Здравствуйте!
Пробую установить tokenizer из командной строки вот что выдает:
1.
2.
3.
4.
5.
6.
7.
8.
9.
# cd /usr/ports/devel/php5-tokenizer/
# make install clean
===> Building for php5-tokenizer- 5 . 2 . 12 /bin/sh /usr/ports/devel/php5-tokenizer/work/php- 5 . 2 . 12 /ext/tokenizer/libtool --mode=compile cc -I. -I/usr/ports/devel/php5-tokenizer/work/php-5.2.12/ext/tokenizer -DPHP_ATOM_INC -I/usr/ports/devel/php5-tokenizer/work/php-5.2.12/ext/tokenizer/include -I/usr/ports/devel/php5-tokenizer/work/php-5.2.12/ext/tokenizer/main -I/usr/ports/devel/php5-tokenizer/work/php-5.2.12/ext/tokenizer -I/usr/local/include/php -I/usr/local/include/php/main -I/usr/local/include/php/TSRM -I/usr/local/include/php/Zend -I/usr/local/include/php/ext -I/usr/local/include/php/ext/date/lib -DHAVE_CONFIG_H -O2 -fno-strict-aliasing -pipe -c /usr/ports/devel/php5-tokenizer/work/php-5.2.12/ext/tokenizer/tokenizer.c -o tokenizer.lo /bin/sh /usr/ports/devel/php5-tokenizer/work/php-5.2.12/ext/tokenizer/libtool --mode=compile cc -I. -I/usr/ports/devel/php5-tokenizer/work/php-5.2.12/ext/tokenizer -DPHP_ATOM_INC -I/usr/ports/devel/php5-tokenizer/work/php-5.2.12/ext/tokenizer/include -I/usr/ports/devel/php5-tokenizer/work/php-5.2.12/ext/tokenizer/main -I/usr/ports/devel/php5-tokenizer/work/php-5.2.12/ext/tokenizer -I/usr/local/include/php -I/usr/local/include/php/main -I/usr/local/include/php/TSRM -I/usr/local/include/php/Zend -I/usr/local/include/php/ext -I/usr/local/include/php/ext/date/lib -DHAVE_CONFIG_H -O2 -fno-strict-aliasing -pipe -c /usr/ports/devel/php5-tokenizer/work/php-5.2.12/ext/tokenizer/tokenizer_data.c -o tokenizer_data.lo cc -I. -I/usr/ports/devel/php5-tokenizer/work/php-5.2.12/ext/tokenizer -DPHP_ATOM_INC -I/usr/ports/devel/php5-tokenizer/work/php-5.2.12/ext/tokenizer/include -I/usr/ports/devel/php5-tokenizer/work/php-5.2.12/ext/tokenizer/main -I/usr/ports/devel/php5-tokenizer/work/php-5.2.12/ext/tokenizer -I/usr/local/include/php -I/usr/local/include/php/main -I/usr/local/include/php/TSRM -I/usr/local/include/php/Zend -I/usr/local/include/php/ext -I/usr/local/include/php/ext/date/lib -DHAVE_CONFIG_H -O2 -fno-strict-aliasing -pipe -c /usr/ports/devel/php5-tokenizer/work/php-5.2.12/ext/tokenizer/tokenizer_data.c -fPIC -DPIC -o .libs/tokenizer_data.o cc -I. -I/usr/ports/devel/php5-tokenizer/work/php-5.2.12/ext/tokenizer -DPHP_ATOM_INC -I/usr/ports/devel/php5-tokenizer/work/php-5.2.12/ext/tokenizer/include -I/usr/ports/devel/php5-tokenizer/work/php-5.2.12/ext/tokenizer/main -I/usr/ports/devel/php5-tokenizer/work/php-5.2.12/ext/tokenizer -I/usr/local/include/php -I/usr/local/include/php/main -I/usr/local/include/php/TSRM -I/usr/local/include/php/Zend -I/usr/local/include/php/ext -I/usr/local/include/php/ext/date/lib -DHAVE_CONFIG_H -O2 -fno-strict-aliasing -pipe -c /usr/ports/devel/php5-tokenizer/work/php-5.2.12/ext/tokenizer/tokenizer.c -fPIC -DPIC -o .libs/tokenizer.o In file included from /usr/local/include/php/main/../main/php_config.h:2839, from /usr/local/include/php/Zend/zend_config.h:1, from /usr/local/include/php/Zend/zend.h:53, from /usr/local/include/php/main/php.h:34, from /usr/ports/devel/php5-tokenizer/work/php-5.2.12/ext/tokenizer/tokenizer.c:25: In file included from /usr/local/include/php/main/../main/php_config.h:2839, from /usr/local/include/php/Zend/zend_config.h:1, from /usr/local/include/php/Zend/zend.h:53, from /usr/local/include/php/main/php.h:34, from /usr/ports/devel/php5-tokenizer/work/php-5.2.12/ext/tokenizer/tokenizer_data.c:26:
/usr/local/include/php/ext/php_config.h: 9 : 29 : ext/pcre/config.h: No such file or directory
*** Error code 1
*** Error code 1
2 errors
*** Error code 1
Stop in /usr/ports/devel/php5-tokenizer.
в чем может быть причина?
поддержка пишет:
авторпроблема в том, что ментейнер порта некоектно собрал оный
1. можете подождать когда он его починит
2. можете установить самомтоятельно
