антиспам postfix-cluebringer
Дано: Linux Debian wheezy 7.5 stable Postfix postfix-cluebringer (2.0.10-1) Ошибка : при попытке запуска ./postfix-cluebringer restart в файле /var/log/cluebringer/cluebringer.log ошибка Couldn't open pid file "/var/run/cluebringer/cbpolicyd.pid" [Permission denied] Делала следующее: chown root:root /var/run/cluebringer chmod 770 /var/run/cluebringer Ошибка не исчезла. Помогите плиз уважаемые профессионалы, файлы конфигурации привожу... main.cf smtpd_banner = $myhostname ESMTP $mail_name (Debian/GNU) biff = no # appending .domain is the MUA's job. append_dot_mydomain = yes myhostname = mydomain.ru alias_maps = hash:/etc/aliases alias_database = hash:/etc/aliases myorigin = /etc/mailname mydestination = mydomain.ru, mail.mydomain.ru relayhost = mynetworks = 127.0.0.0/8, 172.16.1.0/24, 172.16.18.0/24, 172.16.8.0/24, 172.16.3.0/24, 172.16.9.0/24, 172.16.7.0/24 ,172.16.20.0/24, 172.16.22.0/24, 172.16.14.0/24,172.16.15.0/24, 172.16.17.0/24, 172.16.23.0/24 inet_interfaces = all mailbox_command = procmail -a "$EXTENSION" mailbox_size_limit = 0 message_size_limit=0 recipient_delimiter = + smtpd_recipient_restrictions = permit_mynetworks, reject_unauth_destination, reject_unlisted_recipient,check_policy_service inet:127.0.0.1:10031 local_recipient_maps = unix:passwd.byname $alias_maps cluebringer.conf [server] # Protocols to load protocols=<<EOT Postfix Bizanga EOT # Modules to load modules=<<EOT Core AccessControl CheckHelo CheckSPF Greylisting Quotas EOT # User to run this daemon as user=root group=root # Filename to store pid of parent process pid_file=/var/run/cluebringer/cbpolicyd.pid # Uncommenting the below option will prevent cbpolicyd going into the background #background=no # Preforking configuration # # min_server - Minimum servers to keep around # min_spare_servers - Minimum spare servers to keep around ready to # handle requests # max_spare_servers - Maximum spare servers to have around doing nothing # max_servers - Maximum servers alltogether # max_requests - Maximum number of requests each child will serve # # One may want to use the following as a rough guideline... # Small mailserver: 2, 2, 4, 10, 1000 # Medium mailserver: 4, 4, 12, 25, 1000 # Large mailserver: 8, 8, 16, 64, 1000 # #min_servers=4 #min_spare_servers=4 #max_spare_servers=12 #max_servers=25 #max_requests=1000 # Log level: # 0 - Errors only # 1 - Warnings and errors # 2 - Notices, warnings, errors # 3 - Info, notices, warnings, errors # 4 - Debugging log_level=4 # File to log to instead of stdout log_file=/var/log/cbpolicyd.log # Log destination for mail logs... # main - Default. Log to policyd's main log mechanism, accepts NO args # syslog - log mail via syslog # format: log_mail=facility@method,args # # Valid methods for syslog: # native - Let Sys::Syslog decide # unix - Unix socket # udp - UDP socket # stream - Stream (for Solaris) # # Example: unix native #log_mail=mail@syslog:native # # Example: unix socket #log_mail=mail@syslog:unix # # Example: udp #log_mail=mail@syslog:udp,127.0.0.1 # # Example: Solaris #log_mail=local0@syslog:stream,/dev/log #log_mail=maillog log_mail=mail@syslog:native # Things to log in extreme detail # modules - Log detailed module running information # tracking - Log detailed tracking information # policies - Log policy resolution # protocols - Log general protocol info, but detailed # bizanga - Log the bizanga protocol # # There is no default for this configuration option. Options can be # separated by commas. ie. protocols,modules # #log_detail= # IP to listen on, * for all #host=* host=127.0.0.1 # Port to run on port=10031 # Timeout in communication with clients #timeout=120 # cidr_allow/cidr_deny # Comma, whitespace or semi-colon separated. Contains a CIDR block to # compare the clients IP to. If cidr_allow or cidr_deny options are # given, the incoming client must match a cidr_allow and not match a # cidr_deny or the client connection will be closed. #cidr_allow=0.0.0.0/0 #cidr_deny= [database] #DSN=DBI:SQLite:dbname=policyd.sqlite DSN=DBI:mysql:database=policyd;host=localhost Username=root Password= # What do we do when we have a database connection problem # tempfail - Return temporary failure # pass - Return success bypass_mode=tempfail # How many seconds before we retry a DB connection bypass_timeout=30 # Access Control module [AccessControl] enable=1 # Greylisting module [Greylisting] enable=1 # CheckHelo module [CheckHelo] enable=1 # CheckSPF module [CheckSPF] enable=1 # Quotas module [Quotas] enable=1 ... |
| 29.06.2014, 10:54:29 |
Mari.P, /var/run/cluebringer/cbpolicyd.pid - кто владелец файла? служба стартует от рута вы сменили владельца каталога, но файл внутри каталога принадлежит комуто другому видимо, chown -R root:root /var/run/cluebringer возможно и поможет Тока зачем вы от рута стартуете эту службу ? ... |
| 29.06.2014, 13:56:57 |
Заработало. Автоматом создался юзер cluebringer в группе cluebringer Сделала следующее: passwd cluebringer (сменила пароль) в файле /etc/cluebringer написала user=cluebringer group=cluebringer chown cluebringer:cluebringer /var/run/cluebringer chmod a+wxr /var/run/cluebringer изначально owner /var/run/cluebringer был cluebringer:www-data Всем спасибо! ... |
| 03.07.2014, 11:28:51 |
start [/forum/topic.php?fid=25&gotonew=1&tid=1482495]: |
27ms |
60ms |
76ms |
| others: | 365ms |
| total: | 602ms |
