SELinux (проблема доступа)
Поставил Joomla 1.5.11 на FC10 c включенным SELinux'ом. При входе в админку получаю: SELinux Summary: SELinux prevented httpd reading and writing access to http files. Detailed Description: SELinux prevented httpd reading and writing access to http files. Ordinarily httpd is allowed full access to all files labeled with http file context. This machine has a tightened security policy with the httpd_unified turned off, this requires explicit labeling of all files. If a file is a cgi script it needs to be labeled with httpd_TYPE_script_exec_t in order to be executed. If it is read-only content, it needs to be labeled httpd_TYPE_content_t, it is writable content. it needs to be labeled httpd_TYPE_script_rw_t or httpd_TYPE_script_ra_t. You can use the chcon command to change these contexts. Please refer to the man page "man httpd_selinux" or FAQ (http://fedora.redhat.com/docs/selinux-apache-fc3) "TYPE" refers to one of "sys", "user" or "staff" or potentially other script types. Allowing Access: Changing the "httpd_unified" boolean to true will allow this access: "setsebool -P httpd_unified=1" Fix Command: setsebool -P httpd_unified=1 Additional Information: Source Context system_u:system_r:httpd_t:s0 Target Context system_u:object_r:httpd_sys_content_t:s0 Target Objects ./3c788c8140c244baa4de05cad390c937.spc [ file ] Source httpd Source Path /usr/sbin/httpd Port <Unknown> Host localhost Source RPM Packages httpd-2.2.11-2.fc10 Target RPM Packages Policy RPM selinux-policy-3.5.13-61.fc10 Selinux Enabled True Policy Type targeted MLS Enabled True Enforcing Mode Enforcing Plugin Name httpd_unified Host Name localhost Platform Linux localhost 2.6.27.24-170.2.68.fc10.i686 #1 SMP Wed May 20 23:10:16 EDT 2009 i686 i686 Alert Count 28 First Seen Sun 07 Jun 2009 05:33:53 PM EEST Last Seen Wed 10 Jun 2009 06:47:39 AM EEST Local ID cfdffe5b-7123-4370-902a-f982aa3c8162 Line Numbers Raw Audit Messages node=localhost type=AVC msg=audit(1244605659.234:49): avc: denied { create } for pid=4462 comm="httpd" name="3c788c8140c244baa4de05cad390c937.spc" scontext=system_u:system_r:httpd_t:s0 tcontext=system_u:object_r:httpd_sys_content_t:s0 tclass=file node=localhost type=SYSCALL msg=audit(1244605659.234:49): arch=40000003 syscall=5 success=no exit=-13 a0=341eb78 a1=241 a2=1b6 a3=341eb78 items=0 ppid=2385 pid=4462 auid=4294967295 uid=48 gid=48 euid=48 suid=48 fsuid=48 egid=48 sgid=48 fsgid=48 tty=(none) ses=4294967295 comm="httpd" exe="/usr/sbin/httpd" subj=system_u:system_r:httpd_t:s0 key=(null) setsebool -P httpd_unified=1 , как советуют - говорил: что мертвому припарки. В результате, при 777, фактически права на запись - отсутствуют. Как сие лечится? _________________ "Helo, word!" - 17 errors 56 warnings Posted via ActualForum NNTP Server 1.4 ... |
| 10.06.2009, 11:20:34 |
Глобально лечится: 1. Проверяем getsebool -a | grep httpd ... httpd_enable_cgi --> off httpd_unified --> on httpd_builtin_scripting --> on ... 2. Для всех off устанавливаем Код: plaintext 1. 2. 3. М.б. как-то можно непосредственно настроить на конкретные файлы а-ля ? _________________ "Helo, word!" - 17 errors 56 warnings ... |
| 12.06.2009, 15:22:20 |
start [/forum/topic.php?fid=25&gotonew=1&tid=1485734]: |
75ms |
63ms |
| others: | 306ms |
| total: | 527ms |
