Падение сервера
Имею сервер Sun-Fire-V245 c установленной Solaris 10. В последнее время стал падать, однако в /var/adm/messages ничего странного не заметил. Провел диагностику оперативки fmadm faulty, fmdump -v -e, заменил проблемную планку. Однако проблемы продолжились. Сервер падает в init 0. Перед падением выходит сообщение: SUNW-MSG-ID: SUNOS-8000-0G, TYPE: Error, VER: 1, SEVERITY: Major EVENT-TIME: 0x4cfdbcbc.0x245bdd16 (0x1da66678dd2) PLATFORM: SUNW,Sun-Fire-V245, CSN: -, HOSTNAME: ХХХХХХХ SOURCE: SunOS, REV: 5.10 Generic_142900-07 DESC: Errors have been detected that require a reboot to ensure system integrityЧ SC Alert: Host System has Reset CPU 0000.0000.0000.0000 AFSR 0102.0000.050c.0000 SCE ISAP AFAR 0000.0000.0000.0000 Fatal Error Reset Executing Power On Self Test 0> 0>@(#)Sun Fire[TM] V215/V245 POST 4.30.4 2009/08/19 07:35 /export/delivery/delivery/4.30/4.30.4/post4.30.4-micro/Fiesta/seattle/integrated (root) 0>Copyright 2009 Sun Microsystems, Inc. All rights reserved 0>FATAL Reset! 0>OBP->POST Call with %o0=00000800.01014000. 0>Diag level set to MAX. 0>Verbosity level set to NORMAL. 0> 0>@(#)Sun Fire[TM] V215/V245 POST 4.30.4 2009/08/19 07:35 /export/delivery/delivery/4.30/4.30.4/post4.30.4-micro/Fiesta/seattle/integrated (root) 0>Copyright 2009 Sun Microsystems, Inc. All rights reserved 0>OBP->POST Call with %o0=00000800.01014000. 0>Diag level set to MAX. 0>Verbosity level set to NORMAL. 0>Start Selftest..... 0>CPUs present in system: 0 1 0>Test CPU(s)....Done 0>FATAL ERROR!! 0>ERROR: Illegal Instruction! 0>AFAR 00000000.00000000 0>JBUS config reg = 13fa3f3e.104001ea. 0>L2Cache CSR reg = 00000000.00f14000. 0>FIRE JBUS CSR 00000ff5.13cb6000 0>JBC Error Status Clear 00000000.00000000 0>JBC Fatal Error log1 reg 00000000.00000000 0>JBC Fatal Error log2 reg 00049249.201c7fc0 0>JBC Error Status Clear reg 00000000.00000000 0> 0> 0 Peek/Poke interface 0> 1 Dump CPU Regs 0> 2 Dump Valid L2$ 0> 3 Dump Trap Table 0> 4 Dump Mem Controller Regs 0> 5 Dump Valid DMMU entries 0> 6 Dump IMMU entries 0> 7 Dump Mailbox 0> 8 Dump IO-Bridge regs 0> 9 Allow other CPUs to print 0> a Do soft reset 0> ? Help 0> 0>Selection:> как я понял предлагается чтото выбрать, но что? и с чем связано такое поведение ... |
| 07.12.2010, 08:11:08 |
start [/forum/topic.php?fid=25&gotonew=1&tid=1484559]: |
76ms |
43ms |
| others: | 309ms |
| total: | 521ms |
