ftpget как скачать множество файлов и по маске?
ftpget как скачать множество файлов и по маске? На сервере только эта команда, mget нету!!! 1. Как можно скачать все файлы avi с удаленного сервера? 2. Как скачать 1 файл но не зная его точного имени, т.е указать маску файла? ... |
| 17.11.2013, 12:33:59 |
$ ftp ftp.dlink.ru Connected to ftp.dlink.ru (94.198.53.90). 220---------- Welcome to Pure-FTPd [privsep] [TLS] ---------- 220-You are user number 60 of 200 allowed. 220-Local time is now 12:33. Server port: 21. 220-IPv6 connections are also welcome on this server. 220 You will be disconnected after 15 minutes of inactivity. Name (ftp.dlink.ru:user): anonymous 230 Anonymous user logged in Remote system type is UNIX. Using binary mode to transfer files. ftp> cd /pub/Router/DIR-651/Firmware/Old 250 OK. Current directory is /pub/Router/DIR-651/Firmware/Old ftp> prompt Interactive mode off. ftp> mget *.bin local: 20130213_1407_DIR_651A_1.0.1_sdk-master.bin remote: 20130213_1407_DIR_651A_1.0.1_sdk-master.bin 227 Entering Passive Mode (94,198,53,90,215,140) 150-Accepted data connection 150 2888.0 kbytes to download 226-File successfully transferred 226 1.821 seconds (measured here), 1.55 Mbytes per second 2957314 bytes received in 1,94 secs (1521,32 Kbytes/sec) local: 20130321_1716_DIR_651A_1.0.5_sdk-master.bin remote: 20130321_1716_DIR_651A_1.0.5_sdk-master.bin 227 Entering Passive Mode (94,198,53,90,117,60) 150-Accepted data connection 150 2916.0 kbytes to download 226-File successfully transferred 226 1.328 seconds (measured here), 2.14 Mbytes per second 2985986 bytes received in 1,54 secs (1939,10 Kbytes/sec) ftp> bye 221-Goodbye. You uploaded 0 and downloaded 5805 kbytes. 221 Logout. ... |
| 18.11.2013, 13:29:44 |
Vadim Lejnin$ ftp ftp.dlink.ru Connected to ftp.dlink.ru (94.198.53.90). 220---------- Welcome to Pure-FTPd [privsep] [TLS] ---------- 220-You are user number 60 of 200 allowed. 220-Local time is now 12:33. Server port: 21. 220-IPv6 connections are also welcome on this server. 220 You will be disconnected after 15 minutes of inactivity. Name (ftp.dlink.ru:user): anonymous 230 Anonymous user logged in Remote system type is UNIX. Using binary mode to transfer files. ftp> cd /pub/Router/DIR-651/Firmware/Old 250 OK. Current directory is /pub/Router/DIR-651/Firmware/Old ftp> prompt Interactive mode off. ftp> mget *.bin local: 20130213_1407_DIR_651A_1.0.1_sdk-master.bin remote: 20130213_1407_DIR_651A_1.0.1_sdk-master.bin 227 Entering Passive Mode (94,198,53,90,215,140) 150-Accepted data connection 150 2888.0 kbytes to download 226-File successfully transferred 226 1.821 seconds (measured here), 1.55 Mbytes per second 2957314 bytes received in 1,94 secs (1521,32 Kbytes/sec) local: 20130321_1716_DIR_651A_1.0.5_sdk-master.bin remote: 20130321_1716_DIR_651A_1.0.5_sdk-master.bin 227 Entering Passive Mode (94,198,53,90,117,60) 150-Accepted data connection 150 2916.0 kbytes to download 226-File successfully transferred 226 1.328 seconds (measured here), 2.14 Mbytes per second 2985986 bytes received in 1,54 secs (1939,10 Kbytes/sec) ftp> bye 221-Goodbye. You uploaded 0 and downloaded 5805 kbytes. 221 Logout. Я же писал доступна только команда ftpget !!! Я сделал php скриптом, все больше не нужно ничего!!! ... |
| 18.11.2013, 18:52:26 |
start [/forum/topic.php?fid=25&gotonew=1&tid=1482730]: |
59ms |
48ms |
| others: | 317ms |
| total: | 480ms |
