жесткие диски в linux
в системе установлен дополнительный sata диск. После 5-10 минут работы диск пропадает. Что можно предпринять? ... |
| 09.02.2011, 10:53:07 |
dmesg|tail -100 ... |
| 09.02.2011, 10:56:55 |
Журавлев Денис, автор[ 384.097952] ata1.00: error: { ICRC ABRT } [ 384.097969] ata1: soft resetting link [ 384.343661] ata1.00: configured for UDMA/33 [ 384.343683] ata1: EH complete [ 384.356055] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 [ 384.356063] ata1.00: BMDMA stat 0x26 [ 384.356073] ata1.00: cmd 25/00:00:4f:84:38/00:01:ab:00:00/e0 tag 0 dma 131072 in [ 384.356076] res 51/84:1f:4f:84:38/84:00:00:00:00/e0 Emask 0x30 (host bus error) [ 384.356083] ata1.00: status: { DRDY ERR } [ 384.356087] ata1.00: error: { ICRC ABRT } [ 384.356099] ata1: soft resetting link [ 384.603662] ata1.00: configured for UDMA/33 [ 384.603680] ata1: EH complete [ 384.608749] sd 0:0:0:0: [sda] 2930277168 512-byte hardware sectors (1500302 M B) [ 384.615211] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 [ 384.615221] ata1.00: BMDMA stat 0x26 [ 384.615231] ata1.00: cmd 25/00:58:4f:85:38/00:00:ab:00:00/e0 tag 0 dma 45056 in [ 384.615234] res 51/84:17:4f:85:38/84:00:00:00:00/e0 Emask 0x30 (host bus error) [ 384.615242] ata1.00: status: { DRDY ERR } [ 384.615246] ata1.00: error: { ICRC ABRT } [ 384.615259] ata1: soft resetting link [ 384.859680] ata1.00: configured for UDMA/33 [ 384.859700] ata1: EH complete [ 384.872679] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 [ 384.872687] ata1.00: BMDMA stat 0x26 [ 384.872696] ata1.00: cmd 25/00:58:4f:85:38/00:00:ab:00:00/e0 tag 0 dma 45056 in [ 384.872700] res 51/84:47:4f:85:38/84:00:00:00:00/e0 Emask 0x30 (host bus error) [ 384.872707] ata1.00: status: { DRDY ERR } [ 384.872711] ata1.00: error: { ICRC ABRT } [ 384.872723] ata1: soft resetting link [ 385.175667] ata1.00: configured for UDMA/33 [ 385.175687] ata1: EH complete [ 385.197497] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 [ 385.197505] ata1.00: BMDMA stat 0x26 [ 385.197514] ata1.00: cmd 25/00:58:4f:85:38/00:00:ab:00:00/e0 tag 0 dma 45056 in [ 385.197518] res 51/84:47:4f:85:38/84:00:00:00:00/e0 Emask 0x30 (host bus error) [ 385.197525] ata1.00: status: { DRDY ERR } [ 385.197529] ata1.00: error: { ICRC ABRT } [ 385.197541] ata1: soft resetting link [ 385.499671] ata1.00: configured for UDMA/33 [ 385.499690] ata1: EH complete [ 385.517000] sd 0:0:0:0: [sda] Write Protect is off [ 385.517011] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 [ 385.517112] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, does n't support DPO or FUA [ 385.517204] sd 0:0:0:0: [sda] 2930277168 512-byte hardware sectors (1500302 M B) [ 385.517242] sd 0:0:0:0: [sda] Write Protect is off [ 385.517246] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 [ 385.517312] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, does n't support DPO or FUA [ 385.914180] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 [ 385.914189] ata1.00: BMDMA stat 0x26 [ 385.914198] ata1.00: cmd 25/00:78:97:aa:38/00:00:ab:00:00/e0 tag 0 dma 61440 in [ 385.914202] res 51/84:07:97:aa:38/84:00:00:00:00/e0 Emask 0x30 (host bus error) [ 385.914209] ata1.00: status: { DRDY ERR } [ 385.914213] ata1.00: error: { ICRC ABRT } [ 385.914225] ata1: soft resetting link [ 386.159649] ata1.00: configured for UDMA/33 [ 386.159667] ata1: EH complete [ 386.166624] sd 0:0:0:0: [sda] 2930277168 512-byte hardware sectors (1500302 M B) [ 386.166680] sd 0:0:0:0: [sda] Write Protect is off [ 386.166686] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 [ 386.166773] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, does n't support DPO or FUA [ 386.386867] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 [ 386.386877] ata1.00: BMDMA stat 0x26 [ 386.386886] ata1.00: cmd 25/00:38:57:80:38/00:00:ab:00:00/e0 tag 0 dma 28672 in [ 386.386890] res 51/84:27:57:80:38/84:00:00:00:00/e0 Emask 0x30 (host bus error) [ 386.386897] ata1.00: status: { DRDY ERR } [ 386.386901] ata1.00: error: { ICRC ABRT } [ 386.386913] ata1: soft resetting link [ 386.743697] ata1.00: configured for UDMA/33 [ 386.743714] ata1: EH complete [ 386.770205] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 [ 386.770213] ata1.00: BMDMA stat 0x26 [ 386.770222] ata1.00: cmd 25/00:38:57:80:38/00:00:ab:00:00/e0 tag 0 dma 28672 in [ 386.770226] res 51/84:07:57:80:38/84:00:00:00:00/e0 Emask 0x30 (host bus error) [ 386.770233] ata1.00: status: { DRDY ERR } [ 386.770237] ata1.00: error: { ICRC ABRT } [ 386.770249] ata1: soft resetting link [ 387.071681] ata1.00: configured for UDMA/33 [ 387.071700] ata1: EH complete [ 387.089285] sd 0:0:0:0: [sda] 2930277168 512-byte hardware sectors (1500302 M B) [ 387.089341] sd 0:0:0:0: [sda] Write Protect is off [ 387.089346] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 [ 387.089433] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, does n't support DPO or FUA [ 387.089509] sd 0:0:0:0: [sda] 2930277168 512-byte hardware sectors (1500302 M B) [ 387.089547] sd 0:0:0:0: [sda] Write Protect is off [ 387.089551] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 [ 387.089617] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, does n't support DPO or FUA [ 417.556056] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen [ 417.556071] ata1.00: cmd 25/00:68:bf:9e:38/00:00:ab:00:00/e0 tag 0 dma 53248 in [ 417.556075] res 40/00:07:57:80:38/84:00:00:00:00/e0 Emask 0x4 (timeo ut) [ 417.556081] ata1.00: status: { DRDY } [ 422.596031] ata1: link is slow to respond, please be patient (ready=0) [ 427.580033] ata1: device not ready (errno=-16), forcing hardreset [ 427.580046] ata1: soft resetting link [ 427.907671] ata1.00: configured for UDMA/33 [ 427.907688] ata1: EH complete [ 427.917588] sd 0:0:0:0: [sda] 2930277168 512-byte hardware sectors (1500302 M B) [ 427.919703] sd 0:0:0:0: [sda] Write Protect is off [ 427.919712] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 [ 427.919810] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, does n't support DPO or FUA ... |
| 09.02.2011, 11:19:50 |
я бы начал с замены кабеля, если не поможет обновил бы ядро ... |
| 09.02.2011, 11:27:55 |
Журавлев Денис, Спасибо, попробую ... |
| 09.02.2011, 11:33:33 |
start [/forum/topic.php?fid=25&gotonew=1&tid=1484423]: |
29ms |
51ms |
| others: | 285ms |
| total: | 424ms |
