squid каждые 60 минут рвет связь
squid 3.1.6 прозрачный squid каждые 60 минут рвет связь, потом восстанавливает, и все могут работать дальше. те у кого были закачки нужно качать снова, кто работал с удаленным сервером нужно перезаходить в программы. подскажите где смотреть squid.conf на исправление данной проблеммы. # TIMEOUTS # ----------------------------------------------------------------------------- # TAG: forward_timeout time-units # This parameter specifies how long Squid should at most attempt in # finding a forwarding path for the request before giving up. #Default: # forward_timeout 4 minutes # TAG: connect_timeout time-units # This parameter specifies how long to wait for the TCP connect to # the requested server or peer to complete before Squid should # attempt to find another path where to forward the request. #Default: # connect_timeout 1 minute # TAG: peer_connect_timeout time-units # This parameter specifies how long to wait for a pending TCP # connection to a peer cache. The default is 30 seconds. You # may also set different timeout values for individual neighbors # with the 'connect-timeout' option on a 'cache_peer' line. #Default: # peer_connect_timeout 30 seconds # TAG: read_timeout time-units # The read_timeout is applied on server-side connections. After # each successful read(), the timeout will be extended by this # amount. If no data is read again after this amount of time, # the request is aborted and logged with ERR_READ_TIMEOUT. The # default is 15 minutes. #Default: # read_timeout 15 minutes # TAG: request_timeout # How long to wait for an HTTP request after initial # connection establishment. #Default: # request_timeout 5 minutes # TAG: persistent_request_timeout # How long to wait for the next HTTP request on a persistent # connection after the previous request completes. #Default: # persistent_request_timeout 2 minutes # TAG: client_lifetime time-units # The maximum amount of time a client (browser) is allowed to # remain connected to the cache process. This protects the Cache # from having a lot of sockets (and hence file descriptors) tied up # in a CLOSE_WAIT state from remote clients that go away without # properly shutting down (either because of a network failure or # because of a poor client implementation). The default is one # day, 1440 minutes. # # NOTE: The default value is intended to be much larger than any # client would ever need to be connected to your cache. You # should probably change client_lifetime only as a last resort. # If you seem to have many client connections tying up # filedescriptors, we recommend first tuning the read_timeout, # request_timeout, persistent_request_timeout and quick_abort values. #Default: # client_lifetime 1 day # TAG: half_closed_clients # Some clients may shutdown the sending side of their TCP # connections, while leaving their receiving sides open. Sometimes, # Squid can not tell the difference between a half-closed and a # fully-closed TCP connection. # # By default, Squid will immediately close client connections when # read(2) returns "no more data to read." # # Change this option to 'on' and Squid will keep open connections # until a read(2) or write(2) on the socket returns an error. # This may show some benefits for reverse proxies. But if not # it is recommended to leave OFF. #Default: # half_closed_clients off # TAG: pconn_timeout # Timeout for idle persistent connections to servers and other # proxies. #Default: # pconn_timeout 1 minute # TAG: ident_timeout # Maximum time to wait for IDENT lookups to complete. # # If this is too high, and you enabled IDENT lookups from untrusted # users, you might be susceptible to denial-of-service by having # many ident requests going at once. #Default: # ident_timeout 10 seconds # TAG: shutdown_lifetime time-units # When SIGTERM or SIGHUP is received, the cache is put into # "shutdown pending" mode until all active sockets are closed. # This value is the lifetime to set for all open descriptors # during shutdown mode. Any active clients after this many # seconds will receive a 'timeout' message. #Default: # shutdown_lifetime 30 seconds ... |
| 05.03.2013, 12:34:01 |
monstr76, приведи свой squid.conf без коментариаев. То что сейчас привел вообще ни для чего не годится, там закоментировано. Плюс смотри еще крон может он что-то дергает каждый час. ... |
| 05.03.2013, 12:38:52 |
acl manager proto cache_object acl localhost src 127.0.0.1/32 ::1 acl to_localhost dst 127.0.0.0/8 0.0.0.0/32 ::1 acl localnet src 10.0.0.0/8 # RFC1918 possible internal network acl localnet src 172.16.0.0/12 # RFC1918 possible internal network acl localnet src 192.168.0.0/16 # RFC1918 possible internal network acl SSL_ports port 443 acl Safe_ports port 80 # http acl Safe_ports port 21 # ftp acl Safe_ports port 443 # https acl Safe_ports port 995 acl Safe_ports port 70 # gopher acl Safe_ports port 210 # wais acl Safe_ports port 1025-65535 # unregistered ports acl Safe_ports port 280 # http-mgmt acl Safe_ports port 488 # gss-http acl Safe_ports port 591 # filemaker acl Safe_ports port 777 # multiling http acl CONNECT method CONNECT acl worktime time MTWHF 00:00-04:00 acl noworksites dstdomain "/etc/squid3/badsites.txt" acl block dstdomain "/etc/squid3/block.txt" acl ipacl dstdom_regex ^[0-9]*.[0-9]*.[0-9]*.[0-9]* http_access allow manager localhost http_access deny manager http_access deny !Safe_ports http_access deny CONNECT !SSL_ports http_access deny block http_access allow localnet http_access allow localhost http_access deny all http_port 3128 hierarchy_stoplist cgi-bin ? coredump_dir /var/spool/squid3 refresh_pattern ^ftp: 1440 20% 10080 refresh_pattern ^gopher: 1440 0% 1440 refresh_pattern -i (/cgi-bin/|\?) 0 0% 0 refresh_pattern . 0 20% 4320 delay_pools 2 delay_class 1 3 delay_class 2 3 delay_access 1 allow noworksites delay_access 1 deny all delay_parameters 1 256000/256000 128000/128000 32000/128000 delay_access 2 allow localnet delay_access 2 deny all delay_parameters 2 1792000/1792000 1792000/1792000 384000/3276800 ... |
| 05.03.2013, 13:39:55 |
crontabs 59 23 * * * /etc/init.d/squid3 restart ... |
| 05.03.2013, 13:41:16 |
Статистику наверное собираете каждый час, там и рестартуете squid, хотя надо squid -k reconfigure, а не restart ... |
| 05.03.2013, 15:25:32 |
Sergey OrlovСтатистику наверное собираете каждый час, там и рестартуете squid, хотя надо squid -k reconfigure, а не restart но рестарт производится в 23:59 по cronу, при чем тут каждый час. ... |
| 05.03.2013, 16:05:18 |
1. Посмотрите на время создания/модификаиции лога сквида 2. Внимательнее посмотрите все ваши задания и не только в системном кроне, что в это время может выполняться У меня например каждые 20-ть минут лог сквида обрабатывает sarg и после обработки он определяет трафик, использованный пользователем и модифицирует несколько файлов, которые фигурируют в конфиге сквида, так вот дать понять сквиду, что надо перечитать этот конфиг можно 2-мя способами 1. перестартовать его, при этом сессии оборвуться, 2. перечитать конфиг, при этом сессии не оборвуться, но у сквида будт действовать новые параметры. ... |
| 05.03.2013, 16:25:41 |
Спасибо Сергей. Все работает как надо. каждый час не рвет. ... |
| 05.03.2013, 17:03:26 |
monstr76Спасибо Сергей. Все работает как надо. каждый час не рвет. В чем проблема-то была? ... |
| 06.03.2013, 10:45:07 |
k-nikemonstr76Спасибо Сергей. Все работает как надо. каждый час не рвет. В чем проблема-то была?скорее всего именно крон, об этом сразу сказал ... |
| 06.03.2013, 12:17:25 |
bga83скорее всего именно крон, об этом сразу сказал Скорее всего да, но хотелось бы от ТС получить объяснения, ибо он уверяет, что крон у него только раз в день дергает сквид. ... |
| 06.03.2013, 13:50:34 |
start [/forum/topic.php?fid=25&gotonew=1&tid=1483082]: |
39ms |
87ms |
| others: | 390ms |
| total: | 598ms |
