проблема с unixodbc
sles 10 при запуске ODBCConfig появляются ошибки Failed to execute SQLManageDataSources(). The most likely reason for this is that the Qt GUI plugin could not be found or could not be loaded. Ensure that libodbcinstQ.* files are in the library search path. The path can be altered by setting the LTDL_LIBRARY_PATH environment variable. LTDL_LIBRARY_PATH задавал, не помогло может кто сталкивался? ... |
| 05.04.2010, 19:09:34 |
start [/forum/topic.php?fid=25&gotonew=1&tid=1485012]: |
23ms |
2521ms |
62ms |
| others: | 320ms |
| total: | 2992ms |
