 1.1.1. dnl # dnl # For this to work your OpenSSL certificates must be configured. dnl # dnl DAEMON_OPTIONS(`Port=smtps, Name=TLSMTA, M=s')dnl dnl # dnl # The following causes sendmail to additionally listen on the IPv6 loopback dnl # device. Remove the loopback address restriction listen to the network. dnl # dnl # NOTE: binding both IPv4 and IPv6 daemon to the same port requires dnl # a kernel patch dnl # dnl DAEMON_OPTIONS(`port=smtp,Addr=::1, Name=MTA-v6, Family=inet6')dnl dnl # dnl # We strongly recommend not accepting unresolvable domains if you want to dnl # protect yourself from spam. However, the laptop and users on computers dnl # that do not have 24x7 DNS do need this. dnl # FEATURE(`accept_unresolvable_domains')dnl dnl # dnl FEATURE(`relay_based_on_MX')dnl dnl # dnl # Also accept email sent to "localhost.localdomain" as local email. dnl # LOCAL_DOMAIN(`localhost.localdomain')dnl dnl # dnl # The following example makes mail from this host and any additional dnl # specified domains appear to be sent from mydomain.com dnl # dnl MASQUERADE_AS(`mydomain.com')dnl dnl # dnl # masquerade not just the headers, but the envelope as well dnl # dnl FEATURE(masquerade_envelope)dnl dnl # dnl # masquerade not just @mydomainalias.com, but @*.mydomainalias.com as well dnl # dnl FEATURE(masquerade_entire_domain)dnl dnl # dnl MASQUERADE_DOMAIN(localhost)dnl dnl MASQUERADE_DOMAIN(localhost.localdomain)dnl dnl MASQUERADE_DOMAIN(mydomainalias.com)dnl dnl MASQUERADE_DOMAIN(mydomain.lan)dnl MAILER(smtp)dnl MAILER(procmail)dnl LOCAL_CONFIG D{Procmail} PROCMAIL CP ${Procmail} C{PRT} ${Procmail} LOCAL_RULE_0 R$*<@$+.$~{PRT}.>$* $# procmail $@ /etc/some.rc $:$1@$2.$3.${Procmail} R$*<@$*.${Procmail}.>$* $@ $1<@$2.>$3 LOCAL_RULE_2 R$*@$+.${Procmail} $1<@$2.${Procmail}> dnl define(`_FFR_MILTER',1) MAIL_FILTER(`drweb-filter', `S=inet:3001@localhost, T=S:240s;R:240s;E:1h') define(`confINPUT_MAIL_FILTERS', `drweb-filter') define(`confMILTER_LOG_LEVEL',`1') some.rc: :0 *^TO.*sdmv.ru { :0 c ! -f "$@" :0 |/usr/bin/formail -I"To: insdmv" -I"Cc:" -I"Bcc:" |/usr/sbin/sendmail -t } :0 *^TO.* { :0 c ! -f "$@" :0 |/usr/bin/formail -I"To: outsdmv" -I"Cc:" -I"Bcc:" -I"X-SND: Procmail"|/usr/sbin/sendmail -t } ... |
| 27.08.2003, 15:53:02 |
Вопрос снимается, проблема решена ... |
| 29.08.2003, 09:58:03 |
А можно как нибудь поподробней рассказать по этому поводу? ... |
| 03.03.2004, 18:01:49 |
http://www.opennet.ru/docs/RUS/sendmail_copy/#copymail1 Следуя советам статьи - у меня все успешно работает --- www.markelov.net ... |
| 16.03.2004, 09:05:52 |
Статью эту я читал. Но вот интересно а можно ли как нить обойтись прокмейлом и им фильтровать исходящую почту? ... |
| 19.03.2004, 17:19:49 |
tvp, а почему наверху форум пошёл криво? какие-то знаки не фильтруются? например {anything ... |
| 07.05.2009, 14:06:13 |
start [/forum/topic.php?fid=25&gotonew=1&tid=1485837]: |
47ms |
62ms |
| others: | 287ms |
| total: | 470ms |
