Ошибка при pull (GIT)
При попытке сделать pull выходит ошибка eldos@10.0.20.22's password: remote: Counting objects: 11, done. remote: Compressing objects: 100% (6/6), done. remote: Total 6 (delta 4), reused 0 (delta 0) error: insufficient permission for adding an object to repository database .git/objects fatal: failed to write object fatal: unpack-objects failed ... |
| 12.11.2014, 08:16:50 |
start [/forum/topic.php?fid=25&gotonew=1&tid=1482302]: |
67ms |
72ms |
| others: | 365ms |
| total: | 602ms |
