mount не может смонтировать smb
При монтировании smb mount-ом , последний ругается что неизвестный тип файловой системы [root@red samba]# mount -t smbfs -o username=tiе,password=tiе$$ //bge0/ /opt/test/ mount: unknown filesystem type 'smbfs' [root@red samba]# Хотя в мане четко указан, что такой тип файловой системы есть: -t, --types vfstype The argument following the -t is used to indicate the filesystem type. The filesystem types which are currently supported include: adfs, affs, autofs, cifs, coda, coherent, cramfs, debugfs, devpts, efs, ext, ext2, ext3, ext4, hfs, hfs- plus, hpfs, iso9660, jfs, minix, msdos, ncpfs, nfs, nfs4, ntfs, proc, qnx4, ramfs, reiserfs, romfs, squashfs, smbfs , sysv, tmpfs, ubifs, udf, ufs, umsdos, usbfs, vfat, xenix, xfs, xiafs. ... |
| 16.04.2012, 17:52:11 |
-t cifs ... |
| 16.04.2012, 19:11:14 |
tie@debian:/etc/samba$ sudo mount -t cifs //192.168.0.128/s /mnt/test/ mount: wrong fs type, bad option, bad superblock on //192.168.0.128/s, missing codepage or helper program, or other error (for several filesystems (e.g. nfs, cifs) you might need a /sbin/mount.<type> helper program) In some cases useful info is found in syslog - try dmesg | tail or so ... |
| 17.04.2012, 20:11:41 |
Ну дык что dmesg выводит? ... |
| 17.04.2012, 20:18:49 |
[ 9080.364854] CIFS VFS: cifs_mount failed w/return code = -22 [ 9257.851984] CIFS VFS: cifs_mount failed w/return code = -22 ... |
| 17.04.2012, 20:33:22 |
| 17.04.2012, 20:58:39 |
Большое спасибо за ссылку. Но сейчас другая проблемка. ... |
| 17.04.2012, 21:11:05 |
tie@debian:~/Desktop/Downloads$ sudo apt-get install smbfs cifs-utils Reading package lists... Done Building dependency tree Reading state information... Done smbfs is already the newest version. cifs-utils is already the newest version. You might want to run 'apt-get -f install' to correct these: The following packages have unmet dependencies: cifs-utils : Depends: libkrb5-3 (>= 1.10+dfsg~) but 1.8.3+dfsg-4squeeze5 is to be installed Depends: libtalloc2 (>= 2.0.4~git20101213) but 2.0.1-1 is to be installed Recommends: keyutils but it is not installable Recommends: winbind but it is not going to be installed smbfs : Depends: cifs-utils (= 2:4.5-2+squeeze1) but 2:5.3-2 is to be installed E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution). tie@debian:~/Desktop/Downloads$ ... |
| 17.04.2012, 21:13:45 |
Как сделать так чтоб со всеми зависимостями качал пакеты.? ... |
| 17.04.2012, 21:14:53 |
pricy, АРТ всегда качает пакеты со всеми зависимостями. Недавно почему-то сломалась локальная база данных о пакетах. Чтобы исправить ситуацию, надо запустить Код: plaintext ... |
| 17.04.2012, 21:55:25 |
timur@debian:~$ sudo mount -t cifs -o username=timur,password=timur$$ //192.168.16.1/test /mnt/test/ mount: block device //192.168.16.1/test is write-protected, mounting read-only mount: cannot mount block device //192.168.16.1/test read-only timur@debian:~$ ... |
| 19.04.2012, 10:01:11 |
Хотя в винде я открыл шару на чтение и запись ... |
| 19.04.2012, 10:02:41 |
Везде пишут что sudo apt-get install smbfs установит пакет . И никаких проблем. У меня же на деле вот что (см. ниже) ... |
| 19.04.2012, 10:07:54 |
tie@debian:~$ sudo apt-get install smbfs Reading package lists... Done Building dependency tree Reading state information... Done Package smbfs is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source E: Package 'smbfs' has no installation candidate tie@debian:~$ sudo apt-get install cifs-utils Reading package lists... Done Building dependency tree Reading state information... Done Package cifs-utils is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source E: Package 'cifs-utils' has no installation candidate tie@debian:~$ ... |
| 19.04.2012, 10:08:49 |
start [/forum/topic.php?fid=25&gotonew=1&tid=1483603]: |
51ms |
83ms |
| others: | 371ms |
| total: | 592ms |
