Как сделать autorun скрипт для своего демона
Добрый день всем! Есть самодельный демон для Ubuntu Server, подскажите, как можно сделать скрипт автозапуска? Код демона, вот собственно Только pid файл в /var/run/ и umask(777). ls -l /usr/bin | grep pgdeamon -rwxr-xr-x 1 root root 12595 2009-10-26 11:20 pgdeamon root@developer:/etc/init.d# update-rc.d pgdeamon defaults Adding system startup for /etc/init.d/pgdeamon ... /etc/rc0.d/K20pgdeamon -> ../init.d/pgdeamon /etc/rc1.d/K20pgdeamon -> ../init.d/pgdeamon /etc/rc6.d/K20pgdeamon -> ../init.d/pgdeamon /etc/rc2.d/S20pgdeamon -> ../init.d/pgdeamon /etc/rc3.d/S20pgdeamon -> ../init.d/pgdeamon /etc/rc4.d/S20pgdeamon -> ../init.d/pgdeamon /etc/rc5.d/S20pgdeamon -> ../init.d/pgdeamon root@developer:/etc/init.d# ./pgdeamon start 99 * Starting Pgdeamon service pgdeamon [ OK ] root@developer:/etc/init.d# ./pgdeamon stop 99 * Stopping Pgdeamon service pgdeamon [ OK ] root@developer:/etc/init.d# le ./pgdeamon #! /bin/sh ### BEGIN INIT INFO # Provides: skeleton # Required-Start: $local_fs $remote_fs # Required-Stop: $local_fs $remote_fs # Default-Start: 2 3 4 5 # Default-Stop: 0 1 6 # Short-Description: Example initscript # Description: This file should be used to construct scripts to be # placed in /etc/init.d. ### END INIT INFO # Author: Foo Bar # # Please remove the "Author" lines above and replace them # with your own name if you copy and modify this script. # Do NOT "set -e" # PATH should only include /usr/* if it runs after the mountnfs.sh script PATH=/usr/sbin:/usr/bin:/sbin:/bin DESC="Pgdeamon service" NAME=pgdeamon DAEMON=/usr/bin/$NAME DAEMON_ARGS="" PIDFILE=/var/run/$NAME.pid SCRIPTNAME=/etc/init.d/$NAME # Exit if the package is not installed #[ -x "$DAEMON" ] || exit 0 # Read configuration variable file if it is present #[ -r /etc/default/$NAME ] && . /etc/default/$NAME # Load the VERBOSE setting and other rcS variables #[ -f /etc/default/rcS ] && . /etc/default/rcS # Define LSB log_* functions. # Depend on lsb-base (>= 3.0-6) to ensure that this file is present. . /lib/lsb/init-functions # # Function that starts the daemon/service # do_start() { # Return # 0 if daemon has been started # 1 if daemon was already running # 2 if daemon could not be started #start-stop-daemon --start --quiet --pidfile $PIDFILE --exec $DAEMON --test > /dev/null || return 1 #start-stop-daemon --start --quiet --pidfile $PIDFILE --exec $DAEMON -- $DAEMON_ARGS || return 2 start-stop-daemon --start --quiet --pidfile $PIDFILE --exec $DAEMON --background -- $DAEMON_ARGS > /dev/null || return 2 # Add code here, if necessary, that waits for the process to be ready # to handle requests from services started subsequently which depend # on this one. As a last resort, sleep for some time. } # # Function that stops the daemon/service # do_stop() { # Return # 0 if daemon has been stopped # 1 if daemon was already stopped # 2 if daemon could not be stopped # other if a failure occurred #start-stop-daemon --stop --quiet --retry=TERM/30/KILL/5 --pidfile $PIDFILE --name $NAME #RETVAL="$?" #[ "$RETVAL" = 2 ] && return 2 # Wait for children to finish too if this is a daemon that forks # and if the daemon is only ever run from this initscript. # If the above conditions are not satisfied then add some other code # that waits for the process to drop all resources that could be # needed by services started subsequently. A last resort is to # sleep for some time. start-stop-daemon --stop --quiet --oknodo --retry=0/30/KILL/5 --exec $DAEMON [ "$?" = 2 ] && return 2 # Many daemons don't delete their pidfiles when they exit. #rm -f $PIDFILE #return "$RETVAL" } # # Function that sends a SIGHUP to the daemon/service # #do_reload() { # # If the daemon can reload its configuration without # restarting (for example, when it is sent a SIGHUP), # then implement that here. # #start-stop-daemon --stop --signal 1 --quiet --pidfile $PIDFILE --name $NAME #return 0 #} case "$1" in start) [ "$VERBOSE" != no ] && log_daemon_msg "Starting $DESC" "$NAME" do_start case "$?" in 0|1) [ "$VERBOSE" != no ] && log_end_msg 0 ;; 2) [ "$VERBOSE" != no ] && log_end_msg 1 ;; esac ;; stop) [ "$VERBOSE" != no ] && log_daemon_msg "Stopping $DESC" "$NAME" do_stop case "$?" in 0|1) [ "$VERBOSE" != no ] && log_end_msg 0 ;; 2) [ "$VERBOSE" != no ] && log_end_msg 1 ;; esac ;; #reload|force-reload) # # If do_reload() is not implemented then leave this commented out # and leave 'force-reload' as an alias for 'restart'. # #log_daemon_msg "Reloading $DESC" "$NAME" #do_reload #log_end_msg $? #;; restart|force-reload) # # If the "reload" option is implemented then remove the # 'force-reload' alias # log_daemon_msg "Restarting $DESC" "$NAME" do_stop case "$?" in 0|1) do_start case "$?" in 0) log_end_msg 0 ;; 1) log_end_msg 1 ;; # Old process is still running *) log_end_msg 1 ;; # Failed to start esac ;; *) # Failed to stop log_end_msg 1 ;; esac ;; *) #echo "Usage: $SCRIPTNAME {start|stop|restart|reload|force-reload}" >&2 echo "Usage: $SCRIPTNAME {start|stop|restart|force-reload}" >&2 exit 3 ;; esac : При рестарте полный down.... Может фокус в пользователях, при старте у меня пользователь user1, дальше sudo -s -H + код user1 получаюсь root-ом, может тут особенность? Возникают вопросы: Cам демон нужно собрать как-то по стандарту? Демоны нужно как-то регистрировать в системе? ... |
| 27.10.2009, 09:15:55 |
start [/forum/topic.php?fid=25&gotonew=1&tid=1485376]: |
63ms |
47ms |
| others: | 319ms |
| total: | 510ms |
