raspbian: apt-get update - Some index files failed to download
Привет всем! Уже несколько дней не могу обновить систему (OS Raspbian). $ sudo apt-get update -y; sudo apt-get upgrade -y; sudo apt-get autoremove -y; sudo apt-get clean -y Hit http://raspberrypi.collabora.com wheezy Release.gpg Hit http://archive.raspberrypi.org wheezy Release.gpg Hit http://mirrordirector.raspbian.org wheezy Release.gpg Hit http://raspberrypi.collabora.com wheezy Release Hit http://archive.raspberrypi.org wheezy Release Hit http://mirrordirector.raspbian.org wheezy Release Hit http://raspberrypi.collabora.com wheezy/rpi armhf Packages Hit http://archive.raspberrypi.org wheezy/main armhf Packages Ign http://archive.raspberrypi.org wheezy/main Translation-en Hit http://mirrordirector.raspbian.org wheezy/contrib armhf Packages Hit http://mirrordirector.raspbian.org wheezy/non-free armhf Packages Hit http://mirrordirector.raspbian.org wheezy/rpi armhf Packages Ign http://raspberrypi.collabora.com wheezy/rpi Translation-en Get:1 http://mirrordirector.raspbian.org wheezy/main armhf Packages [9509 kB] Ign http://mirrordirector.raspbian.org wheezy/contrib Translation-en Ign http://mirrordirector.raspbian.org wheezy/main Translation-en Ign http://mirrordirector.raspbian.org wheezy/non-free Translation-en Ign http://mirrordirector.raspbian.org wheezy/rpi Translation-en Fetched 1 B in 22s (0 B/s) W: Failed to fetch gzip:/var/lib/apt/lists/partial/mirrordirector.raspbian.org_raspbian_dists_wheezy_ main_binary-armhf_Packages Hash Sum mismatch E: Some index files failed to download. They have been ignored, or old ones used instead. Поменял адрес зеркала, не помогло: $ sudo less /etc/apt/sources.list deb http://archive.raspbian.org/raspbian wheezy main contrib non-free rpi deb-src http://archive.raspbian.org/raspbian wheezy main contrib non-free rpi $ sudo apt-get update Hit http://archive.raspbian.org wheezy Release.gpg Hit http://raspberrypi.collabora.com wheezy Release.gpg Hit http://archive.raspberrypi.org wheezy Release.gpg Hit http://archive.raspbian.org wheezy Release Hit http://raspberrypi.collabora.com wheezy Release Hit http://archive.raspberrypi.org wheezy Release Hit http://raspberrypi.collabora.com wheezy/rpi armhf Packages Hit http://archive.raspberrypi.org wheezy/main armhf Packages Hit http://archive.raspbian.org wheezy/non-free Sources Hit http://archive.raspbian.org wheezy/rpi Sources Ign http://archive.raspberrypi.org wheezy/main Translation-en Hit http://archive.raspbian.org wheezy/non-free armhf Packages Ign http://raspberrypi.collabora.com wheezy/rpi Translation-en Hit http://archive.raspbian.org wheezy/rpi armhf Packages Get:1 http://archive.raspbian.org wheezy/main Sources [7710 kB] Hit http://archive.raspbian.org wheezy/contrib Sources Get:2 http://archive.raspbian.org wheezy/main armhf Packages [9509 kB] Hit http://archive.raspbian.org wheezy/contrib armhf Packages Ign http://archive.raspbian.org wheezy/contrib Translation-en Ign http://archive.raspbian.org wheezy/main Translation-en Ign http://archive.raspbian.org wheezy/non-free Translation-en Ign http://archive.raspbian.org wheezy/rpi Translation-en Fetched 2 B in 22s (0 B/s) W: Failed to fetch gzip:/var/lib/apt/lists/partial/archive.raspbian.org_raspbian_dists_wheezy_main_source_Sources Hash Sum mismatch W: Failed to fetch gzip:/var/lib/apt/lists/partial/archive.raspbian.org_raspbian_dists_wheezy_main_binary-armhf_Packages Hash Sum mismatch E: Some index files failed to download. They have been ignored, or old ones used instead. Здесь http://www.raspberrypi.org/phpBB3/viewtopic.php?f=66&t=18190 нашел совет by plugwash » Tue Sep 25, 2012 6:36 am Please try the following apt-get install apt-transport-https ca-certificates Then point your sources.list at https://archive.raspbian.org/raspbian and try running apt-get update again. Однако попытка установить пакет неуспешная: $ sudo apt-get install apt-transport-https ca-certificates Reading package lists... Done Building dependency tree Reading state information... Done E: Unable to locate package apt-transport-https В общем, я понимаю, что если на зеркало выложили кривой пакет, то его поменять займёт время. Жду. Просто уже несколько дней это всё длится. Насколько помню, дело не в том, что закончилось свободное место (дома еще раз проверю). Если у кого-то есть мысли по этому поводу, поделитесь плз. ... |
| 30.10.2013, 13:21:59 |
$ sudo apt-get install apt-transport-https ... Странный совет установить отсутствующий в пуле пакет. Отсюда и результат — E: Unable to locate package apt-transport-https . Попробуйте другие зеркала распбиана подключить ... |
| 30.10.2013, 14:43:24 |
вчера и update и upgrade прошли с одного раза. ... |
| 01.11.2013, 13:29:46 |
start [/forum/topic.php?fid=25&gotonew=1&tid=1482749]: |
52ms |
50ms |
| others: | 335ms |
| total: | 497ms |
