Как вкл поддержку mod_auth в Apache?
Купили VPS смотрю httpd -l модули Compiled in modules: core.c prefork.c http_core.c mod_so.c Модуля mod_auth нету, из-за этого не работает наверное прохождение пароля .htaccess Пишет access to /admin failed, reason: require directives present and no Authoritative handler. Что делать подскажите плиз, как это исправить? На сервере стоит установщик yum, может как-то с ним можно установить? ... |
| 25.08.2009, 15:28:02 |
1. apachectl -V Server version: Apache/2.2.9 (Unix) Server built: Jul 14 2008 15:36:01 Server's Module Magic Number: 20051115:15 Server loaded: APR 1.2.12, APR-Util 1.2.12 Compiled using: APR 1.2.12, APR-Util 1.2.12 Architecture: 64-bit Server MPM: Prefork threaded: no forked: yes (variable process count) 2. apachectl -l Compiled in modules: core.c prefork.c http_core.c mod_so.c 3. pachectl -M Loaded Modules: core_module (static) mpm_prefork_module (static) http_module (static) so_module (static) auth_basic_module (shared) authn_alias_module (shared) authz_host_module (shared) include_module (shared) log_config_module (shared) logio_module (shared) env_module (shared) ext_filter_module (shared) mime_magic_module (shared) expires_module (shared) deflate_module (shared) headers_module (shared) usertrack_module (shared) setenvif_module (shared) mime_module (shared) autoindex_module (shared) vhost_alias_module (shared) negotiation_module (shared) dir_module (shared) actions_module (shared) alias_module (shared) rewrite_module (shared) proxy_module (shared) proxy_http_module (shared) proxy_connect_module (shared) cache_module (shared) suexec_module (shared) disk_cache_module (shared) file_cache_module (shared) mem_cache_module (shared) cgi_module (shared) cband_module (shared) extract_forwarded_module (shared) geoip_module (shared) security2_module (shared) unique_id_module (shared) proxy_ajp_module (shared) ssl_module (shared) php5_module (shared) Syntax OK ... |
| 26.08.2009, 09:46:19 |
Вот мои параметры Апача apachectl -V Server version: Apache/2.2.3 Server built: Jan 15 2008 20:33:30 Server's Module Magic Number: 20051115:3 Server loaded: APR 1.2.7, APR-Util 1.2.7 Compiled using: APR 1.2.7, APR-Util 1.2.7 Architecture: 32-bit Server MPM: Prefork threaded: no forked: yes (variable process count) Server compiled with.... -D APACHE_MPM_DIR="server/mpm/prefork" -D APR_HAS_SENDFILE -D APR_HAS_MMAP -D APR_HAVE_IPV6 (IPv4-mapped addresses enabled) -D APR_USE_SYSVSEM_SERIALIZE -D APR_USE_PTHREAD_SERIALIZE -D SINGLE_LISTEN_UNSERIALIZED_ACCEPT -D APR_HAS_OTHER_CHILD -D AP_HAVE_RELIABLE_PIPED_LOGS -D DYNAMIC_MODULE_LIMIT=128 -D HTTPD_ROOT="/etc/httpd" -D SUEXEC_BIN="/usr/sbin/suexec" -D DEFAULT_PIDLOG="logs/httpd.pid" -D DEFAULT_SCOREBOARD="logs/apache_runtime_status" -D DEFAULT_LOCKFILE="logs/accept.lock" -D DEFAULT_ERRORLOG="logs/error_log" -D AP_TYPES_CONFIG_FILE="conf/mime.types" -D SERVER_CONFIG_FILE="conf/httpd.conf" apachectl -l Compiled in modules: core.c prefork.c http_core.c mod_so.c apachectl -M Loaded Modules: core_module (static) mpm_prefork_module (static) http_module (static) so_module (static) authn_file_module (shared) actions_module (shared) alias_module (shared) asis_module (shared) auth_basic_module (shared) authz_default_module (shared) authz_host_module (shared) autoindex_module (shared) cgi_module (shared) dir_module (shared) env_module (shared) expires_module (shared) headers_module (shared) include_module (shared) log_config_module (shared) logio_module (shared) mime_module (shared) negotiation_module (shared) rewrite_module (shared) setenvif_module (shared) speling_module (shared) vhost_alias_module (shared) php5_module (shared) Syntax OK ... |
| 26.08.2009, 11:19:15 |
start [/forum/topic.php?fid=25&gotonew=1&tid=1485568]: |
58ms |
51ms |
| others: | 285ms |
| total: | 460ms |
